Reset the gas tank
Discussion in '3rd Gen Tundras (2022+)' started by grizcoach, Jun 26, 2025 at 3:17 PM.
  1. Jun 26, 2025 at 3:17 PM
    grizcoach
    grizcoach [OP] New Member
    2025 Tundra Limited
    Someone posted how to reset your gas gauge. It had something to do with holding the ODO button down. I looked but couldn't find the post. Could someone repost the procedure? TIA
  2. Jun 26, 2025 at 3:58 PM
    Oldandfat
    Oldandfat New Member
    Cannuckastan
    2024 SR5 TRD Offroad Lunar Rock
    While in drive, turn off truck (keep foot on brake). Wait. Fuel gauge will “reset”.
    shift into park and restart. Or just leave in park and turn off.
  3. Jun 26, 2025 at 3:59 PM
    mrfreeman
    mrfreeman New Member
    Kenny
    Buffalo
    2024 Tundra SR5
    Reset when it’s stuck at full? While in drive and stopped, shut off the truck then put it in park.
  4. Jun 26, 2025 at 4:31 PM
    tweezy
    tweezy New Member
    PA
    2024 Blueprint Tundra 1794
    If you have the digital gauge
    With the truck running turn it in park
    Put the odo in odo mode not trip a or b
    Shut off truck
    Press and hold odo button
    While pressing the odo button press the push to start twice with your foot off the brake
    then the mileage flashed blinking it worked my fuel reset to correct level.
    let go of odo button
    Start up the truck and drive
    Literally just did this today and oh do this on level ground
    if you have the analog gauges it’s a different procedure
    more on this topic here: https://www.tundras.com/threads/2022-2024-fuel-tank-gauge-defaults-to-full.148892/page-2
  5. Jun 27, 2025 at 4:19 PM
    PNW Tundra Mike
    Southern Cal
    MX4 Tonneau, Talon's Trans/Cat Shield
    *Note - Truck should be level when resetting
