reverse lights
Discussion in '1st Gen Tundras (2000-2006)' started by daveyc, Jun 15, 2024.
  1. Jun 15, 2024 at 7:33 PM
    daveyc
    daveyc [OP] New Member
    2004 4.7 limited 350k _no reverse lights--which fuse or any ideas?
  2. Jun 15, 2024 at 7:55 PM
    shifty` In South Dakota Trouble ain't hard to find
    Check to see if anyone spliced in a 4-pin harness out back. If so, look at the point they spliced it, check for wiring damage/rot. It’s a super common source of rear lights failing to work.
    But of course, “new to you truck”, now is the time to check EVERY fuse in the dash. And if you haven’t read THIS THREAD yet, it’s time to get off your ass! Pay attention to the water leak section. Just in case it’s not trailer wiring bullshit like others found, and it’s it’s not a burnt or missing bulb, and it’s not a fuse, there may be other stuff afoot.
