Regearing, Calm down cowpokes I’m going 5.29s I have other questions
Discussion in 'Performance and Tuning' started by Lemuel1, Jan 23, 2023.
  1. Jan 24, 2023 at 8:50 AM
    Redline870
    Redline870 New Member
    Ian
    Central NY
    2021 Super White TRD Pro
    I wonder if putting the axles in the freezer would help slip them together with some that are tight but start like yours. With press fit axle bearings, we used to put the bearings in the toaster oven and the axles in the freezer. They would sometimes drop together with no hydraulic press necessary.
    2mchfun likes this.
  2. Jan 24, 2023 at 8:54 AM
    VWTim
    VWTim Mid-Travel Crew
    Corvallis, OR
    Sounds like you have a bigger freezer than I do... Seriously tho, that would likely be enough to shrink them to slide home free. Either that for pack on ice for a few hours and slide them in. We do a lot of press fit stuff at my work, bearing heaters, etc. I never felt the axle was going in too tight.
    2mchfun likes this.
  3. Jan 24, 2023 at 9:01 AM
    2mchfun
    Please don't share this idea with my wife!
    Lemuel1[OP] likes this.
  4. Jan 24, 2023 at 10:24 AM
    dirtydeeds
    Keith
    USA
    more than I can list here
    The guys saying they’re ‘a little tight’ aren’t referring to the issues I’ve seen across the country. The axles physically won’t go in. That’s the issue. This is not something to take lightly. I’ve seen 10 shops across the country have to tear down an assembled carrier section after dong the work of putting it together. All to install a stock carrier. Because companies send these out without the warning, test fit the axles first.
    2mchfun and Lemuel1[OP] like this.
  5. Jan 24, 2023 at 10:38 AM
    Lemuel1
    Lemuel1 [OP] Enjoy
    Samuel
    2020 Tundra
    ToyTec Alumas 2.5,icon IT 2.5 rear,Wheelers superbumpstops, JBA UCA’s, 8 inch BA muffler kit,
    Ohh no not at all I’m saving up for this, probably won’t be able to do it till later this year but active duty and all that so who knows when my life will line up properly to have my truck down for a few days.
    2mchfun likes this.
  6. Jan 24, 2023 at 10:39 AM
    Lemuel1
    Lemuel1 [OP] Enjoy
    Samuel
    2020 Tundra
    Thanks Kieth for the heads up. You’re always the hero we need.
    2mchfun likes this.
  7. Jan 24, 2023 at 11:49 AM
    VWTim
    Corvallis, OR
    If this was towards me, that's not what I was saying. I've heard of the out of spec spline issues, hence why I test fit. Absolutely do a test fit first. Mine was snug but serviceable.
  8. Jan 24, 2023 at 12:27 PM
    dirtydeeds
    Keith
    USA
    Was directed toward everybody reading the thread. Just trying to help.
    Saltyhero13 and 2mchfun like this.
  9. Jan 24, 2023 at 1:32 PM
    Redline870
    Ian
    Central NY
    That a good tip, thanks for the heads up! I can’t stand when I tear down a brake job to find out I’ve got the wrong parts, I’d be beyond myself if it were a differential. Is this an issue you’ve come across with multiple brands of LSDs or any one brand in particular?
    dirtydeeds[QUOTED] likes this.
  10. Jan 24, 2023 at 1:50 PM
    SAGE63
    San Diego County
    Thank you for your Service!
    2mchfun and Lemuel1[QUOTED][OP] like this.
  11. Jan 24, 2023 at 1:55 PM
    VWTim
    Corvallis, OR
    Absolutely, the more info we can get out the better. Now, who's had this happen recently and is there a manufacture date or lot code to look out for?
    2mchfun likes this.
  12. Jan 24, 2023 at 2:12 PM
    Lemuel1
    Lemuel1 [OP] Enjoy
    Samuel
    2020 Tundra
    No thank you for the support.
    2mchfun and SAGE63[QUOTED] like this.
  13. Jan 24, 2023 at 3:09 PM
    dirtydeeds
    Keith
    USA
    Auburn and PowerTrax
    2mchfun likes this.
  14. Jan 24, 2023 at 3:11 PM
    dirtydeeds
    Keith
    USA
    Unfortunately, it happened first in 2020. The problem hasn’t been officially acknowledged or corrected to my knowledge. Until I stop hearing of it happening, everybody needs to check their axle figment before continuing with the set up.
    2mchfun likes this.
  15. Jan 24, 2023 at 3:20 PM
    Silver17
    Eastern PA
    2017 TRD 4x4 Harrop SC
    One of the members here had it happen with both the powertrax and the speedmaster, he bought both in case there was an issue and then neither fit. It almost makes me wonder if there is some amount of inconsistency in the axle splines themselves that contributes to the issue.
    Also, I’ve had both the auburn pro and the powertrax and can definitely say I prefer the operation of the powertrax.
  16. Jan 24, 2023 at 3:24 PM
    Redline870
    Ian
    Central NY
    I’d be EXTREMELY surprised if there were inconsistencies in Toyotas mass production manufacturing. Especially considering the axles are coming out of drivable trucks.
  17. Jan 24, 2023 at 3:52 PM
    Silver17
    Eastern PA
    As would I, it’s just interesting this issue happens across 3 different brands. I’m more implying perhaps it’s relative to how worn the axle splines are. Maybe the axles they used for reference when they made their original design for the differentials had some decent mileage on them. Is this issue possibly happening more often on low mileage trucks with less worn splines?
  18. Jan 24, 2023 at 4:23 PM
    centex
    centex New Member
    I wouldn’t. Manufacturing tolerances are a thing.
    And since the world stopped and things have been coming back online at break neck paces, qc has taken a back seat. I’ve seen failures and quirks in my industry that were never a thing until after covid. Companies are scrambling to get their hands on whatever they can get to keep product going out the door. Doesn’t explain any axle built prior to 2020 but it explains diffs built after 2020.
  19. Jan 24, 2023 at 4:24 PM
    #49
    dirtydeeds
    Keith
    USA
    It’s not the truck. The problem just started happening and the year truck doesn’t matter. It’s the carriers.
  20. Jan 24, 2023 at 5:00 PM
    #50
    SAGE63
    San Diego County
    @dirtydeeds How do you or can you wire eaton e-lockers to a switch pro?
    dirtydeeds likes this.
