Removing front sway bar benefits
Discussion in 'Suspension' started by Jwood562, Apr 18, 2020.
  1. Jun 8, 2021 at 3:50 PM
    #91
    dpast88
    dpast88 New Member
    Dennis
    Furlong, PA
    2015 Tree
    Sorry I stand corrected. I did get the performance load with the smaller spring rate. After installing the new Coilovers it seems like a feel every single road imperfection. I thought this was due to a stiff coil. Maybe the Coilovers just need to break in as I have only driven 200 miles with them. I also haven’t gotten an alignment yet. I was going to wait 500 miles, retorque and then get an alignment.
  2. Jun 8, 2021 at 3:54 PM
    #92
    ohreary
    ohreary Party!
    2020 Platinum
    Is there a front or rear sway bar that is stiffer than the TRD sway bars? Personally, I like to be able to haul ass through turns.
  3. Jun 8, 2021 at 4:15 PM
    #93
    Elduder
    Elduder New Member
    Hellwig RSB is stiffer. Nothing I know of for the front.
  4. Jun 8, 2021 at 4:16 PM
    #94
    Elduder
    Elduder New Member
    Did you add tires at the same time?
    My Eibachs were very nicely balanced and then I added E load 35s, that kind of firmed them up again.
  5. Jun 8, 2021 at 4:53 PM
    #95
    dpast88
    dpast88 New Member
    Dennis
    Furlong, PA
    2015 Tree
    No I already had E rated tires prior.
  6. Jun 8, 2021 at 9:18 PM
    #96
    Jwood562
    Jwood562 [OP] New Member
    2013 Tundra 4x4
    King 2.5s custom gold rock warrior wheels 2020 sequoia LED headlights
    I left mine alone for the time being.
    TTund16 likes this.
  7. Mar 4, 2024 at 7:36 PM
    #97
    Powdigs
    Powdigs New Member
    Rich
    2016 double cab TRD off-road
    Thule racks, RCI steel engine skid, transmission skid and cat guards, RCI rock sliders, Bilstein 8112/8100, Camburg x-joint UCA, Icon RXT leafs, 18" Method 701 rims,
    Look up the moose test. A front sway bar will give you a better chance of not getting into a wreck during a high speed sudden swerve or evasive maneuver to avoid an accident. I'm not sure any added benefit of removing the front sway bar is worth the possibility of not avoiding a wreck. That being said I'm planning on running mud tires and by my same logic that's also not worth it hahaha.
