Regear questions
Discussion in 'Performance and Tuning' started by Cg13055, Nov 22, 2020.
  1. Nov 22, 2020 at 12:28 PM
    Cg13055
    Cg13055 [OP] @yota.parts.distributor
    South Florida
    Mcfly Tundra @yota.parts.distributor
    2012’4.0 Tundra-2004’4.7 crewcab-2021 2.7 Tacoma
    Also only found a 4.88 from G2 DANA in my size but cannot find anything else
    Rica25 likes this.
  2. Nov 22, 2020 at 12:34 PM
    C.I.
    C.I. Surf, off road, sleep, repeat
    Cesar Pedrin
    Cabo, Mx
    2016 5.7 4x4 Bronze Crewmax
    Mods: Ongoing... probably never ending
    Rica25 likes this.
  3. Nov 22, 2020 at 12:42 PM
    Cg13055
    South Florida
    Do you think the 4.30's will help with my overdrive issue? In reality I just want that to be gone or minimized, I hate feeling it shake the truck and having to drive differently to avoid the bogging, thanks for all the help I appreciate it
    Rica25 likes this.
  4. Nov 22, 2020 at 12:48 PM
    Wallygator
    Since you have a 4" lift you could always go up in tire size to bring it back close to stock gearing with the 4.88 r&p
    Rica25 likes this.
  5. Nov 22, 2020 at 12:49 PM
    Cg13055
    South Florida
    These tires are brand new so it would be a while before a they got swapped out, at least a year
    Rica25 and Wallygator[QUOTED] like this.
  6. Nov 22, 2020 at 12:54 PM
    Wallygator
    An that's ok. Just saying you have that option if the 4.88 gearing ends up being too tall for your current tires. In your situation I would probably go with the 4.88's for that reason alone....can eventually have bigger tires with stock gearing.
    Rica25 and Cg13055[QUOTED][OP] like this.
  7. Nov 22, 2020 at 12:56 PM
    SC_TRD
    SC_TRD Big BASTRD 4x4 Enthusiast
    Colin
    Round Rock, Tx
    2012 CrewMax & 2008 Sequoia
    Sweet!
    Stoked this helped you out!
    :yes:
  8. Nov 22, 2020 at 12:56 PM
    Cg13055
    South Florida
    I had the same thinking here, originally thought I could run 33's or more but now that I know all my gearing info I am thankful that I only went up one side but regret it being such a heavy tire, I feel like 4.88 is the best option and if 4.56 existed that would be my choice for sure
  9. Nov 22, 2020 at 1:04 PM
    C.I.
    Cesar Pedrin
    Cabo, Mx
    A bit of gearing goes a long way, even 4.10 would help greatly if not solve it. 4.30 is a much safer option even for a loaded bed.
    Figured this would be the case, thats why I insisted on 4.30, however Wallygator is not wrong :D a year is not a lot of time for tire change, if you're going 34" or larger, then 4.88 is the right call
  10. Nov 22, 2020 at 1:28 PM
    Cg13055
    South Florida
    Truthfully I'm just trying to get rid of the issue and I rather overdo it and then have the means to go further when the time comes, I will probably be between 33" tires or 34's but again they will most likely be the high rated tires that can take the most force, they ride very rough but I promise you will never have a blow out unless you managed to really find something to get in there good
    08TXTundra, Rica25 and Wallygator like this.
  11. Nov 23, 2020 at 8:20 AM
    dirtydeeds
    Keith
    USA
    more than I can list here
    Give Keith Carty a call at 760-877-4234 to talk to him about gearing. He is a master at gearing trucks per best performance.
  12. Dec 1, 2020 at 11:50 AM
    08TXTundra
    08TXTundra New Member
    David
    Houston
    2008 Tundra 5.7 2WD
    Stock. No tow package, 4:10 gears
    I look forward to hearing about the results. My dad has a 4.0L DC.
  13. Dec 5, 2020 at 1:18 PM
    Cg13055
    South Florida
    I'm actually have a TC issue not a gearing issue after further investigation and speaking to a knowledgeable transmission shop.
