Removing Spacer Lift
Discussion in 'Suspension' started by ahenning33, Sep 15, 2020.
  1. Sep 15, 2020 at 8:28 PM
    ahenning33
    ahenning33 [OP] New Member
    Andy
    Payson, AZ
    2014 Super White Tundra SR5 TRD
    Hello fellow 3rd gen owners,
    I've recently joined the club and purchased a 2014 Crewmax. The previous owner had installed a spacer lift on the front end of the truck and I'm wanting to remove it in favor of the Toytec Aluma coilovers, for obvious reasons. Is there any special considerations when removing a spacer or is it as simple as removing a normal shock? I've installed the Toytec Boss system on my 1st gen so I have some experience with the suspension components, but this is my first time dealing with any type of spacer lift.
    Thanks
  2. Sep 16, 2020 at 1:30 AM
    celicacy
    celicacy New Member
    Cy
    Jacksonville, FL
    2014 Tundra Crewmax
    Icon 2.5 Coilovers, Icon UCA, Katzkin Leather, LED Headlight, Nitto Ridge Grappler 305/55/20, Fuel Wheels, Trd Rear Sway bar
    Just as simple as removing the normal shock. Its mounted on top of that shock so it should be all one unit.
  3. Sep 16, 2020 at 3:09 AM
    SprinterAE86
    SprinterAE86 New Member
    Ian
    Charlottetown, PE, Canada
    2012 Toyota Sequoia Platinum
    No need to take the struts apart. Just remove the whole strut and replace with Toytec. Unless you are wanting to sell the spacer lift separate. I would just keep it together until you sell the truck and swap it out.
