Removing the 3rd brake light housing
Discussion in '2.5 Gen Tundras (2014-2021)' started by flynbyu2, Feb 21, 2020.
  1. Feb 21, 2020 at 2:46 PM
    flynbyu2
    flynbyu2 [OP] I'm your huckleberry...
    NorCal
    2015 SR5 CrewMax 2WD
    Flowmaster Super 50 / Dual In - Dual Out Exhaust BakFlipG2 Tonneau Cover TRD Rear Sway Bar
    My truck is black and I’m thinking of replacing the stock 3rd brake light housing with a smoke-tinted housing with LED lighting.
    Today, I took off the stock lens to see how easy it would be to swap it out. It looks like the headliner is either going to have to be removed or at the very least pulled down to gain access the two mounting studs.
    Anybody actually done this?
    Does the headliner look “right” afterwards?
  2. Feb 22, 2020 at 11:56 AM
    SIMPLYTHETRUTH
    SIMPLYTHETRUTH THE ALBINO RHINO
    PA
    2020 Cement TRD
    S&B Cold Air Intake, Recon light bar, Rough Country light bar, Cali ditch lights, aFe throttle spacer,
    Yes headliner pulls down, also rip door seal, most back panels to get to it all because 2 screw you gotta remove. I have one and still didn’t put in in. Seems like a days work. Thinking on getting @Headlight Revolution cargo leds and lightly smoke the cover with vht or plastic dip or something in that nature.
  3. Feb 22, 2020 at 7:43 PM
    flynbyu2
    NorCal
    Yeah, that sounds like a lot of work for a little gain.
    I do have some leftover VHT Nightshades spray tint left over. I’ll probably go that route too.
    SIMPLYTHETRUTH likes this.
  4. Mar 1, 2020 at 4:55 PM
    HailstorminMT
    HailstorminMT New Member
    Hailey
    Montana
    '14 Tundra and '04 4runner v8
    lift and lights
    I bought the light and attempted to do this yesterday... it seems easy once you can actually get ahold of the nuts on the two studs holding the housing of the third brake light. I'm hoping to get this done in the next couple weeks and will try to take pics.
    This vid goes over it alright: https://youtu.be/SYtliycn_zg
    bulldog93 and flynbyu2[OP] like this.
  5. Mar 1, 2020 at 5:41 PM
    chrisbusnut
    chrisbusnut New Member
    Pasadena, CA
    2020 Tundra Crew Max SR5 4x4 w/TRD Off Road pkg
    DiamondBack bed cover, SDHQ sliders, SwitchPro, Katzkin leather seats, TRD Pro grille, TRD Pro wheels w/Nitto Ridge Grappers, Toyota OEM leather steering wheel, SSO Slimline Hybrid Bumper w/Baja Designs S8 light bar, Warn Zeon Platinum 10-S winch, Baja Design rock lights & flush mount rear bumper lights
    I’m going to be swapping out the incandescent brake and cargo light bulbs with VLEDS. So I have to remove the housing from inside the truck? On my truck, there are 4 are screws on the outside face of the third brake light. I’m hoping that I just remove those, the lens comes off and then I can replace the bulbs. Am I wrong? The truck in the video above doesn’t appear to have any screws on the outside.
  6. Mar 1, 2020 at 5:48 PM
    HailstorminMT
    Hailey
    Montana
    lift and lights
    You can change the bulbs without taking out the housing.
    flynbyu2[OP] likes this.
  7. Mar 1, 2020 at 5:56 PM
    chrisbusnut
    Pasadena, CA
    Phew...thanks!
  8. Mar 1, 2020 at 5:59 PM
    jdg1982
    jdg1982 New Member
    Florence, Colorado (From Louisiana)
    2017 Magnetic Gray Tundra SR5 4x4
    Be careful when you remove the cover. If you drop it, it will fall in between the bed and cab and is a huge pita to get out. I know from experience!
  9. Mar 1, 2020 at 6:42 PM
    chrisbusnut
    Pasadena, CA
    Thanks for the tip!
  10. Mar 1, 2020 at 6:55 PM
    Northern Exposure
    Northern Exposure New Member
    Minnesota
    2019 Tundra TRD Sport
    4.5 inch lift, coachbuilder shackles, Fuel wheels, custom grill, dual exhaust with flowmaster super 44, hard tonneau cover, S&B intake, all LED lights, light bar, throttle commander, AJT interior accessories, wireless charging center console, and more...
    I found a company that just makes smokes lenses for the tundra and did LED bulbs. Been on for over a year and no issues.
    Klearz.com
  11. Mar 1, 2020 at 9:42 PM
    flynbyu2
    NorCal
    That's the most detailed video I've seen. Thanks for posting it!
