Replacement cooling hoses for transmission???
Discussion in '2.5 Gen Tundras (2014-2021)' started by Muleycrazy13, Sep 14, 2021.
  1. Sep 14, 2021 at 9:06 PM
    Muleycrazy13
    Muleycrazy13 [OP] New Member
    Buckeye, AZ
    2024 Chevy Silverado 2500HD Duramax
    Hey guys when my catalytic converters got stolen they knicked my transmission cooling hose and I am wanting to replace it for piece of mind. Does anyone know what part number this is ? I asked Toyota to do it and they wanted $200 to replace it I said $200 for an 8” piece of rubber hose that will literally take you 10 minutes to change absolutely not!!! Long story short is I want to change this out before I install my vahalla shield I received today. Thanks for your help!
  2. Sep 14, 2021 at 9:08 PM
    Muleycrazy13
    Buckeye, AZ
    mid you zoom In you can see where they knicked the hose. It’s been that way for about 3 months now but it’s one of those things that constantly gets me thinking if it may fail so I just want to get it replaced.
  3. Sep 14, 2021 at 9:32 PM
    Here you go Brody.
    2mchfun, Muleycrazy13[OP] and Kratos like this.
  4. Sep 14, 2021 at 9:36 PM
    blackdemon_tt
    blackdemon_tt Battery Slayer
    Hope this helps
    2mchfun and Muleycrazy13[OP] like this.
  5. Sep 14, 2021 at 9:41 PM
    blackdemon_tt
    1626724020 here is the whole part number.
  6. Sep 14, 2021 at 9:53 PM
    SLA10
    SLA10 New Member
    2019 Tundra TRD Pro
    Sorry you have to deal with this crap, but the hose replacement will be an easy fix.
    Muleycrazy13[OP] likes this.
  7. Sep 15, 2021 at 4:36 AM
    Muleycrazy13
    Buckeye, AZ
    thanks Chris!
    2mchfun and ColoradoTJ[QUOTED] like this.
  8. Sep 15, 2021 at 4:36 AM
    Muleycrazy13
    Buckeye, AZ
    thank you!
    2mchfun likes this.
  9. Sep 15, 2021 at 4:41 AM
    Spyker
    Spyker I’m a dude,playin a dude,disguised as another dude
    Not to thread jack, but seems like OP got his answer;
    what exactly does this ‘oil cooler’ do? I know it’s not a trans cooler, but what does it do exactly?
  10. Sep 15, 2021 at 6:19 AM
    Muleycrazy13
    Buckeye, AZ
    It is a transmission cooler with a thermostat. Fortunately my year came with the transmission cooler, but the newer ones don’t. I can’t quite remember the cutoff year
    Spyker[QUOTED] likes this.
  11. Sep 15, 2021 at 6:41 AM
    Eaganite
    Eaganite New Member
    Gary
    Eagan, Minnesota
    2020 Limited TRD
    Technically its more a warmer, although it will do some cooling as well. The actual cooler thermostat is between the transmission and the "puck" that the cat thief nicked the engine coolant line to.
  12. Sep 15, 2021 at 8:48 AM
    Muleycrazy13
    Buckeye, AZ
    In this diagram the hose I would need is the pnc 16267 is that the actual part number ?
  13. Sep 15, 2021 at 8:50 AM
    blackdemon_tt
    I typed it out right under.. 1626724020
  14. Sep 15, 2021 at 8:53 AM
    Muleycrazy13
    Buckeye, AZ
    I see that but for some reason when I put that part number in it results in a hose for a Toyota Corolla
  15. Sep 15, 2021 at 8:59 AM
    blackdemon_tt
    Whaaat?? Thats crazy... you can type the number in the picture and it should bring it up.... i looked it up under the 5.7 Tundra and it gave me a green flag.
