Riding mower sputters and dies
Discussion in 'Home Improvement' started by cctxquicksand, Jul 9, 2022.
  1. Jul 9, 2022 at 9:11 AM
    cctxquicksand
    cctxquicksand [OP] IG - TRDistheWrd
    Cub cadet ltx 1045
    as title states the mower starts and runs for a minute or two sputters and dies. Tried a number of things and same results…
    carburetor replaced
    Fuel filter replaced
    Air filter replaced
    Spark plug replaced
    Fuel tank drained and replaced w new fuel
    Seafoamed
    Gas cap off same results
    Air filter off same results
    What am I forgetting?
  2. Jul 9, 2022 at 9:25 AM
    TRDFerguson
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
  3. Jul 9, 2022 at 9:27 AM
    Fuel getting to carb like it should? (Partial blocked line)
  4. Jul 9, 2022 at 9:38 AM
    cctxquicksand
    This occurred to me last night going to replace the lines as well today. Hopefully this helps.
    I also was thinking maybe it’s the 85octane?
  5. Jul 9, 2022 at 9:40 AM
    NewImprovedRon
    NewImprovedRon New Old Guy
    Ron
    NW Arkansas
    2015 Radiant Red Tundra
    Failing magneto?
    cctxquicksand[OP] likes this.
  6. Jul 9, 2022 at 9:55 AM
    shawn474
    shawn474 Lego connoisseur
    MoCo, Maryland
    So I have a zero turn cub cadet that did similar things. It would only run for 40 or so minutes and sputter and die.
    Then wouldn’t hot start…..had to let it cool down and then it would run for a few more minutes and stall.
    i did literally everything you did - magneto is a good guess and cheap enough to replace to see if it solves the problem. Mine ended up being an oil issue - I drained the oil and replaced with a new filter and oil. Turns out it was a low oil issue where it would overheat and stall the engine. I am burning oil somewhere and have to replace a couple ounces here and there. No problems since. Still have no idea why / how it’s burning and I don’t have any leaks anywhere that I can see - no splatter, drips or anything outwardly noticeable……..but haven’t had an issue since I did all that.
    Also, if you haven’t done so already. make sure you take off the engine cover and clear all the leaves, grass and debris. That can choke off the engine and cause it to stall as well.
  7. Jul 9, 2022 at 9:58 AM
    shawn474
    MoCo, Maryland
    One other thing - the gas can “varnish” the inside of the tank. The flakes of varnish can get in the gas lines and cause a blockage or choke off fuel delivery. If you replaced the filter, I would go ahead and replace the fuel lines as well. Never know what’s hiding in those either……
  8. Jul 9, 2022 at 11:21 AM
    I always use premium in my motorized yard equipment.
  9. Jul 9, 2022 at 11:34 AM
    P-Factor
    P-Factor New Member
    I totally agree with ColoradoTJ.
    I stopped using all ethanol's for the same or similar reasons and use only ethanol free 90+ gasoline in all my yard equipment.
    Problems fixed.
  10. Jul 9, 2022 at 11:36 AM
    Toyotoholic
    Toyotoholic -4Life-
    Jmz
    17' MGM
    Pro suspension, sways
    Disconnect the fuel lines and blow them out with a compressor, double check air flow, check ignition wires and all connections. Fresh oil drain and filter always helps as well as 91+ octane.
    cctxquicksand[OP] and ColoradoTJ like this.
  11. Jul 9, 2022 at 1:03 PM
    cctxquicksand
    Good info here thanks. Going to try the oil and filter today. My initial thought with those issues you mentioned would be to overheating, my mower doesn’t run long enough to get over heated. I’m getting spark, So electric is out. The air doesn’t seem to be an issue to I’ve pretty much narrowed down to what think is a fuel issue.
  12. Jul 9, 2022 at 1:04 PM
    cctxquicksand
    I’m thinking this may be likely the issue… or atleast part of it
  13. Jul 9, 2022 at 1:05 PM
    cctxquicksand
    I hate to admit it but all these issues have me seriously looking at electric riding mowers :crapstorm:
  14. Jul 9, 2022 at 1:23 PM
    shawn474
    MoCo, Maryland
    I thought the same thing……until I went and priced them! If you can do with a push mower (I can’t) then they’re much more reasonable. But the riders are in the 4-5k range
  15. Jul 9, 2022 at 4:54 PM
    rebmo
    Rural SE Wisconsin
    2020 CM LImited 5.7L V8 4WD
    As stated previously, make sure your fuel line is clear and fresh line with no leaks. Check your gas tank and make sure you don't have any debris floating around near the pickup tube. Sometimes letting a tractor sit will allow enough gas to trickle past a obstruction and it will run good for a bit then be starved for fuel and sputter. I found a piece of a gas can nozzle stuck in a JD 262 pickup tube after checking the entire gas line. It sucked it up again after reinstalling and luckily I checked it again and got it out of the tank and some other debris as well. Ran great after and still does. Simple thing to check.
  16. Jul 9, 2022 at 5:42 PM
    cctxquicksand
    There ended up being varnish partially blocking the gas tank nipple for the fuel lines. Cleared it out, replaced the fuel lines. She purrs like a kitten now
    thanks for all the suggestions and help :hattip:
    rebmo likes this.
  17. Jul 9, 2022 at 5:43 PM
    Vince
    Vince New Member
    Vincent
    Terre du lac, Missouri
    2011 White DBL cab 5.7
    K&N intake, Air bags
    85 octain I don't think that works. Blow the lines clean. 91 or corn free fuel with some star tron stabilizer
