Reverse lighting
Discussion in 'Lighting' started by Eclipsed & Floating, Nov 2, 2017.
  1. Nov 2, 2017 at 8:42 PM
    #61
    Eclipsed & Floating
    Eclipsed & Floating [OP] Over it.........
    I’m right where I need to be
    Voluptuous Whitey
    my thoughts exactly! i went with the squadron sports and i'm going to mount them on my bed rack like Mark did. I want them up and out of the way, but not above the rack like i've seen some guys do. You'll see what i end up doing, it'll be a little different than Mark (maybe not).
    dcsleeper408 likes this.
  2. Nov 2, 2017 at 9:04 PM
    #62
    BlueBottle
    BlueBottle not a PRO
    '16 Platinum 4x4
    See fine print
    Those will be sweet. I really want some squadrons flush mounted to my rear bumper caps.. one day I will tackle that.
    In the mean time heres some eye candy! https://www.tundras.com/threads/review-diy-guide-baja-designs-rtl-m.18083/#post-403297
  3. Nov 3, 2017 at 8:27 AM
    #63
    Baja Designs
    Baja Designs The Scientist of Lighting Vendor
    Bill
    San Marcos, CA
    4x4_Angel[QUOTED] likes this.
  4. Nov 3, 2017 at 8:29 AM
    #64
    Baja Designs
    Bill
    San Marcos, CA
    Happy to help! Post up some pictures once you get everything installed.
    -Bailey, Baja Designs
    www.bajadesigns.com
    Enter BDForums at checkout for 10% OFF + $5 shipping to the Lower 48!
  5. Nov 3, 2017 at 9:05 AM
    #65
    AlexWV
    AlexWV Trophy Husband
    Alex
    WV
    2014 White SR5 TRD CrewMax
    ARE CX Series shell Rhino Rack cargo basket Leveling Kit 35x12.5 Thunderer TracGrip tires Rough Country 30" light bar
    Any other pictures of the lights and how they look at night? Are they these cree led 8 inch lights? http://www.roughcountry.com/8in-led-light-bar-70718bl.html
  6. Nov 3, 2017 at 10:38 AM
    #66
    Baja Designs
    Bill
    San Marcos, CA
    I wanted to follow up with a little bit more information on the recommended lights. For bumper mounted reverse applications the Wide Cornering pattern offers the most usable light. If these are mounted to a roof rack or bedrack the Work/Scene pattern offers more usable light. Please keep this in mind when ordering. Thanks everyone!
    www.bajadesigns.com
  7. Nov 3, 2017 at 11:10 AM
    #67
    Eclipsed & Floating
    Voluptuous Whitey
    Thanks to Bailey for clearing this up for me and pointing me in the right direction.
    FYI....he sent me a message, called, and emailed me to gain approval to fix my order rather than leave me stranded with inappropriate lighting prior to announcing this. True professionalism!!!!!!
  8. Nov 3, 2017 at 11:15 AM
    #68
    smslavin
    smslavin New Member
    Hudson Valley
    2016 Tundra CrewMax SR5
    Some stuff
    bailey's a good kid. always has been.
  9. Nov 9, 2017 at 5:44 AM
    #69
    AlexWV
    Alex
    WV
    I know this wouldn't work for your application, since it would hang too low for off roading, but does anyone have a hitch-mounted LED to help with reverse lighting?
  10. Nov 9, 2017 at 7:16 AM
    #70
    Eclipsed & Floating
    Voluptuous Whitey
    @ubserved posted something similar in this thread. My problem has already been solved, bud. Thanks for chiming in
  11. Nov 9, 2017 at 8:22 AM
    #71
    AlexWV
    Alex
    WV
    Oh, I know you decided on the Baja Designs lights. I was just asking in this thread since it was about reverse lighting. I was just curious if anyone was running anything here that just hooked into the hitch without having to attach to the bumper. Also didn't know if they made a type that would hook into the trailer harness without having to cut into the wiring.
  12. Nov 9, 2017 at 8:49 AM
    #72
    Eclipsed & Floating
    Voluptuous Whitey
    Oh, gotcha. Yes, there is a way to plug in but I don't know where I saw it. There is also a wrap around the hutch mount that I saw on Amazon. Maybe start there. I'm sure you'll find it
    BlueBottle likes this.
  13. Nov 9, 2017 at 8:50 AM
    #73
    BlueBottle
    '16 Platinum 4x4
    See fine print
    Here you go buddie. Plug and play.
  14. Nov 9, 2017 at 9:00 AM
    #74
    Eclipsed & Floating
    Voluptuous Whitey
    Yeah, yeah, yeah!!! This is your answer to tapping in.
    For the wrap around hitch mount I was talking about this would compliment it perfectly.
    BlueBottle[QUOTED] likes this.
  15. Nov 9, 2017 at 9:01 AM
    #75
    AlexWV
    Alex
    WV
  16. Nov 9, 2017 at 9:06 AM
    #76
    Eclipsed & Floating
    Voluptuous Whitey
  17. Nov 9, 2017 at 9:11 AM
    #77
    AlexWV
    Alex
    WV
  18. Nov 9, 2017 at 9:14 AM
    #78
    AlexWV
    Alex
    WV
  19. Nov 9, 2017 at 10:37 AM
    #79
    BlueBottle
    '16 Platinum 4x4
    See fine print
    If you looked at the thread I sent you I wired it up so it’s plug and play.
    geno0506 and NewImprovedRon like this.
  20. Nov 9, 2017 at 10:53 AM
    #80
    Stumpjumper
    Stumpjumper Not a new member
    Fate, Tx
    2017 Tundra TSS 4x4
    I did something similar but a whole lot cheaper and installed myself. I used low profile 4" single row LEDs. I wired in to reverse light circuit. With LEDs in the cargo light I have all the light I need behind the truck. If I really need the reverse lights on I can engage the parking brake and with key on but without motor running put shifter in reverse. I have LEDs in the taillight and they are ok but do not meet my needs for backup lighting.
  21. Nov 9, 2017 at 10:57 AM
    #81
    Stumpjumper
    Fate, Tx
    2017 Tundra TSS 4x4
    Not sure why you couldn't just use an inline splice? That is what I did when I hooked up my single row LEDs under the bumper.
  22. Nov 9, 2017 at 11:11 AM
    #82
    AlexWV
    Alex
    WV
    Ok thanks! I'll give it a full read when I get the chance.
  23. Nov 9, 2017 at 11:17 AM
    #83
    AlexWV
    Alex
    WV
  24. Nov 9, 2017 at 11:19 AM
    #84
    smslavin
    smslavin New Member
    Hudson Valley
    Some stuff
    he needs no apologies
  25. Nov 9, 2017 at 11:22 AM
    #85
    AlexWV
    Alex
    WV
    Well, I can read into his posts enough to tell he is extremely sarcastic. But I think I already irritated him asking questions in this thread after his problem was solved, so I don't want to push my luck.:boink:
  26. Nov 9, 2017 at 11:24 AM
    #86
    smslavin
    smslavin New Member
    Hudson Valley
    Some stuff
    Understatement of the year :rofl: :thumbsup:
    Keep pushing. He likes it.
  27. Nov 9, 2017 at 11:26 AM
    #87
    Eclipsed & Floating
    Voluptuous Whitey
    Dude!!!! I appreciate the complement "extremely sarcastic"
    You didn't irritate me...trust me. If you did I'd drop some super threatening hammers on you like I do on @smslavin on the regular. He wears a hard hat.. .oh wait, maybe he needs that cuz he rides the short bus
    RICKSTUNDRA, BlueBottle and smslavin like this.
  28. Nov 9, 2017 at 11:27 AM
    #88
    Eclipsed & Floating
    Voluptuous Whitey
    ^^^THIS
    My boy's light bulb just lit up apparently
    smslavin[QUOTED] likes this.
  29. Nov 9, 2017 at 11:32 AM
    #89
    smslavin
    smslavin New Member
    Hudson Valley
    Some stuff
    Story of my life
  30. Nov 9, 2017 at 11:44 AM
    #90
    AlexWV
    Alex
    WV
    Any pictures of your setup?
