Reverse Light Brightness?
Discussion in 'Lighting' started by niru316, Apr 12, 2017.
  1. Apr 12, 2017 at 8:17 PM
    niru316
    niru316 [OP] New Member
    2017 Tundra TRD Pro CrewMax
    So I was watching a video on youtube about LED Reverse lights on stock tail lights. And wowza huge difference of coarse... but what about your aftermaket tail lights? (Anzo/WinJen) How bright is the Reverse light on those? or would you replace the reverse light in those with a LED right away?
    Thanks in advanced!
    Niru
  2. Apr 12, 2017 at 8:46 PM
    duece292
    duece292 Appalachian American
    Greg
    Green Bay, WI
    Most aftermarket taillights have the same lens and reflector as the stock taillights and regardless of whether the brake/tail/turn portion is LED or not, the reverse is still just a standard bulb. I swapped the stock 921's for LED in mine and would do the same on aftermarket taillights too...much brighter. They do make the backup camera appear a little grainy at night though.
    niru316[OP] likes this.
  3. Apr 12, 2017 at 8:49 PM
    Eclipsed & Floating
    I’m right where I need to be
    Voluptuous Whitey
    Which LEDs did you put back tgere?
  4. Apr 12, 2017 at 8:51 PM
    niru316
    Ah okay, wasnt sure if aftermarket tail lights used the same bulb as OEM. I KINDA expected the Lens and reflector to be the same but was never too sure. Kinda stinks to hear that the LED can make the backup camera a little grainy at night... that was primarily the biggest reason I wanted the brighter reverse lights. Thanks for the reply @duece292
  5. Apr 12, 2017 at 9:05 PM
    duece292
    Greg
    Green Bay, WI
    I put in Putco Plasma 360's. I love 'em, they're crazy bright. As far as the grainy backup camera, its not terrible. I think some of that comes from the LED license plate lights in combination with the reverse lights. The graininess is a small tradeoff for a big amount of light, especially when I'm backing into my garage.
  6. Apr 12, 2017 at 9:06 PM
    niru316
    Welp guess that answer that =) Will be replacing mine with LEDs
  7. Apr 19, 2017 at 6:30 PM
    Juanjoolio007
    Juanjoolio007 New Member
    Oregon
    24 Blueprint Sequoia Platinum / 23 Tesla MYP
    I have some GTR lighting for reverse lights and VLEDS for license plate lights.... i found that if i turn the headlights off the graininess goes away. However, it is still a bit grey. I only do that when i am backing into my driveway so i don't shine my headlights in the neighbors houses at 4am.
    Edited to correct headlights to off. This morning I realized I was turning them all the way off.
