Replacement Lock Trail Edition
Discussion in '2.5 Gen Tundras (2014-2021)' started by Drogers100, Mar 26, 2022.
  1. Mar 26, 2022 at 8:16 AM
    Drogers100
    Drogers100 [OP] New Member
    Any idea where replacement locks can be purchased? Purchased truck used and the keys are missing for the current locks.
  2. Mar 26, 2022 at 8:20 AM
    FrenchToasty
    Mo
    The SoAz….. big surprise
    Bone stock
    Camper shell lock? What brand is the cap?
  3. Mar 26, 2022 at 8:24 AM
    Drogers100
    No it is for the tool boxes that came with the truck. Toyota OEM boxes.
  4. Mar 26, 2022 at 8:32 AM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    Contact your local Toyota dealer
    FrenchToasty and GODZILLA like this.
  5. Mar 26, 2022 at 8:35 AM
    Either take the locks to a locksmith to get new keys cut, or reach out to Toyota. Personally, I'd ask @Roman as he is our OEM Parts Guru on here.
    2mchfun and FrenchToasty like this.
  6. Mar 26, 2022 at 8:40 AM
    Drogers100
    Local Toyota dealer says there is not an option for anew key. Locksmith says they can do nothing. @Roman appreciate any help you can provide.
  7. Mar 26, 2022 at 9:00 AM
    Let's see the bottom of the lock.
    Is that a push button lock?
    FrenchToasty likes this.
  8. Mar 26, 2022 at 9:04 AM
    Drogers100
    Yes it is push button.
  9. Mar 26, 2022 at 9:08 AM
  10. Mar 27, 2022 at 8:16 AM
    2mchfun
    You need to see a "real" locksmith, I assure you a true locksmith can in fact make a key.
    BOSSARU, bulldog93 and GODZILLA like this.
  11. Mar 28, 2022 at 4:16 AM
    PermaFroxt
    PermaFroxt New Member
    Vito
    20 Platinum
    lil bit
    I don't mean to crash your thread (but i guess that's what I'm doing ) I'm thinking about adding those boxes. How well do you like them & is there still at least 48" between them for sheet goods like plywood?
    I can't help with your lock issue but if you need fireplace advice I'm yer huckleberry. Thanks!
    Victor
  12. Mar 28, 2022 at 6:16 AM
    2mchfun
    I have the boxes. Like em'! Yes, just a bit over 48", haul panels often here. Some say they leak, mine don't leak, but I don't pressure or wand wash my truck either. Old fashioned sponge and bucket method here. I will say they could interfere with some accessories such as a soft topper cap because of the way the framework folds up and down.
    PermaFroxt[QUOTED] likes this.
  13. Mar 28, 2022 at 9:44 AM
    Roman
    Roman Toyota Parts Master Vendor
    Roman
    Franklin, TN
    Do you have a key at all? If so, which locks does the key work in, if any?
  14. Aug 9, 2022 at 3:15 PM
    caleblukeb
    caleblukeb New Member
    Luke
    2021 Super White Tundra SR5 Trail Edition
    I have the same issue. No key and no one will touch it. Was there a solution to this?
  15. Aug 9, 2022 at 3:38 PM
    Joe333x
    Joe333x Member
    Boston
    2019 Tundra CrewMax Platinum
    Its unfortunate that there's so few real lock smiths around anymore since an actual lock smith can definitely create a key for it.
  16. Aug 9, 2022 at 5:06 PM
    Downytide
    Downytide New Member
    GTA
    Lunar Rock with trail boxes
    I thought the keys for the box is generic?
  17. Oct 9, 2022 at 5:14 PM
    TheDarkside
    TheDarkside New Member
    Georgia
    2021 Trail Edition Tundra
    Defender flares, Barricade HD Stubby Bumper, front black Bumpershellz, graphics, undercover LX tonneau cover, interior chrome delete, custom seat covers, desert eagle cat shield, JL Audio speaker/amp upgrade from Tech12volts, TRD Pro grill…
    The dealership lost the keys for miine and had to order new boxes because not even they could get it rekeyed....so likely unless you find an aftermarket service you won't fix it.
  18. Feb 18, 2023 at 2:25 PM
    blackbetty21
    blackbetty21 New Member
    Scott
    2021 Tundra SR5 Trail Edition
    none yet... why I am here
    I’m in the same boat. Hate to drill it out if a better solution is possible.
  19. Feb 18, 2023 at 2:36 PM
    1lowlife
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
  20. Feb 19, 2023 at 7:40 AM
    Zeroman
    Zeroman New Member
    Cypress, TX
    2019 Gen 2.5 "Just a Stocker"
    Try easykeys.com.
    They have helped me in the past.
    You most likely would have to send a "Submit a Request" with pics.
    Worth a try.
    Good luck.
  21. Oct 6, 2023 at 8:07 AM
    Glockman2018
    Glockman2018 New Member
    Any luck on the locks from Amazon?
  22. Dec 1, 2023 at 6:28 AM
    Glockman2018
    I recently purchased the fjm security lock and it was too small.
    Any help or ideas guys?
  23. Feb 13, 2024 at 2:01 PM
    Avi8or
    Avi8or New Member
    Johann
    MO
    2020 Limited Crewmax
    I am currently trying to get keys made for these locks.
    My locksmith kept it for a few days and couldn’t get a key made. I’ve used him for years and believe if it was possible, he could do it.
    These locks are massive with a 1.18” OD. That is unusually large for this type of lock making an off the shelf solution difficult to find.
    If anyone has had success. Please post.
  24. Mar 1, 2024 at 11:45 AM
    chill_trd
    chill_trd New Member
    '22 TRD limited
    Real locksmith here. Unfortunately locksmiths don't manufacture keys from raw material. In order to make a key we would need a correctly milled blank that goes into the lock. Maybe there is another key that is close enough that would work to begin with but maybe not. If we had the correct uncut blank to start with a locksmith should be able to impression a key unless the lock has a sidebar design. If it is a side bar and the lock does not disassemble then no they would not be able to.
    My guess is your Locksmith wasn't even able to find a key that would work to begin with to even properly attempt to make a key.
  25. Mar 1, 2024 at 12:07 PM
    2mchfun
    Contact Toyota customer relations and request the contact information for the box manufacturer,/supplier. Then reach out to them to request the contact information for the lock supplier.
  26. May 21, 2024 at 10:41 AM
    Ryan1408
    Ryan1408 New Member
    2021 Tundra Trail Edition
    Just wondering if anyone has had any luck with finding a replacement lock/key for these boxes. I'm a new Tundra owner and in a similar situation. So far the individuals I have talked to at the dealership have come up empty (probably just havent found the right person). I did come across a website that supposedly had replacement lock cylinders but seemed a little phishy. Any insight would be appreciated. Thanks!
  27. May 21, 2024 at 10:51 AM
    2mchfun
    Welcome to the forum! Can you please post a link to what you found? Just so others can evaluate their options. TIA!
  28. May 21, 2024 at 11:10 AM
    Ryan1408
    Ryan1408 New Member
    Sure!
    https://parts.toyotadalton.com/p-bed-cooler-box-key-cylinder-pt27134000lc
    The email address listed at the top of the page is whats throwing the red flag for me. That and when I look for the part number through toyota I don't get a matching item, but I'll claim ignorance for that.
    2mchfun[QUOTED] likes this.
  29. May 29, 2024 at 5:25 PM
    Nightshade-Dan
    Nightshade-Dan New Member
    2021 Limited Nightshade
    if these are locked on truck with no key, they can be picked by a locksmith easily. I too am missing keys. Called dealer a few days ago. They list five different options for replacement keys. 5 bucks a set. I can’t find a part number on my cylinders but haven’t removed one yet. If I pull cylinder and don’t see a number, I’m ordering all five options.
    2mchfun likes this.
  30. May 29, 2024 at 5:44 PM
    Ryan1408
    Ryan1408 New Member
    My boxes are not currently locked, but would love to have the ability to lock them. I would gladly pay 5 bucks for a key! Please update us if they were able to provide a key!
    2mchfun likes this.
