Reset Flex Fuel Alcohol/Ethanol Percentage Level with Bidirectional Scan Tool
Discussion in '2nd Gen Tundras (2007-2013)' started by lowercaseg, Apr 25, 2023.
  1. Dec 22, 2024 at 10:36 AM
    #181
    Gustavo
    Gustavo New Member
    Gustavo
    2015 Tundra SR5
    3” Lift. Bilstein shocks, SPC upper control arm, VLAND headlights
    I have the same issue with my 15 FF Tundra every winter. Easily fixed reseting it with Techstream.
    OldGuy03 likes this.
  2. Dec 22, 2024 at 3:05 PM
    #182
    BigTundra69
    BigTundra69 New Member
    Zach
    7” Readylift. 37x13.50 tires Full Exhaust
    Thank you sir. Currently having this same issue. Plugged up my cheap scan tool just to read the ETH content and it’s at 85%. I will buy the scan tool and do the same.
  3. Dec 22, 2024 at 4:14 PM
    #183
    kbahus
    kbahus New Member
    MI
    2015 MGM Tundra Limited Crewmax
    I have to admit, I am pretty happy with my inexpensive Launch Toyota model scan tool. It is a little slow and clunky, but for the price paid I can't complain. I was able to program a new key fob for my 08 Sequoia with it, I changed the door lock settings on my Camry, diagnosed and reset TPMS problems, and took care of the alcohol density relearn with my Tundra. It has certainly paid for itself in short order.
    Whizzit and OldGuy03 like this.
  4. Dec 23, 2024 at 3:47 PM
    #184
    BigTundra69
    Zach
    Has anyone done this with a snap on scanner. Trying to find it using mine. I currently have this issue.
  5. Dec 29, 2024 at 6:47 PM
    #185
    White Puff
    White Puff New Member
    Which scan tool are you referring to? I couldn't access the fuel reset with the Launch Creader tabletop my 2010 sequoia.
  6. Dec 30, 2024 at 12:35 PM
    #186
    kbahus
    kbahus New Member
    MI
    I have a Launch Creader Elite as well. Did you update yours?
  7. Dec 30, 2024 at 4:07 PM
    #187
    White Puff
    It's updated so I don't know if I'm doing something wrong or it's something with my Sequoia.
  8. Dec 30, 2024 at 4:14 PM
    #188
    AZBoatHauler
    So.Arizona
    Are you sure it’s a flex fuel model?
  9. Dec 30, 2024 at 5:46 PM
    #189
    kbahus
    kbahus New Member
    MI
    I will have to check mine, but it doesn't look like yours, mine is orange and a different screen. If I remember right there is a tab for "service function" that is where you need to go, it's within the engine ecm tab.
  10. Dec 30, 2024 at 8:42 PM
    #190
    White Puff
    The truck is.
  11. Dec 31, 2024 at 3:38 PM
    #191
    Stumpjumper
    Stumpjumper Not a new member
    Fate, Tx
    2017 Tundra TSS 4x4
    Anyone else using the TopDon Lite? Ebay has a coupon code good through 12/31.
  12. Jan 9, 2025 at 9:25 AM
    #192
    Jsm52
    Jsm52 New Member
    2019 Tundra TSS
    Has anyone tried the new Launch X431 CRP919E Lite version for the reset? Or is the Elite version the only one that works?
  13. Jan 18, 2025 at 10:42 AM
    #193
    Timberline
    Timberline New Member
    Colorado / South Dakota
    2016 Tundra DC TRD Limited ~ 2007 4Runner Sport ~ 2003 Tunda (sold)
    '19 TRD LED headlights, iHacker harness, RCI sliders, Tuffy Security console safe
    My '16 model has started doing this intermittently. I'm out of warranty and I'm not keen on the dealer keeping it for a few days to finally decide to reset it only to have the matter return and them keep it a few day to repeat the process. So I'm fine with getting a scanner and doing it myself. Glad to see there are numerous options to choose from for a scanner. My question is, which one is most "idiot proof" from a usability viewpoint? I don't care about the option to reprogram key fobs if that's a point of distinction.
  14. Jan 20, 2025 at 10:58 AM
    #194
    centex
    centex New Member
    I borrowed an xtool d7 from Amazon and went to scan the alcohol. Was reading the live data and the percentage was either 0 or flashed no table data constantly. When I went to look at it as a graph, I would see occasional spikes to 88%. Another interesting thing I saw was the fuel type was mainly showing ethanol but would occasionally flash gasoline or no table data. What’s up with the constant flashing of no table data and the fuel type showing as just ethanol? I noticed a lot of the parameters kept rapidly flashing between a value and no table data.
  15. Jan 20, 2025 at 11:23 AM
    #195
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Well, it ain't the tool because the creader elite tool I used had ethanol for fuel type too. I've had a mechanic try and play with the percentage to see how the truck would run and he couldn't get the ECU to accept the numbers he put in. A value would change but the "real" value stayed the same. Almost as if two tunes were running concurrently.
  16. Jan 21, 2025 at 11:17 AM
    #196
    Timwfm
    Timwfm New Member
    My 2016 started to having crank issue with this cold weather. I got the Launch scanner and was able to reset the alcohol density level (now it run fine). My buddy 2016 start to do the same. We reset the alcohol density but it would not hold. It continue with hard starting problem. So, we took it to the dealer with the TSB T-SB-0166-19 document. They wanted 1200 to flash the ECU. After a few minute of intense conversation, they decide to do it for free. Now the truck run fine. I am sure we will have to reset the alcohol level at some point again ( for both truck). If anyone in the central florida need help, I have the scanner and will help in resetting the value. Just message me.
  17. Jan 24, 2025 at 2:04 PM
    #197
    Timberline
    I bought the Launch Creader Elite T on Tuesday arrived today for $107 shipped. Updated it, plugged it in and my alcohol density was 85.1%. Reset it, checked to confirm 0 and cold started with gusto!
    Timwfm, centex, OldGuy03 and 2 others like this.
  18. Jan 24, 2025 at 2:57 PM
    #198
    OldGuy03
    Jay
    CO
    12 MGM DC RW
    Winning.
  19. Jan 25, 2025 at 5:14 PM
    #199
    pkelley36467
    pkelley36467 New Member
    Guess I need some help. I purchased the Launch CRP919X Lite and I have updated everything and have tried to reset my alcohol density but I am unable to find it. It does a VIN search and finds vehicle and i run diagnostics but I am unable to find any way to reset sensor. Any help would be GREATLY appreciated.
  20. Jan 25, 2025 at 6:25 PM
    #200
    kbahus
    kbahus New Member
    MI
    I don’t think that model supports it, or any service functions from what I can tell. I looked it up on Amazon and went to their site, for a 21 Tundra it only does some ABS stuff, that is it. The Launch I have is the Toyota specific model, yours seems to be a global obd2 model made to cover a wide range of vehicles. The special programing probably isn’t there for Toyota specifically. Do you have the link where you purchased yours from?
    Timwfm likes this.
  21. Jan 25, 2025 at 7:07 PM
    #201
    pkelley36467
  22. Jan 25, 2025 at 7:08 PM
    #202
    pkelley36467
    My truck is a 2017 5.7 flexfuel btw if that helps.
  23. Jan 26, 2025 at 6:01 PM
    #203
    kbahus
    kbahus New Member
    MI
    I would return it, I don’t see anywhere that it does anything useful with Toyota vehicles.
  24. Jan 28, 2025 at 1:17 PM
    #204
    Timwfm
    Timwfm New Member
    Do the update on the Launch
    Plug into Tundra (truck running)
    1 Select Intellegent Diagnose (detect vin)
    2 select Diagnostic
    3 select 16Pin DLC (North America)
    4 Select System Selection
    5 SL All system
    6 SL ECMECT
    7 SL Read Data Stream (verify Density level)
    8 SL special Function
    9 stop engine but Ignition on then select Fuel Density Reset
    10 Start engine and SL Read Data Stream (verify Density level is zero).
    Good Luck. Message me Fi you need further assistance. It work great for me and no smelli fume and better mileage
    RobertD likes this.
  25. Jan 28, 2025 at 1:18 PM
    #205
    Timwfm
    Timwfm New Member
    Link please
  26. Jan 28, 2025 at 1:43 PM
    #206
    Timwfm
    Timwfm New Member
  27. Jan 28, 2025 at 3:05 PM
    #207
    OldGuy03
    Jay
    CO
    12 MGM DC RW
    I think the cheapest option is eBay for the c reader elite.
    Timwfm[QUOTED] likes this.
  28. Jan 28, 2025 at 5:32 PM
    #208
    kbahus
    kbahus New Member
    MI
    I purchased my Elite model on Ebay.
    Timwfm likes this.
  29. Jan 30, 2025 at 11:23 AM
    #209
    kchupe
    kchupe New Member
    I purchased this same version from Amazon but have been unable to find the setting to reset the alcohol percentage. How did you find that function? I have only been able to access “live data stream” and relearn fuel density setting but that was it.
  30. Jan 30, 2025 at 11:39 AM
    #210
    AZBoatHauler
    So.Arizona
    Fuel density is what you want. That’s another term for alcohol %. Alcohol has a lower fuel density than gasoline.
