Reverse Aux Lighting
Discussion in 'Lighting' started by dumbassdave, Mar 5, 2019.
  1. Mar 5, 2019 at 8:42 AM
    dumbassdave
    dumbassdave [OP] Member
    Dave
    2016 Crewmax Limited
    I wanted to get some hidden auxiliary reverse lights. I've done in-bumper lighting before, just didn't want that on my new truck. I went with lights on that flat strip between the bumper and the tailgate.
    I bought these lights on Amazon. Initial impression is that they are a quality light. Good solid metal casing on them.
    SpeedTech Lights Micro Carbine Surface Mount LED Spotlight - Clear
    https://www.amazon.com/gp/product/B07C52SLGV/ref=ppx_yo_dt_b_asin_title_o00_s00?ie=UTF8&psc=1
    I didn't use the rubber backing that came with the lights. Just one layer of electrical tape so that it wasn't metal on metal between the lights and truck.
    Just for reference and comparison, I replaced the stock reverse lights with Zevo LED reverse lights.
    15whtrd, Trooper2 and Mountun Goat like this.
  2. Mar 5, 2019 at 10:54 AM
    Check out the LPR from VLeds.
    nlaroy and Prostar 190 like this.
  3. Mar 5, 2019 at 11:16 AM
    dumbassdave
    Dave
    I saw that one, its pretty sweet. With my luck some dick would break something on my truck while stealing it.
    Chili1 likes this.
  4. Mar 5, 2019 at 11:27 AM
    Trooper2
    JR
    Houston, TX (Suburban South)
    Some more reverse lights for sure! Were you able to leave tailgate and/or bumper on to install?
  5. Mar 5, 2019 at 11:32 AM
    dumbassdave
    Dave
    Yeah, everything was left on. Didn't even have to drop the spare. I doubt that I would have gone for this if I had to take off the bumper. I'd say it would be best to leave the tailgate on so that you can set the height of the lights in the gap properly and also use it as a straight line to make sure that the lights are installed level.
  6. Mar 6, 2019 at 8:57 AM
    ncorry
    ncorry New Member
    Nic
    Little Rock, AR
    2019 CM SR5 TSS
    Hey dumbassdave, is that a one pack or a pair for the Amazon link you provided?
  7. Mar 6, 2019 at 9:00 AM
    dumbassdave
    Dave
    One pack. Seem to be quality though. Much better than the first ones that I tried out.
  8. Mar 6, 2019 at 9:10 AM
    dumbassdave
    Dave
    Now that is some reverse lighting!!!!
  9. Mar 6, 2019 at 9:16 AM
  10. Mar 6, 2019 at 9:30 AM
    dumbassdave
    Dave
    Thats awesome! Does it wash out the picture for the back up camera?
    Prostar 190 likes this.
  11. Mar 6, 2019 at 9:33 AM
    No seems to work well.
  12. May 14, 2019 at 7:51 PM
    ND_Porkchop
    ND_Porkchop New Member
    2008 Tundra 5.7 CM DSM
    @dumbassdave is it a noticeable difference from stock lights?
    I'm considering cutting a flush mount 2" cube into the rear bumper beside the plate. But I like how low profile this option is.
  13. May 14, 2019 at 7:54 PM
    Mountun Goat
    Mountun Goat She baaaaaahd
    EhBerta, Canadia
    It’s a Goat.
    I really need to make some time to wire mine up. This is such a great update.
  14. May 14, 2019 at 8:32 PM
    dumbassdave
    Dave
    It's quite a bit brighter. Absolutely noticeable. Not as bright as my flush mounts in my old tundra bumper though. Could always put in 4 of the lights I did?
  15. May 22, 2019 at 11:01 AM
    Stumpjumper
    Stumpjumper Not a new member
    Fate, Tx
    2017 Tundra TSS 4x4
    I am about to mount some flush mount in bumper. I am debating the fastening method. For the location I am using the inside 2 bolts won't be a problem but the outer ones are going to be tough to access. I am thinking I can glue the washer to the nut and use tape to hold the nut in a box end wrench. Problem is 3/8' wrenched are awfully short. Another idea is SS self tappers on all 4 or match the heads and use self tappers on one side and bolts on the other. Goal is to mount these lights without tearing down the bumper. I think it can be done with 4 bolts but might take some Aggie engineering.
    DesertRoads likes this.
  16. May 26, 2019 at 6:50 PM
    Stumpjumper
    Fate, Tx
    2017 Tundra TSS 4x4
    I ended up going in the plastic. Still tight and positioning has to be spot on. The little tab that holds the plastic to the metal gets in the way if not positioned properly. It is definitely a measure several times cut once kind of deal.
