Replacing Stereo
Discussion in '1st Gen Tundras (2000-2006)' started by JimboSlice413, Jun 30, 2020.
  1. Jun 30, 2020 at 8:02 PM
    JimboSlice413
    JimboSlice413 [OP] Super Nice Guy
    Bakersfield
    2016 Limited 4x4, 2003 Sequoia
    Bilstein 5100/5160 Toyo at2 295/70r18 Ray10 GunMetal
    Hey guys, I'm changing out the JBL head unit in my 2003 Sequoia. In respect to sound quality, I'm wondering if I should use the metro harness that retains factory amplifiers or simply pull new wire to the doors. Has anyone replaced their factory head unit and found that it sounded better powered out of the new unit as opposed to running through the preamp of the new unit and out the factory amps?
  2. Jul 2, 2020 at 10:46 AM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    Bump.
    JimboSlice413[OP] likes this.
  3. Jul 2, 2020 at 10:57 AM
    ZeRussian
    ZeRussian New Member
    ‘11 CrewMax
    Bypass the amp and use the amp in the aftermarket stereo. You also don’t need to run new speaker wire. Wires are already ran from the amp to the speakers.
    there are also 2 harnesses that can be used. One to retain factory amp and another to bypass the factory amp.
  4. Jul 4, 2020 at 2:26 PM
    JimboSlice413
    Bakersfield
    Thank you. I did bypass the amps. It sounds amazing. I would strongly recommend anyone looking at this does the same
