Rich Hard Start - The Ongoing Struggle
Discussion in '2nd Gen Tundras (2007-2013)' started by grayscale, Mar 3, 2025.
  1. Mar 24, 2025 at 9:39 AM
    snivilous
    snivilous snivspeedshop.com
    SW UT
    300k+ Supercharged 2008
    I would have someone else crank the truck, or video the gauge while cranking and see what it does. Is there no pressure while the truck refuses to start, and then does start once the gauge is reading pressure for example?
  2. Mar 24, 2025 at 9:51 AM
    grayscale
    grayscale [OP] New Member
    DFW
    2013 Tundra CM TSS 4X4 5.7FFV
    This was a no start situation, so that's what it had while cranking
  3. Mar 24, 2025 at 10:02 AM
    snivilous
    SW UT
    Hmmmm so it would seem like fueling is probably not the issue. I would check spark next since it would be easy, pull a plug and coilpack and lay the plug on the valve cover and crank it and make sure there is spark. One of the guys on the supercharger thread had it recently where his truck wouldn't start and somehow (dont ask me) all of his spark plugs seemed to shit themselves at the same time. He said they were gross, he swapped them out, boom it fired right up. I'm not saying randomly swap all the plugs, but I would confirm that spark is at least happening when cranking. If it's not that, I would be inclined to replace the MAF sensor.
    Do you have anyway to datalog or watch sensor data? It'd be helpful to see fuel injector commanded duty cycle as well as MAF data. I would also be tempted to spray starter fluid in the intake and see if that helps it start. While fuel pressure and fresh injectors would seemingly solve fuel issues, that doesn't necessarily mean the injectors are actually opening---though I would imagine they are. But at the end of the day, either there's no fuel, no spark, or the air sensor data is messed up (assuming it has compression).
    I guess that's another question, have you tested compression? I would do that when you test for spark.
  4. Mar 24, 2025 at 10:33 AM
    grayscale
    DFW
    Well thanks for the help. I'll see what sensor data I can gether next time it starts up.
    While it's possible it is spark, I've kept it at the bottom of the list because I never have any issues beyond startup. Once it's running it's smooth all the way through the power band and wot.
    MAF is definitely a possibility I just wish there was a way to test it without throwing money at it.
    Is there any scenario where too much fuel would cause this? Or would that only be leaky injectors? I just feel like the rich exhaust smell has to be part of it
  5. Mar 24, 2025 at 10:50 AM
    snivilous
    SW UT
    I agree with everything you said, but you would think any issue would also rear its head during normal driving---MAF, spark, fuel, etc. Unless maybe the throttle body is doing weird shit so the idle air control is causing issues...
    I figure spark takes five minutes to check off the list, and was trying to save the pain of replacing the MAF when a good chance it's not that. That's why I was thinking if you can get MAF data through an OBD2 scanner maybe that would point to something.
    Too much fuel can definitely cause it to choke at startup, but I don't know why it would be commanding too much fuel and even if an injector was leaking that would only affect one cylinder. That's why I was next leaning towards MAF since if the air data is messed up then so is the fueling, since the truck looks at the MAF and says there's X amount of air so I need to inject X amount of fuel. Maybe the MAF is reading too much air or not enough. If you can get voltage off of the MAF we could compare that to a normal truck at startup potentially and maybe conclude something.
  6. Mar 24, 2025 at 12:46 PM
    grayscale
    DFW
    @snivilous
    Found something odd. I was reading through the manual looking at the fuel pressure testing and parameters and it occurred to me my fuel pressure should be higher than 40psi. I totally forgot I put in a separate relay and wired the pump power directly. Also odd that with the key in the on position (engine off) I get no pressure on the gauge. So I went and grounded the VSV relay to see if that changed it and cranked the engine but still only got 40psi. The only thing I didn't do when I replaced the pump was take out the fuel pressure switching valve assembly. Not sure it's the source of my issue since I do get 40psi, but still very strange.
    But maybe none of that matters now cause since I installed that pressure gauge the engine sounds like this when I try to crank it -
    https://youtube.com/shorts/uEkXyieZSYA?si=qKRf8MEn3krbqfyS
  7. Mar 25, 2025 at 10:37 AM
    grayscale
    DFW
    Does anyone have any idea why it sounds like that? I hadn't done anything to it before that point, and now it sounds like something is terribly wrong. Negative battery terminal gets pretty hot while trying to crank it as well. If it's the starter I'm gonna lose it, I've already changed it twice cause of this issue
    Edit, got it to start. Pulled it into the garage, it was idling there for 15-20 mins. When I hopped back in the seat the temp gauge was was all the way up. ? Maybe I should be suspecting a bad head gasket?
  8. Mar 25, 2025 at 11:30 AM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    JBA Longtubes, Snivs 2.0 SC pulley, ASP crank overdrive pulley 6.71 in, DD Full 3inch dual exhaust, IPT valve body, Airbox mod, 4.5inch intake, Denso 750, 450 Walbro, W/M injection, GM 95mm TB, SABM, Camburg UCA, Icon shocks, Speedmaster LSD, Motive 5.29 Gears, Mickey Thompson Baja Legend EXP 35's, Solid Offroad engine and transmission mounts, DIY Traction Bars, Tuning by Snivspeedshop.com
    What l is the ignition source for the fuel pump relay? Ignition fuse? Pump positive blue wire? The fuel module only sends power when cranking, if using that blue wire. Red from fuel module is neg, blue pos. Not sure if an extra wire for ffv.
    Your neg wire should not be getting hot.
  9. Mar 25, 2025 at 3:09 PM
    grayscale
    DFW
    10A IGN fuse under the hood drives the fuel pump relay. Don't recall the wire colors down below. I think the negative block is heating up from the starter going out
  10. Mar 26, 2025 at 11:40 AM
    grayscale
    DFW
    I ran through live data and anything else I could find on my scan tool (https://www.amazon.com/dp/B0CJ32MTHC) and the only thing I saw concerning the maf was air volume, nothing that appeared to show me voltages unfortunately. I'm going to start pulling all the plugs to check the spark and then do compression in a little while, hopefully the starter will hold out till that's done.
    snivilous[QUOTED] likes this.
  11. Mar 28, 2025 at 8:02 AM
    grayscale
    DFW
    Well here it is, cold compression of course. I expected odd numbers from bank 1 since the misfires were usually on 3 and 5, but I didn't expect bank 2.
    Bank 1 Bank 2
    1 - 126 2 - 100
    3 - 100 4 - 110
    5 - 149 6 - 117
    7 - 154 8 - 132
    I guess it's time to pull the valve covers and see what's gone wrong in there
    Almost forgot, I checked all the packs and plugs for spark, they all looked about the same, nothing abnormal.
  12. Mar 28, 2025 at 8:30 AM
    snivilous
    SW UT
    That amount of variation is definitely concerning. Ideally those numbers would be in a ~10psi spread, 5 and 7 being very high and then 3 being 50psi lower is very weird. Bank 2 spread is a bit more acceptable, still weird how much higher #8 is. For reference last time I checked my Tundra (probably at 260k at the time) it was around 120-130psi I want to say across the board, I think the biggest difference was like 15psi.
    You could do a leak down test before you pull the valve covers, would narrow down where you're losing compression. And to be clear, those numbers aren't particularly bad in and of themselves, it's the spread that's concerning.
  13. Mar 28, 2025 at 8:53 AM
    grayscale
    DFW
    Yeah I didn't think much at first till I saw 5 and 7. :(
    Let me see what I can do about a leakdown. Is there any good trick to knowing when it's at tdc on compression stroke? or should I just use a balloon
  14. Mar 28, 2025 at 10:56 AM
    snivilous
    SW UT
    Never done one on the 5.7 so not sure, usually I just stick a piece of wire in the spark plug hole and watch it move.
    If the engine is just funky and has odd compression and nothing else is wrong and that's what's causing all your issues, I'd have a hard time doing much about it and just accept it'll be hard to start sometimes.
  15. Mar 28, 2025 at 11:04 AM
    grayscale
    DFW
    Well if it is just funky I'd be getting air through the crankcase right? Surely the odds of that must be astronomical though. And if it is that then it's not worth keeping on with, this is the 3rd starter I've had to put in it in the last 18 months.
  16. Mar 28, 2025 at 11:11 AM
    snivilous
    SW UT
    That or valves aren't sealing well. Even with the hard start I'm surprised the starter would have that much issue.
  17. Mar 28, 2025 at 11:25 AM
    grayscale
    DFW
    Yeah it just burns em up, but sometimes it can take a while to get it started, sometimes it just refuses.
    On another note, I don't seem to have a long enough wrench to get to the crankshaft nut, looks like a 22mm but can't be sure -.-
  18. Mar 28, 2025 at 11:39 AM
    Vizsla
    Vizsla 2 = 2.5
    You can pour a little oil through the spark plug holes on the low compression cylinders and check again. If it doesn’t help the piston rings/cylinder bore are likely damaged/worn out, if it does look for valve/gasket issues. IIRC compression on a warmed-up engine with throttle wide open is a minimum of 145 psi..
  19. Mar 28, 2025 at 11:45 AM
    #49
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    I was just going to post about the compression readings veing real low. 189 psi normal, minimum 145psi with a 15psi variation between cylinders.
    Vizsla[QUOTED] likes this.
  20. Mar 28, 2025 at 3:25 PM
    #50
    grayscale
    DFW
    Yeah I knew with a cold test things would be odd, but with how hard its been to start and the starter crapping out it was really the only option, and the differences are really the most important bit. Hopefully the leak down test will help paint a slightly different picture, if not more than slightly hopefully. I just have a hard time believing it's all gone tits up at 178k miles
  21. Mar 31, 2025 at 9:52 AM
    #51
    grayscale
    DFW
    @snivilous
    Leak down test complete, all cylinders passed. 5 of them were nearly perfect, cylinders 1, 2, 4 didn't test as tight as the others but still well within acceptable range.
    I took pictures of all of them if anyone is curious about the actual results.
    snivilous likes this.
  22. Mar 31, 2025 at 12:39 PM
    #52
    SBGibson
    SBGibson New Member
    2011 Tundra 4 wheel drive
    With the weird cranking in cold weather and all,,just noodling mind ya,,Temp sensor on the raged edge from going south. Had that happen once and gave it a go and worked for me. Cheap fix , if it is the fix.
  23. Mar 31, 2025 at 12:40 PM
    #53
    grayscale
    DFW
    Thanks, that was one of the first things I tried for the same reason, it was cheap! But alas it wasn't it
  24. Mar 31, 2025 at 3:30 PM
    #54
    grayscale
    DFW
    I'm still wondering if I have dropped an intake rocker. I've seen several incidents of it and it wouldn't show up in a leak down (if my logic is correct). I wonder if I could do a reverse leak down to test for it. Like set the cylinders to the intake stroke and see if any of them don't leak. That would tell me the intake valve isn't opening right? Though it still wouldn't explain why it runs fine once it is started.
  25. Apr 1, 2025 at 8:34 AM
    #55
    grayscale
    DFW
    How is idle air controlled on this engine?
  26. Apr 1, 2025 at 8:40 AM
    #56
    snivilous
    SW UT
    It's all through the throttle body and being electronically controlled. There's nothing besides the butterfly valve doing its thing.
  27. Apr 5, 2025 at 3:24 PM
    #57
    grayscale
    DFW
    First let me say thank you to @snivilous for your direction and to @Mdl for your helpful questions.
    When I made my last post I had left the truck as it was when I finished the leak down test. I pulled off the TB just to make sure nothing was awry, wiped some grease off of it, and put it back. I figured at this point I would put the rest of it back together and put the new starter in and see if I could get to throw some codes or do something to give me another hint. When I was done I went to start the truck and lo and behold it started right up with no issue at all. The only thing I did before (intentionally) was put the plugs and packs from bank 1 on bank 2, and vice versa.
    I hadn't said anything till now cause I wasn't sure if it was just a fluke and I didn't want to jinx it. But 5 days later now and it's starting and running perfectly, startup even sounds different than it did, it sounds healthy now. I don't really believe the issue is fixed cause theoretically if it was the plugs and/or packs the problem should have just moved to the other side. But I'll take what I can get at this point, cause I really don't like using the parts cannon to solve things. I was so happy that day though that I immediately started ripping the dash out to replace the stupid hvac box and I got that all buttoned back up yesterday and I now have heat and AC again along with a cooperative engine.
    Thanks again for your time and knowledge. I wish I could give you a definitive solution to it but I suppose I can't have it all :cheers:
    Tunrod likes this.
  28. Apr 25, 2025 at 11:49 AM
    #58
    grayscale
    DFW
    @snivilous
    Well it was fun while it lasted but now its back. Not as troublesome as before, it only takes at most 5-6 tries to get it chugging and then a stab at the pedal helps it along. I've gotten it to throw codes a couple of times but they're only random misfire codes with no consistency.
    I've eliminated the MAF possibility by replacing it. I've no specific reason to suspect it, I just did because I really feel like this has to an air or spark issue considering how rich the exhaust always is on startup. But at the same time I don't have any specific info to fault the coil packs for either. For a second I thought maybe SAIS because of the exhaust but it seems the SAIS wouldn't cause starting issues as it comes in downstream.
    So at this point I'm still stumped with no leads and firing the parts cannon at it is still too expensive without better direction.
  29. Jun 7, 2025 at 9:38 PM
    #59
    j_supra
    j_supra Dreamin about boooost!
    Manitoba, Canada
    2008 Tundra Limited
    20" Vision brawl, 33.5" Toyo at3s, Bilstein 5100s, LTH, custom exhaust, AEM filter, TRD intake pipe, Joying HU, hertz components and sub, Rokblokz XL, AVS visors
    It seems like the the hard starting and funny cranking is due to flooding. Cylinders have lots of fuel and hard to compress and plugs are wet so it won't fire. Probably only fires if it can clear itself out enough to ignite and then smokes lots clearing the rest out. Oil probably smells like gas. But why is it flooding. Almost as though it doesn't spark at first but still sprays fuel. Would be interesting to see what the plugs look like right after that first no start attempt. Also be cool to test for spark on that very first start attempt to somehow pinpoin or narrow down if it's sparking initially or not. Just some crazy thoughts I had.
    Did you ever get your original injectors flow tested and cleaned? That's the best way to service injectors. Replacing with remans or aftermarket is a crap shoot.
    Also super random but is your air filter or bottom of air box wet or dirty?
    Mdl likes this.
  30. Jun 8, 2025 at 8:31 AM
    #60
    grayscale
    DFW
    Great thoughts, thank you for the input - no on the injectors, no on the air box. Once, many months ago, I did pull the no.1 plug after 1 try and it was damp, but not soaked.
    Something is very wrong here though with this design. In another thread @AZBoatHauler alerted me to what seems to be a widespread issue involving the Fuel Pump Control module (89570-34060) more so for aging 2nd gens. They seem to randomly fail or partially fail causing this very type of issue. Taking the module out and bypassing it seems to have resolved the issue about 80% for me. I still get a bit of a blurb at start, maybe a few tries, but it no longer takes forever to get going. It's odd though because this wacky device has something to with regulating the pump pressure in concert with the VSV, but it's not necessarily pressure creating the problem but rather something else. Anyhoo, there's more on it here. When I have some more time I have numerous pics and things to add to that thread. Somehow in over a year of dealing with this issue and all the digging I've done here I never crossed this path, though I'm glad I finally did, and I'd like to make it more visible to others who will inevitably encounter the problem.
    AZBoatHauler likes this.
