Remote Start Question
Discussion in '2.5 Gen Tundras (2014-2021)' started by msg148, May 10, 2015.
  1. May 10, 2015 at 5:45 PM
    msg148
    msg148 [OP] Hulk Smash
    Philadelphia
    15 Tundra Platinum Package
    7" BDS coilover lift kit w/Fox front and rear suspension, 20" Monster 2 Rims, 37" Deegan Tires, TRD Exhuast, TRD Intake, Bushwacker Pocket Flares, Blacked out Mirrors/Door handles, LED interior lights, Stubby Antenna, Bakflip F1 Tonneau Cover, 20% Tint Front windows
    I have the remote start option on the Tundra. I can start it via the remote no problem, but in order to get into the truck I have to hit the unlock button. This subsequently turns the truck off. Does anyone know if there is any way to keep the truck on while I unlock the door?
    Seems like this should be the case, but as for now it does not seem like it.
  2. May 10, 2015 at 5:55 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Aftermarket remote start.
  3. May 10, 2015 at 6:29 PM
    That sounds odd.... I will be going with an after market one for more options.
  4. May 10, 2015 at 6:29 PM
    msg148
    Philadelphia
    Factory
  5. May 10, 2015 at 6:31 PM
    msg148
    Philadelphia
    If I would have known, I would have done the same.
  6. May 10, 2015 at 6:32 PM
    I did some quick web browsing ...looks like this is common and is not a "problem" but set by Toyota to do that.
  7. May 10, 2015 at 6:35 PM
    msg148
    Philadelphia
    That is what I found but did not want to believe it. I've had many other factory remote starts and never had a similar issue.
    Thanks for the help.
  8. May 10, 2015 at 6:48 PM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    I have heard this complaint from co workers and friends with their vehicles. Safety feature I guess.
    I will also opt for an aftermarket one if it allows me to keep the truck running. Also want the feature of having AC or heat on with remote start.
  9. May 10, 2015 at 6:53 PM
    On my last remote start I wound just leave the Ac or heat on before I exited..the remote had the option to view cabin temp too...
    Mike likes this.
  10. May 10, 2015 at 7:17 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    The solution is an aftermarket remote start system. ;)
  11. May 10, 2015 at 8:15 PM
    irishpride114
    irishpride114 New Member
    Travis
    2015 SR5 TRD Double Cab
    My wife's 4Runner has the factory remote start. She likes that it turns off when the door is opened. Can't be stolen that way.
  12. May 12, 2015 at 3:14 AM
    LGTundra
    LGTundra New Member
    2015 1794 Edition: SuperCharger, 3-1 Toytec, 20'' Fuel Wheels, 33" Trail Grapplers, Bushwackers, A.R.E. Z-Model Cap
    Ok well this saved me time on researching the manual for the same issue....thx gents!
  13. May 12, 2015 at 4:56 AM
    mdavis
    mdavis I need a beer.
    Michael
    Rock Hill, SC
    Key has to be in the ignition to put it into gear...
  14. May 12, 2015 at 9:00 AM
    ausei
    ausei New Member
    Ause
    Baton Rouge, LA
    2011 Spruce Tundra TRD SR5 2WD
    3" Leveling Kit 3.5" Spindle Lift 4" Rear Blocks AirAid Intake 20" XD Monsters w/ Nitto Grapplers 1" wheel spacers for rear Magnaflow Exhaust Pro Comp Shocks for rear
    what after market products are yall using for remote start. ive been looking at the viper. but i hear there a lot of issues with them...
  15. May 12, 2015 at 9:20 AM
    msg148
    Philadelphia
    I would like to know as well. Doing some online research, but there are too many options
  16. May 12, 2015 at 2:56 PM
    Mike Tread lightly.
    south carolina
    Viper 5904 both taco and tundra with smart start gps via smart phone love it.
  17. May 12, 2015 at 3:09 PM
    csuviper
    Broomfield, CO
    Is there a monthly fee with the smart gps via smart phone?
    No model number when looking it up on viper website.
  18. May 12, 2015 at 3:14 PM
    Mike Tread lightly.
    south carolina
    There is a fee one year or 3 years on the unit or course you can renew. 3 years is cheaper than buying year after year. Almost all viper can do smart smart.
    Csviper you need a model number to the unit?
  19. May 12, 2015 at 3:16 PM
    ausei
    ausei New Member
    Ause
    Baton Rouge, LA
    i beleive there is. no way you can start your care "virtually anywhere" without using some communications service. i read it somewhere that there is a fee.
  20. May 12, 2015 at 3:18 PM
    Mike Tread lightly.
    south carolina
    The system uses att towers.. fyi.
    Edit doesnt work is canada.
  21. May 12, 2015 at 4:23 PM
    Regardless of towers, Viper does charge a fee to use the app to start it from virtually anywhere.
  22. May 12, 2015 at 4:33 PM
    Mike Tread lightly.
    south carolina
    Correct service fee or connect fee. I want to say mine was like 150 each for 3 years.
  23. May 12, 2015 at 5:14 PM
    msg148
    Philadelphia
    Great info. Thanks guys.
  24. May 13, 2015 at 4:41 AM
    irishpride114
    Travis
    Ours is the push button ignition. No keys needed.
  25. May 13, 2015 at 5:35 AM
    msg148
    Philadelphia
    Wish the Tundra was push button.
  26. May 13, 2015 at 7:35 AM
    I've always been on the fence with that...it's one more electronic to go bad.
    Branj likes this.
  27. May 13, 2015 at 7:39 AM
    msg148
    Philadelphia
    I have it on my other car and it's so hard to get used to the key again.
  28. May 13, 2015 at 7:45 AM
    rr3311
    rr3311 Tundra Magic
    Ohio
    2015 Bronze Tundra Limited Dbl cab 4x4
    Added Extang Solid fold tonneau cover Replaced backup lights with projector LEDs Cab LEDs Taconsha P3 brake controller mounted in dash
    I just renewed mine, and it was just under $80 for a year. I can get a 3 year for $140. I don't have the GPS tracking option, which jumps it up. The service runs on a Smartphone or Blackberry.
  29. May 13, 2015 at 7:54 AM
    csuviper
    Broomfield, CO
    There are lots of model numbers available and i guess i just need to look into what the features are of each.
    Looking up the model number you have this one comes up: Viper 5904V Responder HD 2-Way Security and Remote Start System. Doesn't mention smart start or mobile use.
    When searching "viper smartstart security + remote start system" on Amazon there are several model numbers to choose from. VSS5000, VSS4000, VSS3000, 5706V, etc.
    I assume they are universal and not model specific.
    You mentioned that almost all can do smart start so i guess i chose the features and 1way vs 2 way remote that i want and also add the mobile app and service.
  30. May 13, 2015 at 7:58 AM
    csuviper
    Broomfield, CO
    Starting the truck in the winter from the airport shuttle on its way to the parking lot will be priceless.
    Next question is how hard is it to install?
    I am planning to put this in my wish list for my wife to get me for my birthday or Christmas.
