Reset Flex Fuel Alcohol/Ethanol Percentage Level with Bidirectional Scan Tool
Discussion in '2nd Gen Tundras (2007-2013)' started by lowercaseg, Apr 25, 2023.
  1. May 4, 2025 at 5:18 PM
    #331
    Zeke66
    Zeke66 New Member
    Recently picked up a 2017 FF Sequoia and didn't investigate this before. Now that I am looking the alcohol % is showing 75% and a long term fuel trim of -20%. No physical signs of issues though and the fuel economy actually seems better than it should be ~18.5, which shouldn't be the case right?
    Should I get a tool and reset it anyway?
  2. May 4, 2025 at 5:27 PM
    #332
    dt325ic
    dt325ic Member
    GA
    2019 TRD Sport
    If it were my truck, yes.
    When the alcohol percentage is that high, the fuel pump is working harder in flex fuel mode.
  3. May 4, 2025 at 5:34 PM
    #333
    Zeke66
    Zeke66 New Member
    Okay. I'll order one today.
    Any explanation for increased fuel economy? From what I read it should be the opposite?
  4. May 4, 2025 at 5:49 PM
    #334
    centex
    centex New Member
    I’d leave it alone. The fuel pump isn’t working any harder. All that’s happening is the computer has closed a valve and so now the pump is sending the full 60psi to the engine instead of bleeding off some pressure and only sending 43psi to the engine. No way I’d risk losing 18mpg. My truck was reading 85% when I scanned it but I had zero issues for three years. Now I did clear mine but noticed zero difference after doing so. If I had to do it all over again, I’d leave it alone.
    OldGuy03 likes this.
  5. May 4, 2025 at 8:35 PM
    #335
    Zeke66
    Zeke66 New Member
    Little confused with everything I've read. The ECM should be sending more fuel volume when it thinks its running e85 to compensate for energy density, but then the long term trim is reducing that number because it thinks it's running rich for e85. So is it basically running near normal anyways?
  6. May 8, 2025 at 8:41 AM
    #336
    ohsandy
    ohsandy New Member
    Thank you for the post... I'm considering the same purchase. I have the 2016 4x4TRD Pro 38 gal tank as well, and I'm on the hunt for a way to improve my fuel efficiency. Has doing the fuel density reset helped yours?
  7. May 8, 2025 at 10:09 AM
    #337
    RobertD
    Robert
    DFW, Texas
    It will only help if the sensors are not reading correctly.
    Tundra and fuel efficiency do not go together.... if you are really concerned about fuel consumption, really look if a truck fits your needs. Must folks using their truck as a truck daily are probably 12-15 mpg depending on load, set up, and traffic patterns
    AZBoatHauler likes this.
  8. May 8, 2025 at 10:53 AM
    #338
    AZBoatHauler
    So.Arizona
    I got 8.7mpg towing the side by side up to T2S - honestly I was expecting worse.
    RobertD[QUOTED] likes this.
  9. May 8, 2025 at 10:59 AM
    #339
    RobertD
    Robert
    DFW, Texas
    Well... towing was not addressed in my estimate :rofl:
    AZBoatHauler[QUOTED] likes this.
  10. May 8, 2025 at 11:02 AM
    #340
    AZBoatHauler
    So.Arizona
    Absolutely - just hammering home these motors don't sip they chug.
    ohsandy and RobertD[QUOTED] like this.
  11. May 8, 2025 at 12:10 PM
    #341
    RobertD
    Robert
    DFW, Texas
    Just like the owners
    :cheers:
  12. May 8, 2025 at 12:16 PM
    #342
    AZBoatHauler
    So.Arizona
    :spy:
  13. May 8, 2025 at 2:40 PM
    #343
    OldGuy03
    Jay
    CO
    12 MGM DC RW
    Well. @EmergencyMaximum is just going to be appalled by this. He easily could've hit somewhere in the 18mpg range with no ac. Maybe even more. :rofl:
  14. May 9, 2025 at 3:27 AM
    #344
    ohsandy
    ohsandy New Member
    well, I’m not even getting the 12-15 so I feel like something is off.
    And Btw, I sat myself down and had the “gas mileage talk” with myself and decided this was a “good with the bad” love affair HOWEVER, this doesn’t mean I won’t push my beast to do her best!
  15. May 9, 2025 at 3:29 AM
    #345
    ohsandy
    ohsandy New Member
    Happy Friday y’all!
    NewImprovedRon likes this.
  16. May 20, 2025 at 9:23 AM
    #346
    BluegrassRules
    BluegrassRules New Member
    Justin
    2017 TRD Pro white
    It helped for a while, but my fuel pump was on it's last leg and became a no start issue again, so I ended up replacing the fuel pump myself with a Delphi unit....the Denso through the dealers are on severe backorder, and I was able to get the Delphi through Rock Auto. It wasn't the easiest job to do, but it's running in tip top shape now. The fuel mileage has increased ever so slightly since the fuel/alcohol density reset and new pump. Went from 13-13.5 to about 15-15.5 mpg.
