Remote Start Add on
Discussion in '2.5 Gen Tundras (2014-2021)' started by Tundra420, Feb 21, 2021.
  1. Feb 21, 2021 at 8:17 PM
    Tundra420
    Tundra420 [OP] ‘18 CM LIMITED
    Marcus
    Georgetown, Tennessee
    2018 Tundra CM TRD LIMITED
    Has anyone added remote start setup to their SR5’s and if so any links to do so and have you had any problems out of it?
  2. Feb 21, 2021 at 11:30 PM
    jefroshm0
    jefroshm0 New Member
    Elk Grove, CA
    2018 Cement Tundra Crew 4x4 SR5
    I used 12voltsolutions kit. Very easy plug and play. Install took less than 45 min. You can find more info on my build page.
    https://www.tundras.com/threads/shm0-tundra-build.80242/
    Tundra420[QUOTED][OP] likes this.
  3. Feb 21, 2021 at 11:50 PM
    Tundra420
    Marcus
    That’s the one I ended up finding also and it looks as simple as 123
  4. Feb 22, 2021 at 3:11 AM
    Bprose
    Bprose Old member
    VA
    17 Tundra CM TRD
    I also did the 12voltsolutions one. Easy install and it works great.
  5. Feb 22, 2021 at 9:15 AM
    Mdjamesd
    Mdjamesd New Member
    2015 Silver Sky Crewmax
    I also did the Tech12volts one. Plug and play, took about 45 min
  6. Feb 22, 2021 at 9:33 AM
    TundraPJ
    TundraPJ New Member
    JP
    DFW, Texas
    '19 SR5 TRD Off-Road
    Fox TRD Pro Shocks BFG KO2’s Dirty Deeds 14” BAMF n-fab nerf bars
    Me too, very easy to install and great customer service.
  7. Feb 22, 2021 at 9:09 PM
    ski
    ski New Member
    I ordered the MPC off ebay. Going to install it sometime this week. It's supposedly plug & play with 2 wires to splice. Hopefully all goes well.
  8. Feb 22, 2021 at 9:15 PM
    pearlpower
    pearlpower New Member
    2014 CrewMax in Radiant Red
    I have Start-X along with Carlink. Remote starts with 3 presses, or use the app since the unit has cell so I can start, stop, lock/unlock, check battery voltage, and trucks location, from anywhere. Flawless with no hiccups. It also allows for 4 external on/off controls, perhaps lights, or even horn.
  9. Feb 22, 2021 at 9:17 PM
    41bigdawg
    41bigdawg Let the BIG DAWG Eat
    Robert
    Tennessee
    2013 Tundra DC 5.7
    Magnum front, Iron Cross rear bumpers, SB Cold air intake and Gibson Metal Mulisha exhaust, Fender flares, Tow mirrors, 18" Outlaw wheels, 12k Smitty X2O winch, Tech 12v auto start, Firestone Air Bags, Pedal Commander, Devil Horns, etc...
    I got mine from James @Tech12volts , wouldn't buy one from anyone else. Easy install and works petfect.
  10. Feb 22, 2021 at 9:55 PM
    Ddraig
    Ddraig New Member
    2018 Tundra SR5
    I purchased Start-X off Amazon. Install looks to be the exact same as 12Volt and works the same way, except I press the lock button 4 times instead of 3. Start-X is much cheaper and is a very solid unit with easy plug and play install with their wiring harnesses.
  11. Feb 23, 2021 at 3:52 AM
    Bammer
    Bammer I'm disinclined to acquiesce your request.
    Monroe, CT
    2019 Tundra SR5 TRD Crew Max 4x4
    Tech12 website states that 2018 and 2019 models, one wire needs to be cut and spliced??? Soooooooooooo, who can verify or dispel? I get leery when the big print says plug and play and then as you read, it's not so..:oops:
