Replacing roof molding?
Discussion in '2nd Gen Tundras (2007-2013)' started by Cmaccullen, Apr 15, 2019.
  1. Aug 9, 2020 at 6:15 PM
    COTundra23
    COTundra23 New Member
  2. Aug 10, 2020 at 8:23 AM
    Failure2comply
    Failure2comply Master HVAC Tech
    VA
    2008 Tundra Crewmax Limited w/factory 20" wheels
    Trailer brake. Limousine tint in rear windows. Ultra Gauge "Blue". Toyota bed mat and bug deflector.
  3. Aug 10, 2020 at 10:31 AM
    TunaDr
    TunaDr New Member
    2007 Tundra
    I joined to see what is possible
    they have heavy duty 3m double sided tape rated for like 30lbs, you just need a little piece (1-1.5 inch) on each end. no need for messy caulking
  4. Sep 6, 2020 at 2:27 PM
    twuckman806
    twuckman806 New Member
    Scott
    2011 Black Doublecab Tundra SR5
    BFG TAs with Motometal chromes, cat back exhaust, Snugtop Supersport shell, custom carpet package, security system
    Can someone tell me how to safely remove and replace the roof drip molding on a 2011 Toyota Tundra double cab?
  5. Sep 6, 2020 at 3:33 PM
    TunaDr
    TunaDr New Member
    2007 Tundra
    its just double sided tape on both ends. front side has some hinge contraption with the double sided tape. you can refurbish your strips if they are in one piece. remove, wipe down with mr clean eraser and water few times. let completely dry. spray with some black trim and bumper paint. put on 3m heavy duty double sided tape on both ends and install front side first.
  6. Nov 8, 2020 at 7:32 PM
    Lilvan99
    Lilvan99 New Member
    16 Tundra SR5 CrewMax
    Does anyone know how these are installed? I know it’s not a laborious job, but I would like to install them correctly. I have the clips and I see the double sided tape one one end of the molding (which I’m sure goes towards the rear). I’ve looked into YouTube, but no luck there.
    Thanks in advance!
  7. Nov 8, 2020 at 8:16 PM
    TunaDr
    TunaDr New Member
    2007 Tundra
    clip in the front, run it back, peel double sided tape and press it onto the back. pretty straight forward, no tricks.
    GarTX526 likes this.
  8. Jan 22, 2021 at 6:34 AM
    purplenova
    purplenova Not a new member
    Tom
    Ohio
    2016 Tundra Crewmax SR5
    been having the same issue with the pass side blowing off, either driving on highway or blowers in the car wash.
    Havent taken my truck to the car wash in over a year and just 2 weeks ago i broke down and went thru.
    Same stuff - blew right off at the driers.
    Just bought some of this to reattach it.
  9. Jun 15, 2021 at 1:26 PM
    RalphKaz
    RalphKaz New Member
    @Roman
    The passenger side roof drip moulding is missing on my 2005 Double Cab Limited. I believe the two part numbers that I need are below - would anyone be able to confirm? Not sure if any kind of clips or anything else is needed... Also - any recommendations where to order these from? some initial searches show $65-75 just for the strip (seems quite high for a little piece of rubber)
    75551-0C040 (strip)
    75553-0C010 (cap)
    Thanks!
    MPG_LOL likes this.
  10. Mar 15, 2022 at 10:22 AM
    mike175gr
    mike175gr New Member
    Michael
    I also had my moulding blow off my 2017 Platinum Crewmax from a carwash. I just ordered the fill moulding set (front and rear both sides with extra clips) from Cool Springs Toyota. Thank you for the part number tips!
  11. Mar 15, 2022 at 9:30 PM
    Caliwheysted
    Caliwheysted New Member
    Commiefornia
    08 CrewMax Limited 4x4
    I had just replaced both of mine on an 08. I spent extra time making sure the sticky residue and dirt was off. No issues through the car wash yet lol.
  12. Mar 21, 2022 at 8:17 AM
    MPG_LOL
    MPG_LOL New Member
    Paul
    2012 Black Toyota Tundra
    Leveling Kit, 20" Wheels, KO2 Tires
    Both of mine blew off at Buccees. I'm pretty sure they have a collection of these at the carwash!!! :(
    Abos likes this.
  13. Aug 7, 2023 at 9:59 AM
    EmergencyMaximum
    EmergencyMaximum Synthetic member
    Thank you, ordered.
  14. Aug 27, 2023 at 3:46 AM
    tmac58star
    tmac58star New Member
    Black 1st generation Tundra SR5 Access Cab
    Visit your dealer.
    EmergencyMaximum likes this.
  15. Aug 27, 2023 at 6:02 AM
    Gene_in_FL
    Gene_in_FL SUPER genius
    FLORIDA
    2016 SR5 DC 5.7 2021 SR5 DC 5.7
    Sounds that way. My 2016 looks good as new. Central Florida, and the truck has never been in the shade.
  16. Apr 16, 2025 at 3:15 PM
    Mizterusa
    Mizterusa New Member
    2007 Toyota Tundra crewmax SR5 TRD
    S&B intake, MBRP dual exhaust and a killa sound system
    07 Toyota tundra CM.... Amazon $22 for both sides, there really is no left or right they're exactly the same. I actually like these better because they put a longer section of 3M tape on.
