Removing Dealer Back Window Stickers
Discussion in 'Detailing' started by Riskyguy, May 4, 2018.
  1. May 4, 2018 at 7:44 PM
    Riskyguy
    Riskyguy [OP] New Member
    Stewart
    2008 Tundra SR5 DC
    The new Highlander has the stupid dealer ".Com" sticker on the back window. What is the best way to get it off? Thanks.
  2. May 4, 2018 at 7:47 PM
    rocky_mtn_trd
    rocky_mtn_trd Voided Warranty
    Jeremy
    Palmer Divide, Colorado
    2017 Tundra SR5 CM TRD
    If it's a decal on the outside, glass cleaner and a razor blade.
    joonbug and Bprose like this.
  3. May 4, 2018 at 8:06 PM
    Riskyguy
    Stewart
    2008 Tundra SR5 DC
    It is on the outside. I am worried about scratching the glass with the razor blade.
  4. May 4, 2018 at 8:09 PM
    Stumpjumper
    Stumpjumper New Member
    Fate, Tx
    2017 Tundra TSS 4x4
    Just keep blade flat to glass. I have bladed whole windshields with no problems. Do it before RainEx to get glass super clean
  5. May 4, 2018 at 8:22 PM
    Tundraplatinum
    Tundraplatinum New Member
    2016 Platinum CM
    heat it with heat gun or blow dryer and peel off with fingers
    4x4_Angel likes this.
  6. May 4, 2018 at 8:36 PM
    Over the LINE
    Over the LINE New Member
    New Orleans
    2016 Limited CM 4 x 4
    Toytec -Duratrac -Expedition One-Fab Fours
    Tell the dealer you won't sign until the stickers are gone. That's what I do.
    If you are scared of the razor blade, there are some fairly sharp and hard plastic scrapers I have found at Home Depot. A little Goo Gone will help will residual adhesive.
  7. May 4, 2018 at 8:52 PM
    joonbug
    joonbug bacon bastrd
    Joon
    NorCal - Dublin
    2015 DC 5.7 TRD off-road
    It’s almost impossible to scratch glass with a razor blade.
  8. May 4, 2018 at 9:21 PM
    gosolo
    gosolo “The .com stands for communist”, Dale Gribble
    Ray
    NW Oregon
    2"CB shackles, bushings and 1 shim, lockerdown console vault, rear folding seat back mod, snugtop shell with opening side windows, 46g fuel tank, SDHQ sliders and hidden winch, Decked Drawers, Icon leaf spring packs and got rid of the interior chrome
    Unfortunately joon this is not true. I have seen much glass scratched by razor blades. If the blades are new, sharp and fresh and used with a liberal amount of soapy water the damage is less likely. Careful use and experience helps. Ask any professional glass cleaner.
    joonbug likes this.
  9. May 4, 2018 at 9:40 PM
    joonbug
    Joon
    NorCal - Dublin
    Yeah it can be scratched, but if it’s a flat razor blade and you keep it flat on the glass, you really need to do something wrong to scratch it. Stone is a lot harder than steel. Now if you’re using a utility knife or something that won’t lay flat, and use the sharp point, that’s a lot easier to screw up.
    mudslinger79 likes this.
  10. May 4, 2018 at 9:41 PM
    Vendeta2k
    Montana
    2018 Limited Cement CM
    Heat gun.....
    Tundraplatinum likes this.
  11. May 4, 2018 at 10:36 PM
    4x4_Angel
    Bree
    Funky Town, Texas
    2014 SR5 CM Silver Sky
    Take it to an old school military cop..... they can do it for ya :D scraping base decals off a windshield so much it makes you an expert.
    But seriously... any of the above suggestions will work.... you can also try (if you or your wife are into them) lemon essential oil. It'll work on the sticky like to Goo Gone.... but better (imo) and smells better.... and of course the razor blade
    joonbug likes this.
  12. May 5, 2018 at 5:26 AM
    Riskyguy
    Stewart
    2008 Tundra SR5 DC
    Thanks for the advice guys. I ended up using a hairdryer and peeling the lettering off with my fingernail. It took about 2 minutes. I hesitated using a razor blade because my Tundra had an add-on sticky convex mirror on the left mirror. It looked bad so I removed it but there was some double stick tape residue left and I took a flat razor blade to it. I thought that I was being careful but I ended up scratching the mirror surface.
