Revving at cold startup
Discussion in '2.5 Gen Tundras (2014-2021)' started by Tondra, Nov 12, 2017.
  1. Nov 12, 2017 at 12:41 AM
    Tondra
    Tondra [OP] New Member
    2018 Magnetic Gray Metallic SR5
    I just installed the Flowmaster Outlaw Exhaust in my new Tundra. I got a little excited and gave it a couple of short revs at a cold start. My dad said I shouldn't do that because it's not good for the engine. A couple of short revs shouldn't harm my engine right?
  2. Nov 12, 2017 at 1:51 AM
    tye
    tye New Member
    tye
    2016 TRD Pro DC
    Diamondback cover, flowmaster exhaust, n-fab sliders
    No harm to be done. The oil is pumping as soon as you turn the engine over.
    I have the same exhaust & love it.
    If you owned a Dodge, however, it would fall apart immediately. Does Dad own a Dodge?
    zcarpenter92, T500, TundraTss and 6 others like this.
  3. Nov 12, 2017 at 2:33 AM
    Tondra
    Lol he drives an Ford F-150.
  4. Nov 12, 2017 at 4:09 AM
    CM-LENNY
    CM-LENNY No Complaints
    San Diego, CA
    2015 4x4 CrewMax SR5
    PRO shocks, 37's Nitto G2's 4:88 diffs, few other mods
    I would follow pops advice. I've always been a fan of this start up procedure: No need to let the truck sit and idle, just go easy on the throttle for the 1st mile or so as the engine warms. I have done this my whole life and had great success. Hopes this helps.
    rjbiii, 14burrito, Black Wolf and 4 others like this.
  5. Nov 12, 2017 at 8:03 AM
    040Tundra
    040Tundra Teddy 2013-2019
    Aaron
    Las Vegas, NV
    040 '16 CM LTD 4x4
    I've always liked to get into a truck that the engine has been warmed up when it's cold outside. I agree with @CM-LENNY but since I've got a viper alarm/remote start, I use it daily. Just because I can!
    speckmon, T500 and Sunnier like this.
  6. Nov 12, 2017 at 8:10 AM
    tmart
    tmart New Member
    Travis
    I don’t drive mine until the rpms drop to normal and the engine is a little warm. Just me, I like to be on the safe side
    TundraTss and 14burrito like this.
  7. Nov 12, 2017 at 8:19 AM
    airgunner
    airgunner New Member
    N-KY
    2015 DC MGM TRD
    Sure, the oil is pumping from the start but the oil is still cold and in turn thicker which is not a good thing.
    Will you blow the engine up doing it? No, not unless you did that every morning for years but it's still not a great idea. Better to let it warm up a little first. Just my $.02
  8. Nov 12, 2017 at 8:44 AM
    Samoan Thor
    Samoan Thor God is technically an alien
    Limited 2014 crewmax 4X4
    Kings F&R, no sway bars
    This is one of those questions that is like the cold air intake debate where people say it offers gains and some say no, there are people who as soon as they start their cars the first time of that day they drive it immediately then theres some that wait a few minutes. I wait at least for the rpm's to drop then drive off keeping it below 2k rpm's until it has reached normal operating temperatures, I think of it as when you first start it all the fluids in the truck has to have enough time to reach their destination. It will be an argument, people have drove off and never had problems and people have warmed it up for a few minutes and never had problems, go with whatever has more input on, naw mean?!.
    zcarpenter92 and TheBeast like this.
  9. Nov 12, 2017 at 8:53 AM
    I always let mine warm up a little.
    14burrito likes this.
  10. Nov 12, 2017 at 9:35 AM
    Tondra
    Thanks guys I will definitely take you guys advice and yes specially my dad. Since I only did it once for the first time and not on planning doing it anymore. My engine should be fine right? I mean I didn't cause any permanent damage. Sorry if I'm a little bit paranoid. Ok I admit I have OCD.
    rjbiii, Prostar 190 and TheBeast like this.
  11. Nov 12, 2017 at 9:39 AM
    tmart
    tmart New Member
    Travis
    It’s fine bro dont worry
  12. Nov 12, 2017 at 10:02 AM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    Just say “yes sir” to your dad and never do it again in front of him. But I’m sure you’ll be okay doing it when he’s not around. ;)
    TundraTss, Black Wolf and TheBeast like this.
  13. Nov 12, 2017 at 2:45 PM
    14burrito
    14burrito IG @14burrito
    2014 SR5 CM 4x4 5.7
    Personally, I wait until its off high idle then drive off. No heavy accel, just normal light throttle driving.
  14. Nov 12, 2017 at 3:00 PM
    Jim the Jarhead
    Jim the Jarhead New Member
    2017 SR5 4X4
    If you live in the snow belt, i.e. Midwest, and let it idle more than two minutes, wasting gas imho. I drive 25 miles to work, it has to get to a certain temp to go into o/D (6th). That is two miles down a 55mph road from my house it finally goes into 6th. I can't wait when it's -20f (it will take more for sure to go into o/d), sitting in driveway does no good after the fan figures it' self out. Get up and go! 2 cents.
  15. Nov 12, 2017 at 4:07 PM
    TundraTss
    TundraTss The Mistress
    Brandon
    2019 TRD SR5
    Everything. Literally.
    JRPro likes this.
  16. Nov 12, 2017 at 9:24 PM
    71_340
    71_340 The German
    Hans
    FLW, MO
    It will actually go into 6th gear regardless of engine temperature; usually at 45 mph at light throttle. However, the torque convertor will not go into lock up mode until your engine is warmed up some and allows the ECM to switch over to closed loop operation. The lock up function will lower your RPM some and sometimes feel like another gear shift.
    As far as revving the engine when first started is probably not the best practice because it does take a few seconds for the oil to completely circulate and reach every moving part.
  17. Nov 12, 2017 at 9:27 PM
    speckmon
    speckmon Must. Have. Pow.
    Thornton, CO
    '07 mountain road bomber
    Let it warm up. Remote start FTW
  18. Nov 13, 2017 at 4:43 PM
    Judester714
    Judester714 New Member
    Jude
    2015 TRD Off Road SR5
    Flowmaster Outlaw dual exhaust
    I just got the outlaw as well, love the sound! (wife hates it... ) but are you noticing a drop in power by any chance? or is it just me...
  19. Nov 13, 2017 at 5:17 PM
    Tondra
    No I don't notice it at all.
    Yeah wife hates it too, she wants me to put the stock back.
  20. Nov 13, 2017 at 6:51 PM
    Judester714
    Jude
    but i love it, i see a drop in my MPG because of over-pressing the damn gas pedal. but who cares right?! i was thinking however of putting in some sound deadening material to see if that helps... plus that'll help with the sound system sounding better as well... thanks for the reply! that was my first post!
