Removing lower dash piece
Discussion in '2.5 Gen Tundras (2014-2021)' started by smslavin, Aug 9, 2017.
  1. Aug 9, 2017 at 4:05 PM
    smslavin
    smslavin [OP] New Member
    Hudson Valley
    2016 Tundra CrewMax SR5
    Some stuff
    I've hunted all day for info on this but I can't seem to find what I need. I'm trying to remove the lower dash piece. The one with the temp controls, cig lighters and usb port. What I've seen shows people pulling the center console then putting their fingers under the dash piece and pulling. That's not working for me. I want to pull the lighters and replace them with dedicated usb sockets.
    What's the trick to getting a hold of that thing and getting it off?
  2. Aug 9, 2017 at 5:13 PM
    MikeyMTBs
    MikeyMTBs New Member
    Pull straight back - it'll pop out. Put your thumbs in each of the 12v power plugs, grasp the side and pull straight back. It'll come.
    NewImprovedRon and smslavin[OP] like this.
  3. Aug 9, 2017 at 5:46 PM
    Over the LINE
    Over the LINE New Member
    New Orleans
    2016 Limited CM 4x4 2025 SR5 CM 4 x 4
    As I remember there are 3 or 4 clips across the top. I used a plastic removal tool. I slipped it in until the panel loosened at the top and came out easily.
    Again, as I remember I found a stereo removal video online that showed how it came out. Sorry, If I was on my desktop I have pictures and a link for the video.
  4. Aug 9, 2017 at 6:20 PM
    xj2202009
    xj2202009 New Member
    x
    Lutz, Fl
    2017 tundra sr double cab v8 5.7L black 4x2
    looking to replace factory Radio with a pioneer avix588bhs
    If you don't have the center console, you need to remove that bottom panel first then stick your fingers in the cigarette lighters pulling down and out at the same time..5bc96f7b346f17aba2fe3cb429ae2286_5d81abf6d3a924cad9394378b914c011049f4c8f.jpg
    TTund16 likes this.
  5. Aug 9, 2017 at 6:37 PM
    1UPPER
    1UPPER Not A New Member
    TEXAS
    Flux capacitor!
    If you ever want to take dash pcs off your truck I highly suggest you buy a plastic pry bar kit. One like the one attached sell for $18. These tools will make pulling your dash part out a lot easier without damaging your truck. IMG_9066.jpg
  6. Aug 9, 2017 at 7:19 PM
    Baja Mike
    Baja Mike Baja Aficionado
    South Bay, Ca.
    2016 Tundra TRD 4x4 SR5 white
    LED interior lights, Baja Designs foglights, Baja Designs S8 hood bulge light bar, LED bed lights, Baja Designs S8 amber bar in bumper on Rago Fab mounts, AMP Research bedstep, Switch Pros sp-9100, tinted door windows
    Couldn't agree more. I keep a set in my truck since these things are built like Legos. Everything just snaps into place.
    1UPPER[QUOTED] likes this.
  7. Aug 9, 2017 at 7:22 PM
    smslavin
    Hudson Valley
    Some stuff
    Yeppers. I've got one of those sets. I don't have the smaller ones though. Those look handy.
    Finally got it popped off.
    Jsena and 1UPPER[QUOTED] like this.
  8. Aug 9, 2017 at 7:22 PM
    TTU19
    TTU19 Wreck 'Em
    Wes
    Tx
    2021 TRD Sport
    Those trim tools really come in handy! I've used them to remove dash pieces, bulb covers to switch to leds, and even removing my tail light. Can be used Everywhere!
    Jsena and 1UPPER like this.
  9. Aug 10, 2017 at 8:27 AM
    Over the LINE
    New Orleans
    These are the "plastic removal tools" I was talking about.
  10. Aug 10, 2017 at 8:37 AM
    Jsena
    Jay
    Las Vegas, NV
    A Bad Bissshhhh
    Those help to pull out the plastic clips on the truck as well.. good stuff
  11. Jan 28, 2022 at 11:45 AM
    kai38
    kai38 New Member
    Kirk
    2004 4dr 2x4 TRD Tundra, 2017 TRD PRO
    Zero
    I removed my lower dash to change out the 12v outlets.
    But what is this plugged wire plugged into back of blank switch cover?
    Grey/black wires.
  12. Jan 28, 2022 at 12:29 PM
    1lowlife
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    My 2014 has that too.
    I've never been able to figure out what it was for..
    I have a few other unused plugs in the dash, but they are for options my SR5 doesn't have..
    Tundratoofun and kai38 like this.
  13. Jan 28, 2022 at 1:11 PM
    AZTundra
    Paul
    Phoenix, AZ
    My Limited has a glass break sensor in that spot. Maybe yours is pre-wired?
    1lowlife[QUOTED] likes this.
  14. Jan 28, 2022 at 1:13 PM
    kai38
    kai38 New Member
    Kirk
    Zero
    I used dash,trim removal tools worked them in between the upper line in the llower section and kept prying working across the line until it came lose.
    Tundratoofun likes this.
  15. Jan 28, 2022 at 1:50 PM
    1lowlife
    DADA
    2014 MGM DC SR5
    You're right.
    I now remember someone saying that.
    It's black and a shielded wire..
    AZTundra[QUOTED] likes this.
  16. Jan 29, 2022 at 4:41 PM
    kai38
    kai38 New Member
    Kirk
    Zero
    Finished project today, since I had 2 dual USB plugs I did the back seat too.
    Since I'm not running dual batteries yet I left them to only power on with the key.
