Regearing questions
Discussion in 'Performance and Tuning' started by Lemuel1, Oct 29, 2024.
  1. Oct 29, 2024 at 11:07 AM
    Lemuel1
    Lemuel1 [OP] Enjoy
    Samuel
    2020 Tundra
    ToyTec Alumas 2.5,icon IT 2.5 rear,Wheelers superbumpstops, JBA UCA’s, 8 inch BA muffler kit,
    Regearing my truck to 5.29s I’ve ordered Yukon master kits front and rear what else do I need ?
    Can the carriers be reused safely ?
    Ctaylor76 likes this.
  2. Oct 29, 2024 at 11:51 AM
    texoma
    texoma Triple C Chop Shop
    ChrisTopher
    Lago Vista, TX
    2018 Limited Tundra
    All the Chrome
    It’s common to reuse the carrier, no real reason to replace them unless you’re getting a traction device like a posi or a locker. I would recommend at least getting a posi for the rear, it will greatly improve your traction. Also, 100% recommend getting OEM Toyota pinion seals for both front and rear. The Yukon seals are ok, but you will see the quality difference with OEM seals. Then to seal the rear diff, throw away the black RTV they send in the kit and go buy some of the green RTV from the parts store. You’ll use the entire tube if not more on the rear diff. So yeah, get 2 tubes of green RTV for the rear. For the front, you can either get the green RTV, which I’ve used exclusively without any reported leaks, or get the Toyota FIPG specific to your front diff. The rear diff already has a solid pinion spacer from the factory. The front is a crush sleeve, so if you can swing it, get a solid pinion spacer for the front as well. Then, all new drain n fill plug crush washers x2 so you can have new for the drain n fill as well. For gear oil I recommend Lucas 85w140 in both front n rear diffs, and Lucas 75w90 synthetic in the transfer case. If ya got any questions whatsoever about regearing, hit me up.
    Mdl likes this.
  3. Oct 29, 2024 at 1:15 PM
    Lemuel1
    Lemuel1 [OP] Enjoy
    Samuel
    2020 Tundra
    Awesome thank you. I’m not doing it myself just making sure I have all the parts
  4. Oct 29, 2024 at 1:31 PM
    Lemuel1
    Lemuel1 [OP] Enjoy
    Samuel
    2020 Tundra
    who sells this solid spacer ?
  5. Oct 30, 2024 at 5:26 AM
    texoma
    ChrisTopher
    Lago Vista, TX
    2018 Limited Tundra
    All the Chrome
    Just about every gear supplier. And don’t forget the ever elusive driver side needle bearing. Replace that with the bushing.
    VWTim likes this.
  6. Oct 30, 2024 at 5:46 AM
    Lemuel1
    Lemuel1 [OP] Enjoy
    Samuel
    2020 Tundra
    The driver side needle bearing I can find but the non crush washer I cannot.
  7. Oct 30, 2024 at 6:12 AM
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    You may wanna grab an assortment of shims. In my experience, I needed, and couldn't find, thinner ones. It kinda held up the job for a day or two
    Vizsla likes this.
  8. Oct 30, 2024 at 6:18 AM
    Ctaylor76
    Ctaylor76 New Member
    Chaz
    Houston
    2021 Tundra Supercharged
    BDS 4.5 inch coil over lift BDS UCA’s 35 inch ridge grapplers AT 20 inch methods with offset 5.29 Nitro Gears ARB rear air locker with dual stage air compressor RC switch panel Both bumpers are RC LED Bumpers (6 pods and lower LED light bar) AMP Research power steps Lower RC Tow hooks B&M Transmission Pan CSF Radiator Radium Duel Catch Can BDS recoil traction bars Helwig adjustable rear sway bar Retrax Power Trax tunnel cover NSV LED front light bar Morimoto XB LED Head lights DOOD Rear smoked LED Tail lights (Amazon) NSLUMA Smoked 3rd brake light (Amazon) Morimoto 4 Banger LED A pillar lights Boostautoparts LED tow mirrors w/ power fold (smoked black) Full 3 inch true duel with XF Flowmaster mufflers custom Vbands Steelworks Longtube Headers RC seat covers OEM Audio plus full sound system duel sub 13 inch Phoenix Automotive In dash screen Stater X remote start system Uniden R8 Radar detector Odyssey Extreme Battery RC Seat Covers RC Rubber Mat Bed Cover Full body color door handles & TRD Grille OEM Magnuson TVS2650 Supercharger
    When I did my nitro gears I had to replace the shims and everything else that Toyota had. It's not recommended to re use any of that. This came from a guy that was certified through Yukon 25+ years
    texasrho83 likes this.
  9. Oct 30, 2024 at 6:50 AM
    Vizsla
    Vizsla 2 = 2.5
    Lemuel1[QUOTED][OP] likes this.
  10. Oct 30, 2024 at 8:49 AM
    texoma
    ChrisTopher
    Lago Vista, TX
    2018 Limited Tundra
    All the Chrome
    Weird. Give ECGS a call and see if they have something not listed on the website. It could be that since it’s an aluminum housing, they wouldn’t want to put that much torque on it maybe.
