Recommendations for smoother ride
Discussion in '2.5 Gen Tundras (2014-2021)' started by wwolvverine, Dec 16, 2018.
  1. Dec 28, 2018 at 12:45 PM
    PA452
    PA452 New Member
    2021 Tundra SR5 CM TRD O/R
    Ha, I find this thread kind of bizarre. Partially what got me looking at getting a Tundra was the ride quality. I tell people all the time how nice my Tundra rides. Only have about 5000 miles on it, so we'll see how it does down the road. But I think it rides very nice.
  2. Dec 28, 2018 at 1:09 PM
    Oldgraywolf
    Oldgraywolf New Member
    When I first drove my 2018 Tundra it rode a little rougher than my 2007. Adjusted Tire pressure to 40psi and it rides just like my 2007.
  3. Dec 28, 2018 at 1:11 PM
    JeremyGSU
    JeremyGSU New Member
    Jeremy
    2016 Tundra
    I would also recommend Road Force Balancing the tires at a place that knows how to do it. Even with my 18's it made quite a noticeable difference over a spin balance.
  4. Dec 28, 2018 at 1:16 PM
    Kanelakos
    Kanelakos New Member
    Dean
    Kirkwood NY
    2017 Tundra DC SR5 TRD Off Road - Inferno
    None..... Yet
    I went from a 2016 Tacoma Sport to a Tundra Off Road. The Tundra feels like a Cadillac compared to the Tacoma. :)
  5. Dec 28, 2018 at 2:04 PM
    Ericsopa
    Ericsopa Old man and the sea
    And I don't care what you say. My TRD rides just fine. I've even had compliments from passengers on the ride. With yellow shocks (soon to be 6112s and 5100s). I suggest you trade yours for a piece of Shilverado if you don't like it. It would be more productive than bitching about it here.
    bmcdds, Kanelakos and Rica25 like this.
  6. Dec 28, 2018 at 2:13 PM
    tundracap
    tundracap New Member
    NC
    2017 CM Limited 4x4 Silver Sky Metallic
    Went from a 2006 DC to a 2017 CM Limited and what a huge difference in ride, especially at speed on the highway. WAY better in the 2017. Still running the factory installed 20" wheels and tires - 275/55/R20s Bridgestone Duelers 111H M/S Alenza with 29+k miles.
    Still deciding what to do next when time to replace the tires, but the ride is awesome. (Suggestions?)
    Just installed my Christmas present to me - TRD rear sway bar and will see how that runs this weekend.
  7. Dec 28, 2018 at 2:23 PM
    alpinepro4
    alpinepro4 What is your MPG Today!
    Pat
    2017 TRD Pro Cement DC
    Baja Designs Squadron Sport Fog lights, ARE CX Series Topper, Alcan Springs , DAP Tune, Coach Builder +1 Shackles, Headlight Revolution Supernova V.4 LED bulbs, HR LED interior bulbs. General Grabber ATX 275/70/R18
    Since I put on beefer AT tire I noticed my ride has gotten a bit stiffer. To be expected, yes TRD Pro suspension does ride firm on road. I will be switching to kings next year and aftermarket UCA. I did replace my leaf springs last spring and ride improved, I will be installing CB +1 shackles here soon. Sure that will help as well. There are many ways to make Tundra ride smoother.
    Rica25 likes this.
  8. Aug 18, 2020 at 4:59 AM
    martyvanl
    martyvanl New Member
    Marty
    2018 double cab sport
    Nothing yet, just got it Friday.
    I do want to make my ride a little smoother but do not want to spend more than I have to. If it is all about getting more air can I accomplish the same thing with changing my 275/55R20 to 275/65R20 ? Wouldn't a higher tire give more air?
  9. Aug 18, 2020 at 5:05 AM
    Rex Kramer
    Rex Kramer Vinyl Spinner
    Georgia
    18" Michelin LTX M/S or Defender size 255/70 or 275/65 with brand new standard black shocks and about 200 lbs of weight in the bed should smooth out the ride for you.
    Hoff likes this.
  10. Aug 18, 2020 at 5:26 AM
    ninjajay
    Spoolston, TX
    2018 MGM 1794 TRD 4x4
    Going from stock to that size will also change you to LT tires which will have a much firmer ride
    betotundra and martyvanl[QUOTED] like this.
  11. Aug 18, 2020 at 5:36 AM
    martyvanl
    Marty
    Thanks ninjajay
  12. Aug 18, 2020 at 5:55 AM
    UTAHRTK
    UTAHRTK New Member
    SOCAL
    2017 MGM Tundra TRD CM
    Dirty Deeds 8" standard exhaust, King 2.5's/Bilstein 5160's, Built Right UCA,s, Method 701's, TOYO ATIII 35x12.5x17, TRD LED headlights, Pro Grill
    I had 20" inch wheels from dealer on TRD Off Road SR5 and swapped out stock shocks for Bilstein 6112s and 5160s. I set front to 1.3 setting and left rear stock height; ended up adjusting front to level and went 17" wheels/ 295/70r17 tires- rides smooth but still like truck- I am happy with it. The 20" wheels were OK on street as far as hauling ass but they got dominated on trails and even on road I felt all the pot holes.
    Spitfire likes this.
  13. Aug 18, 2020 at 6:26 AM
    DIYDad
    DIYDad New Member
    2020 Tundra 1794
    My 2020 1794 TRD offroad rides extremely well. Stiff over bumps, as you would expect a truck to be, but not "jittery" at all.
    I'd go to your local dealer and test drive a 2020 with 18" wheels and Michelin tires. If that truck rides better, you have a path to "fix" your truck. If it doesn't satisfy you, you're best bet may be a different brand, or something other than a pickup.
    I considered a used Land Cruiser for a while, but ultimately decided that I still wanted a pickup.
  14. Aug 18, 2020 at 7:11 AM
    ninjajay
    Spoolston, TX
    My 18 rode significantly better than the 18 F150 Platinum I test drove while shopping, much more so now with the right suspension upgrades.
  15. Aug 18, 2020 at 9:27 AM
    Johnnyquad
    Johnnyquad New Member
    21 Pro double cab MGM
    Tint, clear bra, OEM stereo upgrade, tonneau cover, line x, 285/65/18 Toyo AT3
    Aftermarket shocks will help for sure.
  16. Aug 18, 2020 at 10:10 AM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    The stock black shocks are bottom of the barrel. And those bridgestone tires are too. Nothing a shock and tire upgrade won't help greatly.
  17. Aug 18, 2020 at 12:00 PM
    KTMRider
    KTMRider New Member
    Ken
    2020 Tundra
    King's all around, Dirt Deeds 10" exhaust, 18x9 Method 305 NV, Falken Wildpeak A/T3W 305/65/18 tires, tinted windows (shhhhh)
    I have a set of 4 of the TRD red with blue cover shocks with 250 miles on them sitting in my garage. Went with 5100's for the lift.
  18. Aug 19, 2020 at 9:11 AM
    lamarboards00
    lamarboards00 ¯\_(ツ)_/¯
    Alex
    Maryland
    2014 Barcelona Red Tundra
    Surprised no one has mentioned the weight in the bed before you. That makes a world of difference for me.
    Rex Kramer[QUOTED] likes this.
