Remove leveling kit? and a couple other things
Discussion in '2.5 Gen Tundras (2014-2021)' started by willdmckeown, Feb 25, 2019.
  1. Feb 25, 2019 at 1:23 PM
    willdmckeown
    willdmckeown [OP] New Member
    Will
    2016 5.7 tundra double cab trd off road, bench seat
    2 inch leveling kit, piggy back tune
    Hey team I hope all is well :) the mrs has had her truck for about 2 or 3 weeks now :)
    im still in new zealand and have not see the new truck yet :( but cant complain as summer is epic :)
    still looking for any column shift mods (its so long and ugly lol) let me know :p :D
    couple quick things
    her truck has a slight high pitch whistle when accelerating on the highway. the internet seems to things its the filter on the throttle body so i was going to by one without the filter on it and put that in.
    there is a tiny tiny squeak when its a cold morning and put the truck into reverse for the first time. I was told we just need a little geese behind the break pad?
    all the interior lights dont work. have done everything with the switches. on, off,door ect. bed light works. im a summing its this fuse problem.
    https://www.tundras.com/threads/blown-fuse-from-led-cabin-lights.7476/
    The main point the 2 inch leveling kit :)
    I think the level looks super cool but the truck rides a little stiffer then our old 2010 sr5 trd off road and the mrs can deal with it but im sure we would like the ride a little softer
    she has 2 horses and she will trailer them around and ride pretty much every weekend
    and well shes really short lol 5 foot 0 and has super short legs and pretty much has to climb into the truck even with the running boards
    so for all of that we were thinking of taking it to the bros tuck guy and getting the kit taken off
    what do you think? worth taking off? how much should it cost to remove?
    thanks team have an epic day :)
  2. Feb 25, 2019 at 2:32 PM
    040Tundra
    040Tundra Teddy 2013-2019
    Aaron
    Las Vegas, NV
    040 '16 CM LTD 4x4
    From what you written here I would def take off the spacer lift. I just had the spacer lift removed from my truck but for different reasons. It shouldn’t cost anymore than $150 to remove. Make sure you have them give you the parts back so you can resell if you’re into that kinda thing.
    As far as the lights, I think you’re correct in assuming it’s the fuse(s). I replaced mine with all LED’s and haven’t had any problems with it for 2.5 years now (knock on wood).
    Good luck!!!!!
  3. Feb 25, 2019 at 2:59 PM
    Berdine
    Berdine Voodoo Sport
    Binghamton, NY
    2020 VooDoo Blue Trd Sport
    There are 2 fuse panels to check. Under hood and under dash on drivers side above e-brake
    For the lift, if you like it, good cheap solution would be replace with bilstein 5100s, you have 3 height settings, more improved ride over the spacers.
  4. Feb 25, 2019 at 3:17 PM
    JTL
    JTL New Member
    Jon
    Phoenix, Az
    '17 MGM Platinum
    Trd CAI, Trd Dual Exhaust, ESP Locking storage, Center Console Safe, Trd Rear Sway Bar, BFG Ko2, Pioneer Avic 8400nex, Husky Liners, 19 Trd Headlights, iHacker Harness, Tech12Volts Sub Upgrade
    Take it off and sell the spacer like 040Tundra said. Bilstein 6112 might be your cheapest choice if you want the level with a better ride quality
