Refuel light on
Discussion in 'Electrical' started by Sonicbluerider, Apr 6, 2022.
  1. Apr 6, 2022 at 3:16 PM
    Sonicbluerider
    Sonicbluerider [OP] New Member
    Dennis
    2019 Tundra
    Full tank. Opened gas cap but that didn't work. Any ideas why I have this light on?
  2. Apr 6, 2022 at 3:22 PM
    Taco-Spike
    Two Trucks
    Well, the gas cap would be my first go to.
    Disconnect the battery for a while and reconnect. That would be my easy second go to procedure.
  3. Apr 6, 2022 at 4:06 PM
    Jeff_5_7
    Jeff_5_7 New Member
    Jeff
    Houston Tx Area
    Curious as to why opening the gas cap was a thought?
    Trying to understand more about how the newer truck determines how much fuel is in it. Does it have a sensor to know if the cap is open?
    The 2007-2017 just use the float to run the fuel gauge and tell the cluster the amount of fuel to calculate the range.
    The 2018 might have more sensors or way of reading the data
  4. Apr 7, 2022 at 8:56 AM
    Sonicbluerider
    Dennis
    2019 Tundra
    Omg. Filled up tank ,2 gallons. Light still on. Took to dealer,never seen it before. So on 5 miles ride home ,sob yaaaa light went off. So no solution buts lights off.
    Taco-Spike likes this.
