Recon big rig ice
Discussion in 'Lighting' started by D1227, Jan 1, 2017.
  1. Jan 1, 2017 at 7:40 PM
    D1227
    D1227 [OP] New Member
    Dustin
    Western Washington
    16crewmax
    Hey guys...I got these ionic illuminator led courtesy lights I will be attempting to install tomorrow can some one tell me or send me a link for what wires to tap into so they come on with the dome lights...I tried searching but could not find what I was looking for...2016 tundra
    Thanks in advance for any help.
    I plan on mounting the leds on the white metal below the doors and above the running boards.20170102_111128.jpg
    THESE FAILED HORRIBLY
    Berdine likes this.
  2. Jan 2, 2017 at 9:10 PM
    D1227
    Dustin
    Western Washington
    16crewmax
  3. Jan 2, 2017 at 10:05 PM
    D1227
    Dustin
    Western Washington
    16crewmax
    They come when I unlock with the fob or open a door.
  4. Jan 3, 2017 at 3:09 AM
    chphilo
    chphilo Tundra addict
    Western PA
    Well, how many sexy women do you have at hand that come like that? :D Sorry, I couldn't resist that.
    Light looks great. I wanted to do something similar (but hooking up to the signal light).
    D1227[QUOTED][OP] likes this.
  5. Jan 3, 2017 at 6:45 AM
    Sixpack
    Sixpack New Member
    Central Florida
    2014 Silver Sky Tundra CM TRD 4x4 Limited
    Moto Metal 951 18x9 rims with 285x75x18 Nitto Terra Grapplers , ESP lockable under seat storage, Husky mats front and rear, ReadyLift 3/1, Undercover Flex trifold bed cover, Bed Rug, interior LED's, 15% tint all around, TRD CAI, Bully Dog Platinum GT tuner, TRD rear sway bar, Flowmaster Series 44 dual exhaust system, LED head lights and Fog lights, 32" LED light bar in lower bumper cover, Switchback running lights, much more to come...
    Can you post where you got the LED light strips? Thanks
    D1227[OP] likes this.
  6. Jan 3, 2017 at 4:47 PM
    D1227
    Dustin
    Western Washington
    16crewmax
    You got me.
  7. Jan 3, 2017 at 4:55 PM
    D1227
    Dustin
    Western Washington
    16crewmax
    Theses were a gift from the wifey...I will post as soon as I find out.
    Sixpack[QUOTED] likes this.
  8. Jan 3, 2017 at 5:50 PM
    Sixpack
    Sixpack New Member
    Central Florida
    Let me know when you can, thanks...
  9. Jan 3, 2017 at 5:53 PM
    D1227
    Dustin
    Western Washington
    16crewmax
    Wifey says running board warehouse they were on sale for 50.00 bucks for the 77inch leds
  10. Jan 3, 2017 at 5:54 PM
    D1227
    Dustin
    Western Washington
    16crewmax
  11. Jan 3, 2017 at 5:59 PM
    Sixpack
    Sixpack New Member
    Central Florida
    What length is your set?
  12. Jan 3, 2017 at 6:27 PM
    Sixpack
    Sixpack New Member
    Central Florida
    Never mind I went with 77" set. Sorry, I didn't read post #9 in its entirety. Thanks for the info...
  13. Jan 3, 2017 at 6:33 PM
    D1227
    Dustin
    Western Washington
    16crewmax
    Mine are 77...if you have any questions when you install them let me know i might be able to help...
  14. Jan 3, 2017 at 6:34 PM
    Sixpack
    Sixpack New Member
    Central Florida
    Where did you tap into your interior lights?
  15. Jan 3, 2017 at 6:39 PM
    D1227
    Dustin
    Western Washington
    16crewmax
    Under the driver side door sill there is a fat wire loom I went with my cargo light which is the little brown wire....would post pictures but I really don't think my butcher wire job belongs on the net...lol
  16. Jan 3, 2017 at 6:43 PM
    Sixpack
    Sixpack New Member
    Central Florida
    Got it, did you just hook up the one side to power how did you run the wire to the passenger side?
  17. Jan 3, 2017 at 6:45 PM
    D1227
    Dustin
    Western Washington
    16crewmax
    Be back in a moment with pics bruh...
    Sixpack likes this.
  18. Jan 3, 2017 at 7:04 PM
    D1227
    Dustin
    Western Washington
    16crewmax
    Brown wire to cargo light I tapped into under Driver side door sill.
  19. Jan 3, 2017 at 7:07 PM
    D1227
    Dustin
    Western Washington
    16crewmax
    This is behind the kick panel on Driver side where i use to ground the light's.
  20. Jan 3, 2017 at 7:14 PM
    D1227
    Dustin
    Western Washington
    16crewmax
    This is way up behind the pedals on the left...this harness has a big rubber grommet around it..on the bottom of that grommet there is a nipple you can poke hole in and run your wires into the engine bay.
  21. Jan 3, 2017 at 7:20 PM
    Sixpack
    Sixpack New Member
    Central Florida
    Thanks, if I have any more questions when I install them I'll contact you. Appreciate all your help...
  22. Jan 3, 2017 at 7:23 PM
    D1227
    Dustin
    Western Washington
    16crewmax
    This black wire is coming off the leds where I routed back to the frame and up into the engine bay...did this on both sides used a lot of zip ties that I haven't clipped yet as you can see in the pic.
    Sixpack likes this.
  23. Jan 3, 2017 at 7:31 PM
    D1227
    Dustin
    Western Washington
    16crewmax
    One more thing before I put the strips on my truck I tapped them flat to the kitchen table over night to let them unwind...then I cleaned the f@&! Out of the metal on the truck with rubbing alcohol and rags then as I was applying the strips I used a heat gun to warm the metal and the double sided sticky tape...I only peel about six inches of backing at time I hope this helps. Use caution with heat gun and your paint !
  24. Jan 3, 2017 at 7:34 PM
    Sixpack
    Sixpack New Member
    Central Florida
    Thanks again for all the awesome information...
  25. Jan 3, 2017 at 7:39 PM
    D1227
    Dustin
    Western Washington
    16crewmax
    No problem this is the first time I get post something that I did to my truck usually I find what ever it is I want on this site and copy the way they did it on here but couldn't find any info and no one was real quick to jump in with hints or info...I just hope these mf'ers hold up.
  26. Jan 3, 2017 at 7:42 PM
    D1227
    Dustin
    Western Washington
    16crewmax
    If any one with more experience with this or has any info to do a better job by all means jump in here guys this was the fist time I've done something like this.
  27. Jan 3, 2017 at 8:43 PM
    BlueBottle
    BlueBottle not a PRO
    '16 Platinum 4x4
    See fine print
    Where's the other side of the brown wire ? Thought you are only suppose to splice into it and not cut it completely?
  28. Jan 3, 2017 at 8:48 PM
    D1227
    Dustin
    Western Washington
    16crewmax
    I was waiting for this.
    Check it out... I f'ed up when I spliced into the brown wire ok... I made it work though. I had to cut out the shitty supplied splice connector which left me a tad short of where I needed to be...
  29. Jan 3, 2017 at 8:50 PM
    D1227
    Dustin
    Western Washington
    16crewmax
    BlueBottle likes this.
  30. Jan 3, 2017 at 8:51 PM
    BlueBottle
    '16 Platinum 4x4
    See fine print
    LOL ok just want to make sure I do it right, cus I'm splicing into that same wire for my bed lamps.
