Ride height numbers with lifted/leveled trucks
Discussion in '1st Gen Tundras (2000-2006)' started by AWilliams, Nov 19, 2023.
  1. Nov 19, 2023 at 7:05 AM
    AWilliams
    AWilliams [OP] New Member
    Hey guys,
    Been away a little while but have some suspension related questions. Can I get some numbers on those of you that have lifted/leveled your trucks? I'm trying to figure out exactly where I'm at with mine. Bought my truck the way it sits. If you could please list what lift/set up you have with a measurement from ground to fender and center hub to fender. Please limit responses to an V8 Access Cab 4x4. The double cab and 2x4/V6 always is lower. Thanks
    My truck is as follows:
    2003 Access Cab 4x4 TRD V8
    King coilovers
    5100 rear shocks
    Total Chaos UCA's
    285/70r17 tires
    Diff drop
    Suspension Maxx longer sway links
    Measurement now is appx. 22.5" from center hub to fender
    I'm maybe looking to change my set up to 5100/Dobinson/OME springs.
    Thanks for any help.
  2. Nov 19, 2023 at 7:07 AM
  3. Nov 19, 2023 at 7:09 AM
    AWilliams
    Damn...thx dude.
  4. Nov 19, 2023 at 7:49 AM
    shifty` Animals and insects don't do drugs
    Also, read the "Suspension and wheels" section over here: https://www.tundras.com/threads/so-you-wanna-buy-just-bought-a-1st-gen-tundra-eh.115928/
    It'll help you to avoid some of the 'ahas' and 'gotchas' others have run into in the past, plus help you ballpark what to expect from what you buy.
    There's probably resale value on those Kings, some may argue you're going backwards getting rid of them for any of the others you mentioned.
