Removing Tow Hitch lock
Discussion in 'Towing & Hauling' started by CCTundra, Mar 20, 2017.
  1. Mar 21, 2017 at 10:05 AM
    Old Time Goat
    Old Time Goat OldTimeGoat
    14+ Tundra, Crew Max, 5.7L, 4X4, TRD, SR5
    Whack it a coupla times with a hammer, Bubba!
    bigoltater and Law323 like this.
  2. Mar 21, 2017 at 10:53 AM
    rons23
    rons23 Get The Led Out!!!
    Ron
    Kill Devil Hills
    2008 Nautical Blue TRD
    You drinking again Sean :oops:
  3. Mar 21, 2017 at 11:08 AM
  4. Mar 21, 2017 at 6:28 PM
    CCTundra
    CCTundra [OP] New Member
    Seattle,WA
    2021 1794 Tundra
    Bilsteins 6112 top setting, 0.5" Coach builder shims, 5160 rear shock with 3" Coachbuilder shackle kit. RB20 Step bars, Forged TRD Pro wheels, Back flip cover, Kennwood 10" Head unit, 2JL 10" Subs, Alpine 6 channel Amp.
    I just got home and I did what a couple of people told me to do, which was to pull out and up on the tab and slide the pin out. It worked!!!. Problem now is that even though I removed the pin, the hitch is really stuck on there. I'm trying to removed it but it's really on there. Any suggestions? I was trying to bang it out with a rock, but I'm going to try with a hammer. It should just pull straight out right?IMG_6968.jpgIMG_6971.jpg
    NewImprovedRon likes this.
  5. Mar 21, 2017 at 6:30 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    Now it's time.... BFH!!!
    Law323, Tundra Fan, 15whtrd and 7 others like this.
  6. Mar 21, 2017 at 6:30 PM
    Crewmax Chris
    Crewmax Chris Paper Airplane Enthusiast
    Lewiston, ME
    2013 Tundra SR5 DoubleCab
    Hammer or a hatchet. You won't hurt something you don't care about. Crowbar if you have the room maybe? I'd probably start swinging the eight pound hammer at it to see if it loosens it if nothing else.
    NewImprovedRon and rons23 like this.
  7. Mar 21, 2017 at 6:31 PM
    mdavis
    mdavis I need a beer.
    Michael
    Rock Hill, SC
    Sounds like it's rusted together. Few taps with a hammer should break it free. Yes, it should pull straight out.
  8. Mar 21, 2017 at 7:09 PM
    CCTundra
    Seattle,WA
    2021 1794 Tundra
    Cool. I will try that. Thanks :thumbsup:
  9. Mar 21, 2017 at 7:48 PM
    Steve Tundra
    Steve Tundra New Member
    Steven
    2022 4x4 platinum
    Put a pipe over it. Should be able to bend it off with a little force
  10. Mar 21, 2017 at 8:42 PM
    BB Stacker
    BB Stacker New Member
    So. Cal
    2016 White 1794 TRD 4X4
    Sway Bar, TRD Catback Exhaust, Morimoto LED fog lamps, running boards, paracord wrapped oh-shit handles, Bak-Flip bed cover.
    A little bit of this will help...
    Randy Morton and Achuop like this.
  11. Mar 21, 2017 at 8:52 PM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    Tie it to a tree and "drive" it out.
  12. Mar 21, 2017 at 11:53 PM
    Voyagermike
    Voyagermike New Member
    California
  13. Mar 22, 2017 at 2:20 AM
    PermaFrostTRD
    Northern NY
    This. I have the same pin. I hated messing with carter keys so I bought this. Great quick release hitch pin.
  14. Mar 22, 2017 at 2:32 AM
    rons23
    Ron
    Kill Devil Hills
    Worse case scenario cctundra, put some heat on it. Heat gun or small propane torch. $20-30 @ home cheapo. Should break free from the smack of a maul. Good luck and don't forget your safety glasses. :D
    Law323 likes this.
  15. Mar 22, 2017 at 8:42 AM
    Crewmax Chris
    Lewiston, ME
    How'd you make out, sir?
  16. Mar 22, 2017 at 1:03 PM
    Krezz
    Krezz Doesn't want to be new member
    Kevin
    Southern Ontario, Canada
    2022 Tundra Crewmax Hybrid TRD Pro
    you locked her in good!
  17. Mar 22, 2017 at 1:05 PM
    Bprose
    Bprose Old member
    VA
    17 Tundra CM TRD
    The suspense is killing me. Did you get that thing out yet?
    joonbug and Crewmax Chris like this.
  18. Mar 22, 2017 at 1:12 PM
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    More importantly, is the tree still standing?
  19. Mar 22, 2017 at 3:39 PM
    #49
    CCTundra
    Seattle,WA
    2021 1794 Tundra
    Sorry guys. I have not gotten to it yet. Yesterday I got tied up with my 15 month old daughter. I will try to tackle it once I get home today. I'm thinking about using a hammer or something like that. I'm wondering if using something like WD40 might work? I don't know about a torch. I'm hoping that with some WD40 and wacking it with a hammer might do the trick.
    Crewmax Chris likes this.
  20. Mar 22, 2017 at 3:42 PM
    #50
    Crewmax Chris
    Lewiston, ME
    Whack it from different angles, it'll shake free. That's the best kind of getting tied up, man. My 22 month old "keeps me" from getting stuff done too. I wouldn't trade it for the world. :thumbsup:
    joonbug and Law323 like this.
  21. Mar 22, 2017 at 3:43 PM
    #51
    TRDFaux
    TRDFaux Irresponsible Adult
    2014 Tundra SR5 Crewmax 4X4
    Toytec level and diff drop, Cooper STT Pro Tires, TRD Pro Grill, blacked out, debadged.
    you won't need a torch. most people haven't even read other people suggestions or that it wasn't even a lock. All you need to do is break the rust free. give the hitch a good whack with a hammer on all four sides and it should pull right out. don't try to tie it off to something and pull it out with power you risk getting it crooked and it binding much worse than it already is. just a little gentle persuasion with a hammer.
    Law323, 15whtrd and Crewmax Chris like this.
  22. Mar 22, 2017 at 3:59 PM
    #52
    15whtrd
    15whtrd Mr. Blonde
    That's a nice stainless hitch. It's even got those shim tabs to keep it from rattling around when you're towing something. I want it Lol
    Wynnded likes this.
  23. Mar 22, 2017 at 4:23 PM
    #53
    CCTundra
    Seattle,WA
    2021 1794 Tundra
    I wouldn't trade it for the world either. :) I love my little girl.
    Crewmax Chris[QUOTED] and Law323 like this.
  24. Mar 22, 2017 at 5:06 PM
    #54
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
    If whacking it with a hammer doesn't work, get under the truck, get an old pipe, stick it in the other end of the receiver and hit with a hammer. Might help.
  25. Mar 22, 2017 at 5:09 PM
    #55
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    I really like the tie it to a tree idea. Definitely not the safest idea, but sure would be awesomest.
  26. Mar 22, 2017 at 5:21 PM
    #56
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
    No.....but since when is the safest idea the most awesome idea??
  27. Mar 22, 2017 at 5:24 PM
    #57
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    Oh, and please record from the beginning. Starting with the hammer tap. You never know... it could get really amusing.
    Law323, BlueBottle and Crewmax Chris like this.
  28. Mar 22, 2017 at 5:41 PM
    #58
    Bprose
    Bprose Old member
    VA
    17 Tundra CM TRD
    I never thought getting a hitch out of a receiver could be so amusing. I always thought the hardest part was finding the key to the lock. This has become like a show I can't wait to see what happens next.
  29. Mar 22, 2017 at 5:43 PM
    #59
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    It just might be a dud... but there is massive potential.
    Crewmax Chris and BlueBottle like this.
  30. Mar 22, 2017 at 5:47 PM
    #60
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
    Anyone suggest a cherry bomb??
    No?
    Then in that case....a cherry bomb would be really fun to watch...or a grenade if you have one!
