Removing (and possibly replacing) Black Out Tape?
Discussion in '2.5 Gen Tundras (2014-2021)' started by Sas, Jul 29, 2018.
  1. May 5, 2019 at 9:16 AM
    ridgwel
    ridgwel New Member
    LYNN
    2008 Tundra Limited
    Zapp, not a bad idea. Do you know if vinyl wrap can stick to something like weatherstripping? Do you happen to know where I could find "color matched vinyl wrap" in such a small quantity? Thanks
    Mountun Goat likes this.
  2. May 5, 2019 at 9:23 AM
    Mountun Goat
    Mountun Goat She baaaaaahd
    EhBerta, Canadia
    It’s a Goat.
    What color is your truck?
  3. May 5, 2019 at 9:25 AM
    ridgwel
    ridgwel New Member
    LYNN
    2008 Tundra Limited
    Salsa Red (3Q3)
  4. May 5, 2019 at 9:28 AM
    Mountun Goat
    EhBerta, Canadia
    It’s a Goat.
  5. May 5, 2019 at 9:31 AM
    ridgwel
    ridgwel New Member
    LYNN
    2008 Tundra Limited
    That is another good idea! I wonder how long paint on weather stripping would last? But it could be worth a try. Thanks
  6. May 5, 2019 at 9:31 AM
    Mountun Goat
    EhBerta, Canadia
    It’s a Goat.
    Try it out! I want to see how it looks!
  7. May 6, 2019 at 9:06 AM
    ridgwel
    ridgwel New Member
    LYNN
    2008 Tundra Limited
    I haven't found a good reason not to remove the weatherstrip, so I did it. Here are pictures with it removed.
    I did put some buttons in the clip holes. I will now just drive it for a while to see if there is any rain leakage or additional wind noise (I'm hard of hearing so I doubt that I will hear any additional noise). As you can see from the picture, those buttons are visible between the doors when they are closed.....so, my plan is to get a thin strip of aluminum (say 1"x20"x1/16") and have it painted body cover and attach it over the holes with double-sided molding tape.....giving a smooth reveal. The worst that can happen is that I re-install the weatherstrip.....which right now is the last thing I want to do. That's the plan......we'll see how it goes. I'll post the results when the final results are in.
    EDIT: The next pictures will be with "blackout" removed as well.
    Mountun Goat and jewsNbrews like this.
  8. May 7, 2019 at 7:47 AM
    Rockgate
    Rockgate New Member
    Terry
    Middle TN
    2022 CMLB TRD OR Prem. 4X4 and 2002 RCLBV65Spd
    Here's an off the wall idea why the rubber is there instead of blackout tape. Maybe in the absence of the rubber, it whistle'. Let us know.
  9. Jun 9, 2019 at 2:26 PM
    ridgwel
    ridgwel New Member
    LYNN
    2008 Tundra Limited
    IMG_2790.jpg Well, I finally got my 2008 Limited TRD Tundra back from the detailer. Here she is completely de-badged, de-chromed, black vinyl removed, and polished up. I love the new look and with a ceramic coating, she IS SLICK! In both senses.
    ....and Rockgate....no whistle noises. I took her up to 80 and all is good!
    EDIT: That's the original paint! Well, except the items that were de-chromed! So if any paint was going to show signs of not seeing daylight before now, none did! Not behind the badges, the TRD decal, nor the black out vinyl.
    Mountun Goat, jewsNbrews and Rockgate like this.
  10. Jun 9, 2019 at 2:56 PM
    Rockgate
    Rockgate New Member
    Terry
    Middle TN
    Looks good. I like the looks of it without.
    jewsNbrews likes this.
  11. Jun 19, 2019 at 9:31 AM
    ridgwel
    ridgwel New Member
    LYNN
    2008 Tundra Limited
    Here's the "final touch".......the holes that held the weather stripping between the doors have been covered up with 1"x 1/16" strip of aluminum painted and taped into place.
    Mountun Goat, jewsNbrews and JTL like this.
  12. Jun 19, 2019 at 9:45 AM
    ToyotaTundraMike
    2015 Tundra
    What’s the point of removing the weatherstrip? My truck came without the pillar tape and you couldn’t tell the weatherstrip was even there with the doors closed. Plenty of pics in my build thread in my signature of before and after I added the pillar tape. Looks kinda funny without the strip there when you have your doors open.
    Edit: final pic looks better but still not sure the point?
  13. Jun 19, 2019 at 9:57 AM
    ridgwel
    ridgwel New Member
    LYNN
    2008 Tundra Limited
    Mike,
    I guess it's a matter of taste. I could have left the weather stripping on, but I liked the look without it. I'm sure you like the looks of your Tundra and I like the looks of mine.
    But I think your comment will help others that are considering removing the black vinyl. Thanks
  14. Jun 19, 2019 at 10:05 AM
    ToyotaTundraMike
    2015 Tundra
    You can see the weatherstrip with doors closed? Never noticed it when I had my pillars off. Interesting. To each their own I guess, definitely looks better now that you covered up the holes etc
  15. Jun 19, 2019 at 10:29 AM
    ridgwel
    ridgwel New Member
    LYNN
    2008 Tundra Limited
    Yes you can......and that's the reason I removed it. But, it's a matter of taste. Here's what it looks like with the doors closed. It's pretty much a non-event, but I just liked it better. Leaving the weatherstripping on may give you a little less wind noise. I tested my Tundra without the weatherstripping before I chose to do what I did. I didn't see much difference......but then I need hearing aids! LOL
  16. Jun 19, 2019 at 11:06 AM
    Pudge
    CT
    2015 Blue Ribbon Platinum
    How hard will it be to put gloss black vinyl over the top of what's there already. Or should I remove the current vinyl and apply new pieces right to the painted surface. I have never done any kind of wrap. Precut pieces would be a good idea for any vinyl guys out there, or at least rough cut @DecalsByDesign
  17. Jun 21, 2019 at 7:20 AM
    DecalsByDesign
    DecalsByDesign Vinyl Connoisseur
    Eagle, CO
    2019 Quicksand Limited Double Cab
    Toytec Performance Aluma 2.5 Kit Nitto G2 295/70-18 Method MR306 18x9 +18 Kenwood DDX6906s Carven TR Muffler w/ Y-Pipe
    I’m retiring, I am 2 months out on wraps right now and just losing my mind. Vinyl can be bought at metrorestyling.com or fellers.com . I’ll tell you now that flat objects are simple to wrap. it might take you a few try’s, but that’s the beauty of paint vs vinyl. My top material is Avery Dennison.
    Pudge[QUOTED] likes this.
  18. Jun 21, 2019 at 8:07 AM
    TRD-tv
    TRD-tv Menace2Ohio
    Cleveland OH
    2012 MGM Tundra TRD
    Imo it looks terrible without the black vinyl
  19. Jun 21, 2019 at 9:20 AM
    #49
    CMB
    CMB New Member
    Cecil County MD.
    2010 Tundra DC 4X4 SR5
    Not nearly enough room here!
    0516190743[3742].jpg One more option, I replaced my blemished pillar tape with 'Carbon Fiber' look molding from E-Bay. Made by Di-Noc. $50 for my 2010 and it's removable with no mess.
  20. Jun 21, 2019 at 10:25 AM
    #50
    Pudge
    CT
    I may try gloss black over what's there already. I haven't done any wrap before other than fog light laminex. I think I can get enough wrap for like $20 to try it. Maybe I'll order a light smoke too for my tail lights
  21. Jun 22, 2019 at 6:37 PM
    #51
    JTL
    JTL New Member
    Jon
    Phoenix, Az
    '17 MGM Platinum
    Trd CAI, Trd Dual Exhaust, ESP Locking storage, Center Console Safe, Trd Rear Sway Bar, BFG Ko2, Pioneer Avic 8400nex, Husky Liners, 19 Trd Headlights, iHacker Harness, Tech12Volts Sub Upgrade
    People have a hard time with the tail lights due to the little fin. Keep them on the truck so you have leverage to stretch it. Good luck with it. Reading around in the forums most people give up on diy tail light tinting. Look forward to seeing your results!
    Pudge[QUOTED] and jewsNbrews like this.
  22. Jun 23, 2019 at 12:51 AM
    #52
    Pudge
    CT
    Yeah the fins look like they will take me down. I'll try but am not expecting terrific results.
  23. Jun 25, 2019 at 8:29 PM
    #53
    Pudge
    CT
    B pillar gloss vinyl. Very simple mod and I like the look over the OEM satin finish
    cmiller219, JTL and jewsNbrews like this.
  24. Jun 25, 2019 at 9:25 PM
    #54
    jewsNbrews
    Jewiston Idaho
    2019 TRD PRO
    Bolt on
    That looks sharp!
