Remove front companion flange removal help
Discussion in '2.5 Gen Tundras (2014-2021)' started by zpoulsen, Apr 5, 2020.
  1. Apr 5, 2020 at 1:07 PM
    zpoulsen
    zpoulsen [OP] -
    Indiana
    2016 Tundra TRD PRO
    I have a seal leaking behind my transfer case front companion flange. I took the driveshaft out thinking I would just have to remove the nut and pull the flange off to replace the seal but there is no nut. Im kinda confused because I am not able to get the flange out with pry bar and dont want to try to get it off with a puller and break something. Anyone have any experience with this? Searched the web and couldnt find anything. Here is a pic of what im looking at. A1EABC24-7F84-4845-BD0E-F37F3A1B0905.jpg
  2. Apr 5, 2020 at 3:11 PM
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Is it pressed on?
  3. Apr 5, 2020 at 4:01 PM
    zpoulsen
    zpoulsen [OP] -
    Indiana
    2016 Tundra TRD PRO
    Im 698D000B-413F-4345-A4A9-6A7955D614D9.jpg D6A74276-0940-43E9-B9D0-D394C6916E44.jpg
    I dont know. I dont want to try to just pull it. Was looking at some parts diagrams and there might be a retaining ring inside but im not sure if thats to keep a bearing in.
  4. Apr 5, 2020 at 5:00 PM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Looks like you're right. That shaft ain't going anywhere until the snap ring is removed but how?
  5. Apr 5, 2020 at 5:03 PM
    zpoulsen
    zpoulsen [OP] -
    Indiana
    2016 Tundra TRD PRO
    Well looks like Im gonna have open up the transfer case. Maybe someone has done this seal and has more info on it.
  6. Apr 5, 2020 at 5:18 PM
    chickunfut
    chickunfut Low-buck Ramp Truck
    Fort Worth, TX
    2007 Tundra Crewmax
    Those typically come off with a pry bar between the flange and case. When you put enough force on it the snap ring will pinch down in the groove of the shaft so you can slide the shaft out. GENTLY pry and it “should” come out. Bump bump wiggle wiggle kind of motion..
    equin and texasrho83 like this.
  7. Apr 5, 2020 at 5:22 PM
    zpoulsen
    zpoulsen [OP] -
    Indiana
    2016 Tundra TRD PRO
    Ill have to check the vent and make sure its not blocked up and getting pressure before I start taking stuff apart.
    Mr Badwrench likes this.
  8. Apr 5, 2020 at 5:25 PM
    zpoulsen
    zpoulsen [OP] -
    Indiana
    2016 Tundra TRD PRO
    I tried with a pry bar but not a whole lot with not knowing how it worked. Thanks. Have you replaced this seal before? I couldn’t find anything online about that seal being replaced.
  9. Apr 5, 2020 at 5:53 PM
    chickunfut
    Fort Worth, TX
    2007 Tundra Crewmax
    Haven’t done this exact one but I have worked on several similar output shafts designed the same way. May have to find a way to tap it a bit from behind.
    Sometimes there’s a bit of play that will allow you to push the flange IN a hair. Then tap it OUT from there.
  10. Apr 5, 2020 at 6:10 PM
    zpoulsen
    zpoulsen [OP] -
    Indiana
    2016 Tundra TRD PRO
    there is a little bit of play but not much. Maybe 1/16 of an inch. Ill mess with it a little bit more, see what I can mess up lol. Thanks
  11. Apr 7, 2020 at 8:09 AM
    zpoulsen
    zpoulsen [OP] -
    Indiana
    2016 Tundra TRD PRO
    Well after a couple of calls and buying TIS for 2 days to see exactly how to get the front flange out to replace the seal I figured it out. You have to open up the transfer case in order to remove the snap ring and then you can pull the flange out. A lot of work for 1 seal.
    equin, texasrho83 and YardBird like this.
  12. Apr 7, 2020 at 8:32 AM
    Sumo91
    Sumo91 Busy with projects
    TN
    2014 MGM Tundra Platinum 4x4
    If you're gonna split the case open it probably wouldn't hurt to replace all the seals. If that one is already leaking the others may not be far behind.
  13. Apr 7, 2020 at 1:52 PM
    zpoulsen
    zpoulsen [OP] -
    Indiana
    2016 Tundra TRD PRO
    Ya all seals will be. Might as well while its all apart.
  14. Jun 20, 2020 at 1:01 PM
    UTTundra
    UTTundra New Member
    Lou
    Utah
    Yea, mine started leaking last year. Toyota quoted around 1800+ to replace that seal. I've just been monitoring the levels. Sometimes it doesn't leak for awhile.
  15. Mar 16, 2023 at 9:28 PM
    EndlessWinter77
    EndlessWinter77 New Member
    2014 4.6 SR5 TRD Graphite
    Decked, Racked, Covered
    Reading through this thread it appears that you opened up your t case and replaced seals. If so, wondering if you might be able to provide any more details on what it took to accomplish? Was there anything special about opening and re-sealing to make sure the gears/timing didn't get screwed up? Im looking to do the exact same repair. Thanks, there's not much other info on this out there....
  16. Jan 8, 2024 at 6:30 PM
    831mic
    831mic 2016 DC TRD PRO
    California
    '16 DC TRD PRO
    bumping this thread.
    I have the same type of leaking seal, and looking to see if I can knock this out at home, or if it's better to just pay a shop.
  17. Jan 8, 2024 at 6:48 PM
    equin
    equin Texarican Tundra
    Ed
    DFW, TX
    If you do it yourself, please post any additional details for those of us who may have to tackle this in the future.
    831mic[QUOTED] likes this.
  18. Oct 23, 2024 at 2:31 PM
    MDNyota
    MDNyota New Member
    2014 Tundra Crewmax
    zpoulsen or anybody else who has succesfully done this repair, any words of advise? Mine has been leaking for a while temporarily fixed with AT-205 RE-Seal (no noticeable ill effects) but just got back from a hunting trip and its now pucking fluid. Would love some input or parts list. Thanks
