Remote start
Discussion in '2.5 Gen Tundras (2014-2021)' started by SDNY, Nov 13, 2016.
  1. Aug 27, 2017 at 6:09 PM
    #91
    Midnighttaco08
    Midnighttaco08 High Quality H2O Inspector
    Sam
    Gilbert, AZ
    2017 Quicksand TRD OR 4x4 2008 Indigo Ink Tacoma TRDOR
    None yet!
    Maybe lack of hood pin is making it think the circuit is open?
    Have to program for no hood pin?
  2. Aug 27, 2017 at 6:15 PM
    #92
    Tundra Fan
    Tundra Fan Got 17's?
    Toby
    Nor Cal (Placer Co.)
    I don't want to turn it off, I didn't even realize it did this until today. You must be right, it must have been setup/flashed this way before it was sent to me. I'm totally okay with it.
  3. Aug 27, 2017 at 7:38 PM
    #93
    BlueBottle
    BlueBottle not a PRO
    '16 Platinum 4x4
    See fine print
    If you look at the latch mechanism there is a wire connected to it. Might be part of the canbus system.
  4. Sep 9, 2017 at 10:34 AM
    #94
    iHacker
    iHacker SW TRD PRO
    Mario
    TRD PRO Super White CM
    2019 TRD PRO LED Headlights, 2019 TRD PRO Rigid LED Fog lights, All LED Interior, LED Cargo Lights, Bed LED Lights, Undercover Flex, Husky Weather beater floormats, FORTIN EVO ONE remote start, TDR Cold Air Intake, Tundra tail gate inserts, Pop & Lock...
    Bulldog_tundra likes this.
  5. Sep 9, 2017 at 12:31 PM
    #95
    Bulldog_tundra
    Bulldog_tundra New Member
    USA
    2006 Double Cab
    Bilstein 5100 (Top Notch Front) 1” Rear Block Flowmaster 40 w/ 3” Tip Bumperplugs Front Plate Delete
    This is the step by step I used and it was spot on, thank you so much for doing all that work.
    The instructions that come with the kit say you need at "least" the version of firmware he uses in this video, but it won't work. You have to use the most recent version.
    iHacker[QUOTED] likes this.
  6. Sep 12, 2017 at 11:26 AM
    #96
    Red Freighter
    Red Freighter Red Freighter
    Oregon City
    2013 double cab sr5 trd red
    2014 TRD wheels and TRd pro center caps. Stock 2014 running boards. Stereo gps dvd deck two 12" subs w/amp. Dvd Headrests. Rear air bags with compressor and air tank.
    I found these install instructions and now I'm planning on having the dealer do it.
  7. Sep 12, 2017 at 5:32 PM
    #97
    this one?
  8. Apr 21, 2018 at 11:43 PM
    #98
    blackychan15
    blackychan15 New Member
    Victor
    Chicago
    2015 Black Tundra TRD
    Leveling Kit, Rims & Tires , Fender Flares
    I am looking for this vender on ebay but can't find them, can you post a link to them or it?
    #98
  9. Apr 21, 2018 at 11:49 PM
    #99
    blackychan15
    Victor
    Chicago
    Can you help with a link I can't find them on ebay.
    #99
  10. Apr 22, 2018 at 11:48 AM
    #100
    borntostun
    borntostun New Member
    Hi all.
    Time for a quick question? Doing the 12volt.solutions plug and play remote start install today . . . the main install unit went well . . . did anyone happen to install the phone module as well? . . .I'm running into an issue with that . . .
    All of the steps seemed to work, lights are on and solid, but the app still has all of the functions greyed out. The GPS locater works, but nothing else.
    I am assuming that I need to sign up for the service somewhere? Any ideas? Thanks.
  11. Apr 22, 2018 at 12:18 PM
    #101
    borntostun
    Figured out how to remove it from stand alone . . . but nowhere in the 12volt.solutions instructions does it say which protocol to select?
  12. Sep 20, 2018 at 7:42 PM
    #102
    Geargal13
    Geargal13 New Member
    2015 Tundra limited
    Hey y’all I’m new user. I just got a 2015 tundra limited and wanted to put a remote start in it. I went with the compustar cm900-as and compustar prime T9 2-way remote upgrade kit. It didn’t come with install instructions but did come with wiring schematic. I got it off of Amazon so it didn’t come straight from compustar. Does anyone have the install instructions for this model and or Does anyone know if there is something else that they don’t send with that I need?
  13. Aug 25, 2020 at 5:06 PM
    #103
    AggiePhil
    AggiePhil Texas Chapter President
    College Station, TX
    2020 Smoked Mesquite Platinum 4x4
    Can someone with a push button start Tundra confirm that the Fortin unit allows you to enter and take control of the vehicle without the engine shutting off?
    TundyManFL and DIYDad like this.
