Replacement stock front coils with Bilstien's?
Discussion in '1st Gen Tundras (2000-2006)' started by willrun4fun, Aug 12, 2017.
  1. Aug 12, 2017 at 3:42 AM
    willrun4fun
    willrun4fun [OP] New Member
    2000 Limited 4wd
    I am looking at putting in the adjustable Bilstien shocks in the future and wondering if I should look at coils as well. I don't want a lift I just want to get it up a little more level is all.
  2. Aug 12, 2017 at 4:00 AM
    Garvin74
    Garvin74 New Member
    2017 Tundra CM SR5
    Of all the research I've done the 5100's are perfect for what you want no coils nessecary. When I replace mine I'll use the 5100's
  3. Aug 13, 2017 at 1:41 AM
    willrun4fun
    2000 Limited 4wd
    Well, after doing a garage lift of 1" with the floor jack to look at it I think the 5100 models would be the route. I will put them on my wish list and also get ball joints, from Toyota, and some other parts to do a the same time.
    Thanks.
  4. Aug 13, 2017 at 4:53 AM
    Netmonkey
    Netmonkey Don't be a Dumbass
    Georgetown, TX
    2016 Texas Edition, 5.7, CM, MGM
    Icon stage 2 lift, 295 60 20 nitto ridge grapplers, fuel kranks, TRD dual exhaust, TRD rear sway bar
    I am very happy with the 5100's at the middle setting. I don't plan on doing any off-roading so they are perfect for my use. if I were to do a lot of off-roading, I would have gone with the 6112's that come with a coil.
  5. Aug 13, 2017 at 5:09 AM
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    A warning, if the shocks have been replaced before with a quick strut type assembly the springs may not fit the 5100's.
    My truck had Monroe's on it and the springs would not fit the lower pad at all.
    TX-TRD1stGEN and willrun4fun[OP] like this.
  6. Feb 4, 2018 at 10:28 AM
    Poopypants
    Poopypants New Member
    Mark
    2011 Tundra SR5
    I'm in the same boat, and since I rarely get off the highway (well worn dirt paths, and some camping on family property) I am looking at the Monroe's. I can do all four corners on my 2011 for about $270 from Rock.
  7. Feb 4, 2018 at 10:30 AM
    Stulloh
    Stulloh New Member
    Dallas
    18 Tundra TSS
    I put on the 6112s upfront, I plan on soon putting 5110’s on the back. I love the 6112’s
    pschiller86 likes this.
  8. Feb 4, 2018 at 10:31 AM
    pschiller86
    pschiller86 2017 SR5 CrewMax
    Paul
    Temecula, CA
    Do the 6112’s you won’t regret it! I set mine at 1.9” (3rd setting) and it’s a HUGE improvement over the stock black shocks.
    Stulloh likes this.
