Remote Start
Discussion in '2.5 Gen Tundras (2014-2021)' started by Hulkster529, Nov 4, 2019.
  1. Nov 4, 2019 at 4:15 PM
    Hulkster529
    Hulkster529 [OP] New Member
    Ohio
    2018 SR Double Cab
    Running Boards, Delay Wipers, Interior Green LED Lights, Bug Shield, Bed Rail System Factory Fog Lights, Black Wheel Skins, Remote Start, FRAC System, 33% Tinted Glass, Heated Seats,Leveling Kit, Factory Entune Nav System, Spectre Air Box , Drivers Side Grab Bar, Window Vent Shades
    Looking to add remote start to my 2018 SR with key start. Any advise on a good setup? Mine has the “H” key.
    Beesta likes this.
  2. Nov 4, 2019 at 4:18 PM
    DvilleMafia
    DvilleMafia New Member
    DFW
    2018 Tundra SR5 4x4
  3. Nov 4, 2019 at 4:27 PM
    19TurdPro
    19TurdPro New Member
    2019 Tundra TRD Pro
    I have this:
    https://smile.amazon.com/Start-X-Re...x+remote+starter+tundra&qid=1572913502&sr=8-1
    Along with this ($105 is a good deal, it won't last long):
    https://smile.amazon.com/Audiovox-A...f=sr_1_1?keywords=ascl6&qid=1572913543&sr=8-1
    The remote start is a Fortin Evo One. A lot of guys here use it.
    The telematics module is called an ASCLR Car Link, or My Car.
    Beesta likes this.
  4. Nov 4, 2019 at 4:45 PM
    Hulkster529
    Ohio
    2018 SR Double Cab
  5. Nov 5, 2019 at 4:39 PM
    19TurdPro
    2019 Tundra TRD Pro
    It's a cell module for the remote start. It's not necessary, but it allows me to start my truck with an app on my phone, and track it via GPS.
  6. Nov 6, 2019 at 8:06 PM
    Jsnake89
    Jsnake89 New Member
    Dane
    2019 Tundra TSS SR5 8W2
    Bilstein 5100 3/1 Pro Comp 1" Blocks, 12Volt Remote start.
    I got the one from 12voltsolutions.com for 19, and Inatalled it myself. Worked with my stock H key from about 300ft away.
    GasGuzzler likes this.
  7. Nov 8, 2019 at 6:39 AM
    Boomer3
    Boomer3 New Member
    ROB
    2018 BLUE TOYOTA TUNDRA LIMITED
    6" ROUGH COUNTRY SUSPENSION LIFT, LONESTAR OUTLAW WHEELS, 35/12.50R20 CROSSWIND A/T TIRES.
    12V SOLUTIONS. INSTALLED ONE OF THESE IN MY 2018 LIMITED. PLUG & PLAY, AND EASY TO PROGRAM. I AM NOT MECHANICALLY INCLINED, SO IT TOOK ME ABOUT 3 HRS.
  8. Nov 13, 2019 at 12:03 PM
    Hulkster529
    Ohio
    2018 SR Double Cab
    Ended up going with Viper with the phone app. Thanks for everyone’s input.
    jptshadow likes this.
  9. Nov 13, 2019 at 12:08 PM
    PJR202
    PJR202 New Member
    I am very mechanically inclined and it took me 5 hours. At least one of those was spent trying to unplug ONE plug because i'm an idiot.
    I could do the whole thing again in less than an hour, including the one wire I had to splice. Everything tends to take me three times as long as it should.
    pearlpower likes this.
  10. Sep 25, 2020 at 9:12 AM
    TelemarkTumalo
    TelemarkTumalo New Member
    Mark
    Bend, OR
    2020 Tundra TRD Pro Double Cab Army Green
    Driver side grab handle Door sill protectors Falken WildPeak 295/70 R18 X-Pel clear front paint protection 20% front window tint Go Rhino RB20 side steps - Bedliner finish Lock'er Down 1/2 console safe Toyota bed cargo divider Toyota auto tail gate lock
    I'm installing a 12V Solutions remote start on my '18 Tundra tomorrow. Any advice before I get started? :cool:
  11. Sep 25, 2020 at 1:15 PM
    Beesta
    Beesta New Member
    Jay
    Loudoun County
    2019 Pro Midnight Black Metallic
    Hey guys ... i just downloaded the Toyota app .... have you found a way to using 12V solution remote start on the app ..? I really hate hearing my pop a lock in my tailgate click 3X ...
  12. Sep 25, 2020 at 1:16 PM
    Beesta
    Beesta New Member
    Jay
    Loudoun County
    Disconnect the batt ... its very simple .. route your wires neatly away from any moving parts ..
  13. Sep 25, 2020 at 2:06 PM
    19TurdPro
    2019 Tundra TRD Pro
    You need this: https://www.amazon.com/dp/B07H9FLDCD/ref=cm_sw_em_r_mt_dp_QULBFb987RHHK
    Keep it on your watch list, or call around to local shops. I paid 80 for mine from a local shop, and I've seen the prices as low as $90 on Amazon.
    EDIT: You still won't be able to use the Toyota app, but Carlink has its own.
    Beesta[QUOTED] likes this.
  14. Sep 25, 2020 at 2:57 PM
    PJR202
    PJR202 New Member
    There's a point where you unplug one of the harness plugs up high and to the left. the release is a flimsy little thing. I pulled on that stupid plug and used a screwdriver and all, and never noticed the little flap. came right out once i found it....an hour later.
  15. Sep 25, 2020 at 2:58 PM
    PJR202
    PJR202 New Member
    and check the Tmobile coverage map to make sure you have service. if you don't, it wont work from the phone if you got the phone module.
  16. Sep 25, 2020 at 3:30 PM
    jptshadow
    jptshadow New Member
    Question with the remote start, can it setup to where the AC would be blasting? Or I'll have to turn all that on before I shut the car prior?
  17. Sep 25, 2020 at 3:40 PM
    19TurdPro
    2019 Tundra TRD Pro
    You need to blast it before you turn the vehicle off (auto climate control). Manual control it doesn't matter when you crank it up, but it needs to be manually set. There's no way to wire it do it automatically.
    TelemarkTumalo likes this.
  18. Sep 25, 2020 at 3:44 PM
    19TurdPro
    2019 Tundra TRD Pro
    Not sure tech 12 volt sells a different Carlink, but mine uses AT&T 4G LTE
  19. Sep 25, 2020 at 4:35 PM
    Beesta
    Beesta New Member
    Jay
    Loudoun County
    Thanks man .. ill look it up
  20. Sep 25, 2020 at 4:36 PM
    PJR202
    PJR202 New Member
    I bought mine in August of 2019. My phone is ATT, but the carlink module itself runs off the T-Mobile network. I didn't even know that initially. So my connection to the module was sketchy from inside the house sometimes, and now it's non-existent. I emailed the manufacturer and they told me about T-mobile and that coverage in my area was listed as "fair" in the T-mobile network, and they can't help me beyond that. I can go a couple miles from the house and it works fine. Luckily, I'm within keyfob range at home anyway.
  21. Sep 26, 2020 at 2:46 PM
    Linuxmale
    Linuxmale 2018 Tundra 2003 Tj
    Sault Sainte Marie, MI
    2018 CREWMAX TRD Off Road ( a Canadian import )
    I just installed the 12 volt solutions 100% plug and play kit in my H key 2018 Crewmax. It works great but i forgot about the auto lights.. so here i go back out to the driveway.
    For the OP. If you go with the 12 volt solutions, Don't follow the video for the 2018 that has you take the knee area airbag off. You don't need to.
  22. Sep 26, 2020 at 5:48 PM
    TelemarkTumalo
    Mark
    Bend, OR
    Oh man that sucks. Hopefully, you were able to get the wire cutters on there without dismantling everything. I did my install today and it went very smoothly. I admit that I am not the most confident with electronics, but I had no trouble. Working like a charm.
  23. Sep 26, 2020 at 7:47 PM
    Linuxmale
    Yup, it was easy. That kit sure is pretty great. I got mine for $50 off too. It works better than the "pro" installed one we have in the Minivan.
  24. Sep 27, 2020 at 10:35 AM
    Bdebs
    Bdebs Don’t Threaten Me With A Good Time!
    2020 Limited Crewmax TRD Offroad
    TRD Rear sway bar, Bilstein 6112, Bakflip MX4 Tonneau Cover
    I’m selling my car link if anyone is interested
