Recommended Tool Kit(s)?
Discussion in 'General Tundra Discussion' started by WarDamnTundra, Sep 6, 2022.
  1. Sep 12, 2022 at 3:52 PM
    Outbound
    Aaron
    Northern Alberta
    That's just a starter set. :D
    I have the same compressor. It's a great choice for light duty home jobber stuff.
    JMB[QUOTED] likes this.
  2. Sep 12, 2022 at 4:00 PM
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
    Have to turn the power level to 2 of not it goes over 100ft/lb even with the torque stick.
  3. Sep 12, 2022 at 4:09 PM
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Go ahead and buy a bunch of 10mm sockets right now to get it outta the way
  4. Sep 12, 2022 at 4:28 PM
    JMB
    Chesapeake, VA
    2013 Super White Tundra DC
    The IR or the Craftsman?
    Edit, the PC or the Craftsman?
  5. Sep 12, 2022 at 4:52 PM
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
    I'm sure 80% of household have a pancake PC...lol
    Beach Toy and JMB like this.
  6. Sep 12, 2022 at 4:56 PM
    jalam321
    jalam321 New Member
    2018 Tundra CM Platinum 4x4 and Sequoia Platinum 4x4
    Like others have said...start with a good Mechanics tool kit (Craftsman, Husky, Kobalt, etc). Be sure they include a 1/4", 3/8", 1/2" drive ratchet and wide assortment of sockets. Then get a long breaker bar, good floor jack that lifts high enough for trucks, heavy duty jack stands. Get both 3/8 and 1/2" torque wrench. A cordless impact wrench will help a lot also. I have Milwaukee and Ryobi, both are good. I used to use air tools a lot, but use my battery power cordless more now. A set of open end and ratcheting wrenches from 8mm - 19mm. (may even need 21, 22, 24mm). Start with these basics and continue to grow your collection as you need more tools for specific jobs.
  7. Sep 12, 2022 at 4:58 PM
    Outbound
    Aaron
    Northern Alberta
    PC.
  8. Sep 12, 2022 at 7:48 PM
    Tripleconpanna
    2021 TRD PRO CM; 2008 SR5 CM
    ...that and the 1/4" socket; I can never find that freakin' thing either :mad:
  9. Sep 14, 2022 at 9:33 PM
    farleymcjohnson
    farleymcjohnson New Member
    Eric
    Cokato MN
    2017 Super White Limited Double Cab
    ARE Topper Prinsu Cab and Topper Rack
    I've worked on my own trucks for years, and I've been a machinist for years. One tool I'll always have in my toolbox is a large (like 12" or bigger) flathead screwdriver. A true multi tool!
    I've used it as a pry bar more than I've used it as a screwdriver. Used it to reach stuff down in the engine bay, used it to lift awkward objects, used it accross the starter to jump a tractor. used it as a chisel, used it as a scraper, used it as a handle, oil filter wrench in a bind, etc...
  10. Sep 18, 2022 at 2:51 PM
    WarDamnTundra
    WarDamnTundra [OP] New Member
    2014 Tundra TRD Limited CrewMax
    Icon Stage 2 w/ Icon Mini Leaf Pack - WildPeak A/T3W 35x12.5x20 - 20" Rock Star II - Retrax Bedcover
    I went through this today when I was replacing the grommet on the base of the antenna. Felt like I wont the lottery when I did find it. :rofl:
    WVI, texasrho83[QUOTED] and JMB like this.
  11. Sep 18, 2022 at 4:05 PM
    Beach Toy
    Beach Toy New Member
    David
    SE NC
    2017 White SR5 4x4
    Lomax cover, TRD PRO headlight conversion...so far anyway
    What he said! Two is one, one is none, but with 10mm sockets, that goes to whole new level of never too many. Double up with drive extensions as well, in all sizes. Oh, and swivels.
    WVI and texasrho83[QUOTED] like this.
  12. Sep 18, 2022 at 4:12 PM
    WarDamnTundra
  13. Sep 18, 2022 at 4:35 PM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
  14. Sep 18, 2022 at 4:51 PM
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
  15. Sep 18, 2022 at 4:54 PM
    WarDamnTundra
    Maybe for all around use? Comparing prices of tools in general I thought it was a good deal for the money.
    WVI likes this.
  16. Sep 18, 2022 at 4:58 PM
    WarDamnTundra
    I looked at impact wrench yesterday and they aren't too bad until you have to buy the battery. Ryobi seemed to be the most reasonably priced.
  17. Sep 18, 2022 at 4:58 PM
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
    Getting the regular with 6 points is better for breaking lost nuts and bolts, specially with an impact on the other side. and you could hit it with a hammer or double wrench
    WVI likes this.
  18. Sep 18, 2022 at 5:01 PM
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
    Ryobi just came out with bunch of power tools, it’s not bad for home use, the tools don’t cost much, but those big batteries is like $200 a piece
    I always recommend what ever the battery platform the guy own already… because if they have to buy 3 batteries, it’s already $600
  19. Sep 18, 2022 at 5:02 PM
    #49
    WarDamnTundra
    I have another newbie question:
    If a set states it is SAE/MM, does that mean it's a crossover set? No need to buy separate?
    texasrho83 likes this.
  20. Sep 18, 2022 at 5:06 PM
    #50
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
    Sae is standard ¼, 5/16, ⅜…etc mm which mean they have both
  21. Sep 18, 2022 at 5:24 PM
    #51
    WarDamnTundra
    Yeah, just wasn't aware a set could be both SAE and metric. Such a noob I am.
    When I said I was here to learn, I wasn't BS'ing. haha
