Replace TRD Big Brake Kit
Discussion in '2.5 Gen Tundras (2014-2021)' started by kdinkel, Nov 19, 2019.
  1. Nov 19, 2019 at 3:50 PM
    kdinkel
    kdinkel [OP] New Member
    Ken
    2020 Platinum Crewcab
    I just purchased a 2015 Platinum with a TRD big brake kit (my 3rd tundra). It needs new pads which means it needs new rotors. I don't want to spend the money every time I need new pads (it is just my daily driver, mostly freeway miles). Can I just swap the rotors, calipers, and pads with oem or will it require different mounts, etc? I have replaced all 3 before, but never changed the type. If there is someone in Utah who wants to trade, I am open to that as well. Thoughts?
  2. Nov 19, 2019 at 5:20 PM
    What is leading you to think that you need to replace the rotors?
  3. Nov 20, 2019 at 7:29 AM
    kdinkel
    Ken
    Good question. When I bought the truck the were squeaking a lot. I decide to pull the pads and clean and grease everything. Since I was doing that much work I decided to replace the pads as well. I did that and bedded them. Even after all that the squeaking was still there. I took it to Big O and they said the rotors were warped. I don't have the shuddering or shaking that typically comes with warped rotors, just the noise. They aren't as bad after 2 weeks, but still have some noise. I was also told that when I replace the pads I have to replace the rotors?
  4. Nov 20, 2019 at 7:34 AM
    rustynail11
    rustynail11 New Member
    Scott
    Mansfield,TX (DFW Area)
    2017 Grey Tundra TRD
    Have you tried having the rotors turned?
    Inquiringone likes this.
  5. Nov 20, 2019 at 7:36 AM
    Scuba
    Scuba Sober member
    Austin, Tx.
    2012 Texas Edition CM.
    If they’re squeaking when you apply the brakes I would assume the pads aren’t lubed enough.
    You aren’t required to replace the rotors when you replace the pads. It is however recommended to have them resurfaced when you replace the pads. That way the new pads have a new surface to bed in to.
    My local oriellys turns them for $15 each.
    Also in response to your main question.. I don’t see why the non TRD brakes wouldn’t just bolt on to replace the big brake kit.
  6. Nov 20, 2019 at 7:43 AM
    kdinkel
    Ken
  7. Nov 20, 2019 at 7:51 AM
    kdinkel
    Ken
    Thanks a ton for the advice. I just called Oriellys and they turn drilled and slotted rotors. I will give that a shot. Follow up question then. I have run the new pads on these rotors for about 2 weeks. Do I need to replace the pads again?
  8. Nov 20, 2019 at 8:08 AM
    Danimal86
    Daniel
    Sacramento, CA
    2017 White Tundra SR5
    Make sure they know you have two piece rotors.
  9. Nov 20, 2019 at 8:13 AM
    kdinkel
    Ken
    Thanks! Just called and they said as long as they are hub centric?
  10. Nov 20, 2019 at 8:26 AM
    Danimal86
    Daniel
    Sacramento, CA
    :notsure:
    Our wheels are hub centric, so I'd assume the rotors are.......
  11. Nov 20, 2019 at 8:29 AM
    Scuba
    Scuba Sober member
    Austin, Tx.
    Yes they are hub centric rotors.
    As for the pads.. they’re probably still okay. When I did a similar thing like you are doing, I took an 80G sandpaper block to the pads to knock off a tiny bit of the material in an effort to get down to fresh material. I don’t know if this is right or wrong but I’ve put 2500 miles on the car since then and the brakes work great. YMMV.
    Vince, 773_eddie and BENWALES like this.
  12. Nov 20, 2019 at 8:32 AM
    timsp8
    NY
    It’ll cost more to buy stock calipers and rotors than just new rotors. I think the bbk rotors are less than $200 a piece while just stock calipers are around $400.
  13. Nov 20, 2019 at 8:42 AM
    Mr_Lahey
    Mr_Lahey New Member
    SE Idaho
    2016 TRD Double Cab (Black of course)
    Once you go black you never go back.
    With my limited experience taking rotors to chain auto part stores to be turned they always told me my rotors were too thin to turn but they would out of the goodness of their heart sell me new ones.
    Why would someone put a $2800 big brake kit on a Tundra?
  14. Nov 20, 2019 at 9:07 AM
    kdinkel
    Ken
    Thanks for the additional feedback. The guy at Oreilly thought the TRD rotors would be thick enough. Fingers crossed. The TRD BB rotors are about $300 a piece. I have no idea why they are on there. The original owner put them, TRD dual exhaust (which I do like), TRD sway bar, and TRD air filter on it.
  15. Mar 11, 2020 at 3:28 AM
    407plattundra
    407plattundra New Member
    2019 Super White Tundra Platinum
    Do they make a trd brake kit for a 2019 ? Im not really finding anything on here about it...
  16. Mar 11, 2020 at 4:15 AM
    Deuxlatch
    Deuxlatch AirBus
    Chris (Latch)
    Tomball, Tx./Lafayette, La.
    2010 Super White Tundra CM
    TRD Supercharger, TRD Big Brake kit, MotoMetal wheels, Undercover Tonneau with dual swing out saddle bag tool boxes.
    I'm not sure what the kit costs but mine has one the PO installed and Holy Crap! The stopping power is night and day difference from my last Tundra. Mine did squeek for a bit but like @Scuba said I just used a sanding block to get to new material on the pads and it stopped.
    airosey likes this.
  17. Mar 11, 2020 at 5:26 AM
    BENWALES
    BENWALES New Member
    Ben
    2020 Tundra White SR5
    Last time I checked the kit was discontinued.
    I have a customer that we took the BBK system off the truck and put a stock system on. You can buy reman calipers with pads and good rotors for way less than OE Toyota parts. I ran the Raybestos calipers and rotors on my 08 for years.
    407plattundra[QUOTED] likes this.
  18. Mar 11, 2020 at 6:00 AM
    Rustyscrew
    Rustyscrew New Member
    Rockledge,Fl
    15 Tundra Platinum
    TRD Front sway bar, TRD Rear sway bar, TRD red and blue shocks, 2018 LED headlights and fogs, TRD intake box lid, TRD air flow accelerator, AFE Super Stock Intake with dry filter, TRD radiator and oil cap, Radium PCV Oil catch can, StopTech SS brake lines, LED puddle lights, VLED interior lights, OEM metal oil filter housing, Fumoto oil drain valve, LED front turn signals, TRD Battery tie down.
    Stop Tech makes the kit for Toyota. You can still buy it from them as well as a rear BBK
    BENWALES and RitcheyRch like this.
  19. Mar 11, 2020 at 3:43 PM
    407plattundra
    I see some places still have some for sale but it says 07-15. I wonder if i purchased a kit if it would still fit
  20. Mar 11, 2020 at 4:16 PM
    BENWALES
    BENWALES New Member
    Ben
    I don’t know why it wouldn’t, nothing has changed in the brakes.
  21. Mar 12, 2020 at 2:05 AM
    RAMIRO V
    RAMIRO V New Member
    San Diego
    2014 1G3 SR5 PRO
    If you are still wanting to trade I may consider it.
  22. Mar 12, 2020 at 5:44 AM
    Brandisher
    Brandisher Member
    UT
    2018 MGM Limited CM
    Too bad these don’t fit inside 18” wheels (from your link). Otherwise, I would consider meeting up and trading with you.
  23. Mar 12, 2020 at 5:50 AM
    407plattundra
    Are you replying to me or someone else?
  24. Mar 12, 2020 at 7:47 AM
    Brandisher
    Brandisher Member
    UT
    2018 MGM Limited CM
    I meant I was interested, but I’m running the 18” TRD BBS wheels and wished they would clear, but from Toyota’s statement that’s not the case.
  25. Mar 12, 2020 at 10:06 AM
    scottb2240
    scottb2240 New Member
    Scott
    2015 Tundra SR5 Black
    2016+ model years have different size bolts that mount to the spindle.
    I have a 2014 that came with the BBK. I wanted 17” wheels so the big brakes had to go. I found a set of 2016 oem take-offs on eBay for a good price. They had minimal use so I looked at part numbers to make sure it would fit. The 07-15 and 16+ have different numbers but nobody could tell me why. A few people said it was probably just a different supplier. So I bought the 2016 brake setup off eBay and attempted to install it. It didn’t work. I found a set off a 2014 and installed those with no issues.
    So now I have a set of 2016+ brakes sitting in my garage. Anybody want them? Ha
  26. Mar 12, 2020 at 10:12 AM
    TXTundra2722
    2015 Black Tundra
    CST makes a "spacer" bolt that fixes the different sized bolts issue.
  27. Mar 12, 2020 at 10:18 AM
    Inquiringone
    Ter
    NorCal 408
    Not many yet, mostly stock.
    Id think they were doing some towing
    That’s my take on big brake kit installed.
    Mr_Lahey[QUOTED] likes this.
  28. Mar 12, 2020 at 11:16 AM
    scottb2240
    Scott
    sounds like you’d only be able to use that if you had a 2016+ Tundra... also, I couldn’t find it on their website. Do you have info on that? I was curious to see their solution.
  29. Mar 12, 2020 at 11:22 AM
    TXTundra2722
    2015 Black Tundra
    It's not listed separately on their website, but I called and ordered a set. It's only if you have 2015 and older and are buying something 2016+
  30. Mar 12, 2020 at 11:24 AM
    scottb2240
    Scott
    Ah interesting. Oh well, getting the correct 07-15 calipers solved my issue.
