Removing bed bolt with broken torx teeth
Discussion in '2.5 Gen Tundras (2014-2021)' started by PNWtundrite, Feb 2, 2025.
  1. Feb 4, 2025 at 9:13 PM
    lr172
    lr172 New Member
    07 DC
    I had that issue. Incompetent tech had stripped the head . I went under the truck and aggressively heated the captive nut that the bolt went into. Was able to get them out with just vice grips. Always use heat on problems like this.
  2. Feb 4, 2025 at 9:29 PM
    PNWtundrite
    PNWtundrite [OP] New Member
    2010 Tundra TRD rock warrior black
    Demello front number with winch and lights, Bilstein 5100 Eibach spring 3" front lift and 5100 rear 2" lift, Android auto stereo with front camera
    Steel pipe from the hardware store best extension ever you could also wrap some electrical tape around the handle to get it a little bit more snug further down if you need to for extra leverage.
  3. Feb 4, 2025 at 9:32 PM
    PNWtundrite
    Nope getting new ones for both back bolts. Would like to eventually take off the entire bed and do some rust corrosion prevention.
  4. Feb 4, 2025 at 9:32 PM
    PNWtundrite
    Only harsh language is used when the head stripped out LOL that pipe wrench grips hard!
  5. Feb 5, 2025 at 4:22 AM
    Roborob70
    Roborob70 New Member
    Robert
    18 Toyota Tundra TRD
    Catch it with a punch.
  6. Feb 5, 2025 at 5:12 AM
    rjls
    rjls New Member
    I would also use a rust penetrating fluid as well.
    Double DC[QUOTED] likes this.
  7. Apr 25, 2025 at 7:27 PM
    Ero2
    Ero2 New Member
    I was going to back mine out today to see if I could get rid of some creaking in the bed but with it covered by the spray in bed liner I’m unsure if I should touch them/break the spray in seal?
  8. Apr 26, 2025 at 11:45 AM
    d33pt
    d33pt New Member
    I had to do that to remove the bed. You just need to get a razor and cut around them carefully, then jab it with a pick or awl and pull it off the bolt head. It should come off clean.
  9. Apr 26, 2025 at 3:01 PM
    Ero2
    Ero2 New Member
    Glad I asked as I was going to try the T55 and see if an impact would just break the liner once I cut around it with a blade, lol.
    I don’t understand why they sprayed over it in the first place…there’s no other way to loosen/grease the bed bolts without doing the above right?
    Thanks for the advice!
  10. Apr 26, 2025 at 3:04 PM
    Rakkasan
    Rakkasan New Member
    NorCal
    2020 Tundra- cement-crew max 4x4
    Spray in Bed liner, 2-10”subs/400w.amp, tailgate shock, Tinted windows, seat covers, dash cover, CatShield, Fuel D538 20”wheels, Husky custom floor mats, TSC tool chest, leather seat covers. Genuine Cooling systems transmission cooler, scan gauge OBD2
    if you're careful not to cut into the bed liner you can cut two straight edges on the bolt head perimeter with a grinder and cutting disc and use a crescent wrench or if you measure first, can cut to spec, say 3/4" wrench
  11. Apr 27, 2025 at 11:32 AM
    d33pt
    d33pt New Member
    Yeah that's the only way to take those bolts off. It's just lazy from the liner shop. They should've taken the bolts off then spray. You can keep the pieces you cut out as plugs to put back in once you're done. They come off in one piece usually and have the torx imprint on them.
