Removing Tow Hitch lock
Discussion in 'Towing & Hauling' started by CCTundra, Mar 20, 2017.
  1. Mar 23, 2017 at 11:37 PM
    #91
    TRDFaux
    TRDFaux Irresponsible Adult
    2014 Tundra SR5 Crewmax 4X4
    Toytec level and diff drop, Cooper STT Pro Tires, TRD Pro Grill, blacked out, debadged.
    Where is your sister in law? We are still waiting to see her.
  2. Mar 23, 2017 at 11:57 PM
    #92
    Tomcat
    Tomcat Ever see a motorcycle outside a shrinks office?
    2010 SR5 4X4 5.7 20" wheels Metallic Gray
    Bakflip
    Have you tried hitting the pin and not the hitch? Please document everything?
  3. Mar 24, 2017 at 2:03 AM
    #93
    TRDFaux
    he got the pin out. its just the hitch that is stuck in the receiver.
  4. Mar 24, 2017 at 2:45 AM
    #94
    rons23
    rons23 Get The Led Out!!!
    Ron
    Kill Devil Hills
    2008 Nautical Blue TRD
    So here's my .02 worth once more. First you try easy route. ( Soak with PB Blaster overnight) smack with maul. Not working? Suggestion #2. HEAT IT WITH TORCH!!!!. You could try a small propane torch from home cheapo, but don't think it will be enough. You need to put some serious heat on it, then let it cool. Then smack again with your maul. Steel expands then retracts with heat. Trust me, been using a torch all my working life. Worst case scenario, take it to a shop where they have a torch and have them remove it.
  5. Mar 24, 2017 at 8:57 AM
    #95
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    Seeing the side to side movement when you whack it, I think the PO did something else to secure it towards the inside. Make sure there aren't any holes drilled with a pin or bolt going through. Or like a wire behind it holding onto it. Gotta drop the spare and see.
    NewImprovedRon and 15whtrd like this.
  6. Mar 24, 2017 at 9:47 AM
    #96
    Mike Tread lightly.
    south carolina
    Guys guys.. I'm laughing here..
    If the hitch is made out of iron and the receiver is made out of aluminum they will fuse together.. if he is where the salt roads thats a permanent weld.
    Metallurgy ring a bell?
    rons23 and NewImprovedRon like this.
  7. Mar 24, 2017 at 10:14 AM
    #97
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    Not an issue, OP has movement, watch his cool video
    joonbug likes this.
  8. Mar 24, 2017 at 11:07 AM
    #98
    Mike Tread lightly.
    south carolina
    Video has been removed.
  9. Mar 24, 2017 at 11:09 AM
    #99
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    You might have to wait til it's released on DVD or Netflix. :D
    gosolo, T-Rex266 and NewImprovedRon like this.
  10. Mar 24, 2017 at 11:15 AM
    #100
    Mike Tread lightly.
    south carolina
    I'm screwed don't have Netflix or DVD.
    T-Rex266, NewImprovedRon and joonbug like this.
  11. Mar 24, 2017 at 11:27 AM
    #101
    TRDFaux
    And there was no cameo from his sister in law.
    BlueBottle, joonbug, T-Rex266 and 2 others like this.
  12. Mar 24, 2017 at 11:28 AM
    #102
    Crewmax Chris
    Crewmax Chris Paper Airplane Enthusiast
    Lewiston, ME
    2013 Tundra SR5 DoubleCab
    Well that's not cool...
    joonbug, T-Rex266 and NewImprovedRon like this.
  13. Mar 24, 2017 at 12:23 PM
    #103
    rons23
    Ron
    Kill Devil Hills
    Ron, that was one helluva description.
  14. Mar 24, 2017 at 12:26 PM
    #104
    cd121082
    cd121082 New Member
    chris
    Washington State
    2016 Silver Tundra TRD OffRoad
    none yet
    OP be like
  15. Mar 24, 2017 at 1:05 PM
    #105
    rons23
    Ron
    Kill Devil Hills
    Mike you are correct, you have oxidation (steel), and aluminum (corrosion) , putting heat on it will get it out. At this point, I don't know why someone would use aluminum hitch in a steel receiver (dissimilar metals) cc tundra would be best to remove both and install new one.
    Mike[QUOTED] and NewImprovedRon like this.
  16. Mar 24, 2017 at 1:29 PM
    #106
    15whtrd
    15whtrd Mr. Blonde
    I thought it was a stainless hitch. I have a basic one in my garage. Never thought they would use in aluminum hitch to tow anything. Sounds like a bad idea.
    joonbug likes this.
  17. Mar 24, 2017 at 1:31 PM
    #107
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    Yup, sounded like steel.
  18. Mar 24, 2017 at 1:34 PM
    #108
    15whtrd
    15whtrd Mr. Blonde
    I was looking at these pictures again to see if it was stainless (which I still think it is). There is an Allen head screw just behind the ball. Do you think that is some sort of screw that pushes against something inside the hitch to pinch into the receiver to help with rattle?
  19. Mar 24, 2017 at 1:40 PM
    #109
    15whtrd
    15whtrd Mr. Blonde
    OK I retract my stainless statement as I looked into it further.
    Check out this link I found the trailer hitch he's using online. This one you use a key just behind the ball to release the hitch. Although I know he's had a pin installed there must be something inside of it causing it not to be released. Check out my link https://www.etrailer.com/Ball-Mount...tml?feed=npn&gclid=CLHhnbr_79ICFZBafgodcRQOgQ
    If you scroll down to the bottom of the page below the description of the ball it shows someone using the key and it releasing an internal locking pin.
    Boom bitches!
    Crewmax Chris and NewImprovedRon like this.
  20. Mar 24, 2017 at 1:41 PM
    #110
    rons23
    Ron
    Kill Devil Hills
    15whtrd, I could be wrong, but probably not lol, the receiver is mild steel, or as Mike would put it Iron. The hitch is aluminum
  21. Mar 24, 2017 at 1:44 PM
    #111
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    I think that's it right there. Nice Sean. It definitely looked like something else was holding it in... and not just rust or something. Hmmmmm, now how to get it out without a key.
    Crewmax Chris and 15whtrd like this.
  22. Mar 24, 2017 at 1:46 PM
    #112
    Bprose
    Bprose Old member
    VA
    17 Tundra CM TRD
    Sean. Pretty damn impressive search skills.
    But if it's that self locking one how did it have a pin in it too?
    15whtrd likes this.
  23. Mar 24, 2017 at 1:48 PM
    #113
    15whtrd
    15whtrd Mr. Blonde
    IMG_2627.jpg His looks like an older style with an Allen key. Maybe I'm wrong and it's just dirt.
  24. Mar 24, 2017 at 1:50 PM
    #114
    15whtrd
    15whtrd Mr. Blonde
    I'm thinking that you can put something through the center of it maybe the locking pin so it's like double locked. Basically those two pins that expand to lock it in place maybe Hollow?
  25. Mar 24, 2017 at 1:51 PM
    #115
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    I think we have two holes for pins. Maybe he has a longer one and uses both holes. both holes :p But I think we're on the right track.
  26. Mar 24, 2017 at 1:53 PM
    #116
    Bprose
    Bprose Old member
    VA
    17 Tundra CM TRD
    Could be, like a sleeve. One of the pins I have has a sleeve with it so you could use the pin on a 1" receiver.
  27. Mar 24, 2017 at 1:54 PM
    #117
    Bprose
    Bprose Old member
    VA
    17 Tundra CM TRD
    Both holes, haha, love it
    15whtrd likes this.
  28. Mar 24, 2017 at 1:54 PM
    #118
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    Maybe we should erase all these messages and hold this info and exchange it for pictures of the sister in law.
    T-Rex266, BlueBottle, TRDFaux and 2 others like this.
  29. Mar 24, 2017 at 1:55 PM
    #119
    Crewmax Chris
    Lewiston, ME
    Agreed! :thumbsup:
    joonbug[QUOTED] likes this.
  30. Mar 24, 2017 at 1:57 PM
    #120
    15whtrd
    15whtrd Mr. Blonde
    If you want I'll edit it right now LMAO!
