Retro’s with switchbacks help
Discussion in 'Lighting' started by atxtundra, Feb 7, 2018.
  1. Feb 7, 2018 at 12:07 PM
    atxtundra
    atxtundra [OP] New Member
    I just installed some retros that I got from a forum member and everything is working great. My only issue is the switchbacks are only white when the headlights are on, and amber when the headlights are off or in the parking light position. Do I need to do the drl delete mod? I want to remove the amber halogen bulb altogether too so only the switchbacks are my turn signals. I need resistors right? Here’s how I have them wired. Thanks in advance!
  2. Feb 7, 2018 at 12:49 PM
    xtyfighterx
    xtyfighterx New Member
    Ty
    North Idaho
    2015 Black Crewmax Mid Travel
    You need to do the drl grey wire mod under the dash and it will work like it should.
    TRD15559 likes this.
  3. Feb 7, 2018 at 12:50 PM
    xtyfighterx
    Ty
    North Idaho
    remove your oem turn bulb and wire a resistor on and you will be good no hyper flash
  4. Feb 7, 2018 at 12:52 PM
    xtyfighterx
    Ty
    North Idaho
    What I did for wiring is on the switch back driver there’s three wires hot ground and signal. Signal went to my turn signal hot wire on the oem drl connector hot went to my ignition fuse and the ground went somewhere close. Snipped my grey wire to delete oem drl and wired resistors to oem turn signal bulb to delete that worked perfect.
  5. Feb 24, 2018 at 7:33 PM
    =57=
    =57= New Member
    Plano, TX
    2015 Black Tundra TSS Crewmax
    Interior/Exterior LEDs, Winjet smoke tail lights, BullyDog Tuner, painted 3rd brakelight, Retrofit projector headlights done by Eledobleu, TonnoPro Tri-Fold Tonneau Cover, BAM 8" exhaust, 35" Nitto Ridge Grapplers and 20" Fuel Assaults
    What resistor did you use? Any 3157/4157 found on ebay?
  6. Feb 25, 2018 at 8:03 AM
    atxtundra
  7. Feb 25, 2018 at 8:30 AM
    xtyfighterx
    Ty
    North Idaho
    Edit: like the guy above me posted.
    I don’t even remember 6 ohms ones I think idk lol just the cheap gold looking ones on eBay . I ran then for 3 years till now since I just went with the new 2018 sport lights. Never had problems
  8. Feb 26, 2018 at 11:39 AM
    =57=
    =57= New Member
    Plano, TX
    Thanks guys for the info
  9. Feb 26, 2018 at 3:47 PM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    What type of connectors are those? Do you like them better than the inline and t-tap connectors?
