replacement lug nuts
Discussion in 'Wheels & Tires' started by olds350, Aug 9, 2022.
  1. Aug 9, 2022 at 6:17 AM
    olds350
    olds350 [OP] New Member
    Has anyone on here ordered a set of replacement lug nuts for their tundra? I'm sick of these 2 piece nuts. That outer cover is starting to show it's age and I'm afraid it's going to come off at some point. I rotate tires every time I change the oil and the socket always gets stuck on a few of these. I'm interested in buying some black ones. What did you buy and from where? Please add a link if you can please....
  2. Aug 9, 2022 at 6:51 AM
    1lowlife
    1lowlife New Member
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
  3. Aug 9, 2022 at 6:52 AM
    TundraMidwesterner
    TundraMidwesterner What?
    Northern Illinois
    2019 Magnetic Gray Metallic CrewMax TSSOR 4x4
    Katzkins, Rostra heated seats(4), Tint (all), TRD rear sway bar, TSS wheels, OEM black lug nuts and wheel locks, OEM LED black fog lights, Driver side grab handle, Rough country LED Bumper bar, Rough Country Hard tri fold tonneau cover, AVS ventshades, Bilstein 5100's on top setting in front, Ready lift 1 inch ready block in the rear with Bilstein 5100's. Fluid Film. ESP under seat storage. LED interior lights and cargo lights swapped. Rear USB charger port swapped for 12v port. Remote start. Leather wrapped steering wheel kit. TRD shift knob. Kenwood dmx1037s. Hertz K170 door speakers/ tweeters, Infinity Reference 7005A 5 channel amp, 2 JBL WS1000 10 inch subs. DDI Seat Jackers. RCI engine Skid and Vahalla's Shields (front and rear) 1/4 aluminum. Stillen intake. LED Pro Headlights with iHacker harness. Cartrimhome auto up and down window switches. Coupe's aluminum battery tie down. Color matched mirror caps. Color matched door handles. Chalk bag cup holder. NFab podium step bars, herculined. Powerstop z36 drilled slotted brake discs w/ceramic pads.
  4. Aug 9, 2022 at 7:00 AM
    1lowlife
    1lowlife New Member
    DADA
    2014 MGM DC SR5
    Those are the same type of 2 piece lugnuts the OP is trying to get away from.:(
  5. Aug 9, 2022 at 7:07 AM
    TundraMidwesterner
    Northern Illinois
    Ah, well maybe the black will hold up a little better? I know all the aftermarket ones I've ever purchased for cars in the past - I've had back luck with rust or peeling coatings and end up having to replace them every few years. The OE black ones I have are holding up well but I try to avoid driving the truck in the winter as much as I can.
    hopefully someone can post a better option.
    1lowlife[QUOTED] likes this.
  6. Aug 11, 2022 at 12:03 PM
    Bergy24
    Bergy24 New Member
    2021 Cement Crewmax Limited TRD 4X4
    Have you considered these?
    Taco-Spike likes this.
  7. Aug 11, 2022 at 1:14 PM
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    2015 MGM Limited 2x4 Sequoia
