Remote Starter - 12 Volt Solutions ...
Discussion in 'General Tundra Discussion' started by Bob S, Oct 20, 2018.
  1. Dec 15, 2018 at 2:12 PM
    Fishman57
    Fishman57 New Member
    Wayne
    Bucks County, PA
    Shoot an email to 12 Volt Solutions. Also, give them a call. They may get back to you quickly even though it's outside of their advertised hours.
  2. Dec 15, 2018 at 2:34 PM
    MisterTundra
    MisterTundra New Member
    MGM CM
    K thanks. Will do. I just noticed that the sequence, Unlock-lock-lock-lock works.
  3. Dec 15, 2018 at 3:15 PM
    CMENT_GREATNESS_4x4
    CMENT_GREATNESS_4x4 New Member
    Rob
    San Antonio TX
    2018 Cement TRD 4x4 Offroad Tundra
    Husky Weatherbeaters, Driver side grab handle, Nox-Lux kit... so far
    Since it is all plug and play, it seems like a programming issue. Might be worth unplugging and doing the program sequence again per their YouTube video. If you got the patience then yea reach out to them and see what they say. Hopefully you get it solved.
  4. Feb 18, 2019 at 1:26 PM
    phonyteachr
    phonyteachr New Member
    2018 SR5 TRD off-road CM
    Hello. I was reading over this earlier post and I just installed the 12 volt remote start and have the same issue you had...starts with 3 clicks but won't unlock from key fob only key lock. What was your remedy for this issue?? Thanks in advance.
  5. Feb 18, 2019 at 7:34 PM
    Geezer
    Geezer New Member
    Heart of the Catskills
    2019 Tundra Limited
    Take a look at post #4 above in this thread, something about using the wrong socket for the TPMS plug during install.
