Replace timing belt based on age or just miles?
Discussion in '1st Gen Tundras (2000-2006)' started by MartyE12345, Sep 10, 2020.
  1. Sep 10, 2020 at 7:28 PM
    MartyE12345
    MartyE12345 [OP] New Member
    Martin
    2000 Toyota Tundra SR5 Access Cab
    I purchased a 2000 Tundra AC SR5 4wd about 6 months ago. When I purchased it had about 135k, it sits right at 140k now. When I purchased the truck, the CarFax Said the timing belt was replaced at 96k by a local Toyota dealership. The problem is that happened in 2006. How worried should I be about replacing it? Only 40k miles on it but about 14 years of age.
  2. Sep 11, 2020 at 1:15 AM
    abcinv
    abcinv OEM (+) Junkie
    Tommy
    South of ATL
    2006 Tundra 4X4 Limited Dbl Cab
    I replaced my belt earlier this year on my 2006 with ~67k miles on it due to age; I think you should do the same.
    I believe most on here will advise the same - 14yrs is a long time for that rubber belt...
  3. Sep 11, 2020 at 4:51 AM
    DSTundra
    DSTundra New Member
    Dave
    Albuquerque, NM
    2017 Tundra Platinum
    If I remember correctly, timing belts on 1st gens are recommended to be replaced every 7 years or 90,000 miles.
    035VZFE likes this.
  4. Sep 11, 2020 at 4:56 AM
    N84434
    N84434 In the Frozen Tundra
    Milwaukee WI.
    2001 Limited TRD
    14 years is a pretty good length of time for a rubber component to be in there and yes, I would swap it out. I did the TB on my 2005 LS430 last year, with a mere 62,000 miles and as expected, the belt and water pump looked new. It was worth the peace of mind to swap it out, though.
    10TundraSR5 and bmf4069 like this.
  5. Sep 11, 2020 at 5:01 AM
    Professional Hand Model
    Hand Protectors
    Most likely the belt won’t fail, but if it does then kiss the motor good bye. Toy reccos 9 years or 90k miles.
    Yours has 40k on it. Just replace it for piece of mind. Flush coolant prior to water belt change and maybe you need a new radiator and accessory belt.
  6. Sep 11, 2020 at 5:14 AM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    I'd do it.
    That's 4 votes for yes.
    GeezePlease, FirstGenVol and Tundra2 like this.
  7. Sep 11, 2020 at 5:20 AM
    Hand Protectors
    I’m feeling a landslide victory here. :yes:
    bmf4069[QUOTED] likes this.
  8. Sep 11, 2020 at 5:20 AM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
  9. Sep 11, 2020 at 5:22 AM
    FrenchToasty
    Mo
    The SoAz….. big surprise
    Bone stock
    My mom still thinks that show is real
  10. Sep 11, 2020 at 5:25 AM
    Hand Protectors
    Its not?
  11. Sep 11, 2020 at 5:25 AM
    Suprafantx
    Suprafantx New Member
    2020 4X4 White Tundra TSS
    You should replace the timing belt ASAP. Since your engine still has lost of miles left, you don't want to take a risk if the timing belt is failed.
    Tundra2 likes this.
  12. Sep 11, 2020 at 5:30 AM
    FrenchToasty
    Mo
    Bone stock
    Don’t tell her that! She literally has “survivor night” with my sister and her husband. It was one of the OG reality tv shows(COPS being the first and best)
    But I can’t stand watching that kind of “editing” for an entire episode.
  13. Sep 11, 2020 at 5:30 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    Make it 5..
    bmf4069[QUOTED] and Tundra2 like this.
  14. Sep 11, 2020 at 9:06 AM
    MartyE12345
    Martin
    Looks like I’m changing the timing belt. I am fairly capable in terms of repairs but I may have someone do this for me? What does the dealer charge to do this? Or think I should get the parts and have a local guy do it?
    bmf4069 likes this.
  15. Sep 11, 2020 at 9:12 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    I would watch a video on it before deciding. Some have said as far as T-belt jobs are are concerned, the 4.7L is fairly easy. If you are capable you might not have any issues. Just make sure you use OEM or equivalent parts. Don't go aftermarket on the T Belt. I paid the dealer around $900 to do my timing belt and water pump. Most people recommend the Aisin kit sold on Amazon.
    Is your radiator original? 20 years is a good run for the radiator. It might be a good time to replace both.
    41bigdawg, bmf4069 and N84434 like this.
  16. Sep 11, 2020 at 11:21 AM
    270Fan
    270Fan New Member
    2004 Silver Tundra 4x4 DC
    I have a 2004 that I bought with 135k miles on it. The TB had never been changed. I thought about doing myself but I found myself in the rare position of having more money than time so I paid a shop to do it. It was a complete dumpster fire and I wish I had done it myself - or at least found a competent shop to do it. I paid $950 (which I understand is what the dealerships around here get) for the cornholing.
    The truck was from the Bakersfield area which can be extremely hot and dry. Looking at the belt, it was time for a change.
    bmf4069 likes this.
  17. Sep 15, 2020 at 9:25 AM
    MartyE12345
    Martin
    I am in Maryland, I just called the dealership, they want 1500.... I’m going to look into doing this myself
    N84434 and bmf4069 like this.
  18. Sep 15, 2020 at 10:21 AM
    RPR
    RPR New Member
    2005 Tundra SR5 2WD Silver
  19. Sep 15, 2020 at 10:28 AM
    MartyE12345
    Martin
  20. Sep 15, 2020 at 10:44 AM
    B33
    B33 New Member
    doing my 2007 2nd gen today has 120k i could do this my self but Truck won't fit in the Garage, so a local shop is doing it for
    $850 with Aisin parts and toyota T-stat and drive belt I would do the belt
  21. Sep 15, 2020 at 10:52 AM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    Theres lots of good threads on here, as well as a good YouTube video to help you along. You got this. And that's the kit a lot of people on here get, and is recommended.
  22. Sep 15, 2020 at 10:54 AM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
  23. Sep 15, 2020 at 11:26 AM
    035VZFE
    035VZFE Restored a Tundra top to bottom
    James
    Vero Beach, Florida
    2009 Passat B6 2.0 Turbo
    ECS Tuning DV Spacer ECS Tuning Turbo Muffler Delete ECS Tuning Luft-Technik CAI System A-Spec 60mm Charge Pipe Straight piped from resonator back, stock cat and downpipe
    :amen::D
    Tundra2 likes this.
  24. Sep 15, 2020 at 11:37 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
  25. Sep 15, 2020 at 1:24 PM
    Hand Protectors
    Shove it down the hole!
    bmf4069[QUOTED] and Lil Steve like this.
  26. Sep 15, 2020 at 1:54 PM
    delz05
    delz05 Old relic... Living and Loving Life!!!
    BOSTON
    2005 Tundra Limited
    Work in progress...
    Why the rush??? LOL!!! The 05 truck I have now had the original belt et al.... 267K miles.... previous/original owner did only the basics over the years...
    TundraBike&SkiGuy likes this.
  27. Sep 15, 2020 at 2:26 PM
    TundraBike&SkiGuy
    TundraBike&SkiGuy So I got that goin' for me
    Jeff
    Minneapolis, MN
    2020 Quicksand Tundra
    I sold my 04 this past July with 196,000 and the original belt. I was the third owner in 2008 at 40,000. If I didn't get a 2020 I might have tried for 267k miles. Boy do I miss that truck.
  28. Sep 15, 2020 at 7:41 PM
    MartyE12345
    Martin
  29. Sep 15, 2020 at 8:06 PM
    Lil Steve
    Lil Steve Living the dream
    Gilbert, AZ
    2002 Tundra SR5 Access Cab 2WD V8
    Aisin makes lots of parts for many Japanese OEM's. Buying Aisin parts can often save you a good amount of money vs buying essentially the same parts from a car dealership.
  30. Sep 15, 2020 at 8:14 PM
    fbingha
    fbingha New Member
    Bakersfield, CA
    I was in for about 1,000 from the dealer both times I had the belt and water pump changed. First around 90,000, second around 187,000
