Restored my headlights.
Discussion in 'Lighting' started by freerider8, Jul 4, 2017.
  1. Jul 4, 2017 at 5:51 PM
    freerider8
    freerider8 [OP] Trucks Rule
    Fairview PA
    2014 Tundra, Lift Kit aftermarket wheels and tires. One Badass Toy!!
    Fuel Wheels. Lift Kit. Duel Exhaust.
    So I purchased the 3M headlight restorer kit at the local auto parts store. I had tried to take care of them myself without spending any money on something that may or may not work. I tried a few home remedies if you will based of some videos on youtube but the results were only very temporary. I decided today to take the plunge and spend the 15.99 for this kit due to its simplicity and the brand 3M has been around for some time so I figured WTH?! So it is with pleasure that I tell you that the results were much better than expected. The passenger side light was worse than the driver's side, not sure why but they both turned out good. Still a slight difference in the two lights but much improved. If you this have the same issue with headlights then this is a good choice.
    Black Wolf and GNTundra like this.
  2. Jul 4, 2017 at 6:17 PM
    MotoTundra
    MotoTundra The Ocho
    Don
    I had a good experience with Megquiars kit on another vehicle.
    Nothing like clearing up that ugly haze!
  3. Jul 4, 2017 at 6:35 PM
    I used the 3M restorer kit. Worth the money for sure.
  4. Jul 4, 2017 at 8:03 PM
    Abrams65
    Abrams65 New Member
    Cliff
    WV
    16 Tundra MGM SR5 CM OR/15 Corolla S
    ICI Magnum RT Steps, 18' LED Foglights
    When I did my Tacoma a couple years back all I did was wet sand 400, 1000, 3000 with the drill polished with scratch/swirl remover and then applied wax and sealer never had anymore problems after. Just need to occasionally touch up the wax and sealer.
