Recall notice - Rear axle shafts may separate from vehicle
Discussion in '3rd Gen Tundras (2022+)' started by mannyg84, Jun 23, 2022.
  1. Jun 25, 2022 at 10:23 AM
    Craigaz
    Craigaz New Member
    Craig
    2022 4x4 CrewMax Limited w/TRD offroad package
    I slid under my truck and all 8 were around 43 foot pounds. Cranked up the torque wrench to 70 foot pounds and it took about 22 degrees of rotation to hit 70. My truck was built on 3/1/22 as a reference point.
    I'll have the dealer check my work during the 5k service visit.
    FirstGenVol, Toyotoholic and husktank like this.
  2. Jun 25, 2022 at 12:15 PM
    husktank
    husktank New Member
    Just did mine. None were under 14.75 foot pounds (threshold referenced by the recall). My experience was the same as @Craigaz; about 22 degrees rotation to get to 70 on all 8. Feb. 22 build.
    Craigaz likes this.
  3. Jun 25, 2022 at 12:31 PM
    paradizecityz
    paradizecityz New Member
    Richmond, TX
    2022 Tundra TRD Off Road
    Is it only the rear that everyone is checking?
  4. Jun 25, 2022 at 12:32 PM
    husktank
    husktank New Member
    I didn't check the front since the recall didn't reference it. Does anyone know what the factory torque setting is for the front?
  5. Jun 26, 2022 at 2:45 PM
    PoundHard
    PoundHard Knows just enough to be dangerous
    22 SR5 TRD OR Prem
    3" Lift, Defender Flares, EGR Deflectors, Ceramic Coat, UnderCover ArmorFlex, DIY De-chrome, Headwaters Seat Covers
    My dealer's next appointment isn't until July 15... Anyone know what size the flange nuts are?
  6. Jun 26, 2022 at 2:55 PM
    roboots21
    roboots21 New Member
    2022 MGM Tundra Limited DC
    17mm
    PoundHard[QUOTED] likes this.
  7. Jun 26, 2022 at 2:59 PM
    brucega7x
    brucega7x New Member
    2022 Tundra SR5 CrewMax 4X4
    I can literally only get to 1 on each side of mine without pulling tires off.
    Each one I could get to was NOT torqued to 70ft/lbs though. I got almost 1/4 turn out of them before the torque wrench clicked. Not overly worried about it and not going to go out of my way to make an appointment. I'll let them take care of it when I hit 5K miles, which will be in like 6 months at the rate I drive. lol
  8. Jun 26, 2022 at 3:06 PM
    roboots21
    I was able to slide under my truck with a creeper and tighten all of them. All mine were present, torqued to 44 lb-ft, and then I tightened them up to 70 lb-ft. Try some different socket set ups perhaps?
  9. Jun 26, 2022 at 3:08 PM
    brucega7x
    My tires are wider than OEM so I needed an extension that frankly I was just too lazy to go back and get...again, not overly concerned. All 4 were on each side and I doubt they will move before 5K miles even being a little under torqued.
  10. Jun 26, 2022 at 3:29 PM
    jmay86
    jmay86 New Member
    Josh
    Columbus, Ohio
    '22 Lunar Rock LTD DC TRD-OR
    The 70ft/lb is for the recall, so I’m not surprised they weren’t at 70 already… from what I can gather the original torque specs were only in the 40’s, which I suspect was too low and the reason they backed off on some trucks…
  11. Jun 26, 2022 at 3:33 PM
    brucega7x
    Yeah, I definitely wouldn't want to go forever with where they are now, but I'm quite confident I'll be just fine for 5,000 miles.
    jmay86[QUOTED] likes this.
  12. Jun 26, 2022 at 10:36 PM
    bigjuice
    bigjuice Spring hath arrived…
    WA State
    2024 Terra TRD Pro
    Took a few different setups to get mine too…3 were more accessible on each side that the 4th.
    Got a dealer appointment next week either was coupled with my first oil change
  13. Jun 27, 2022 at 5:07 AM
    joescho
    joescho New Member
    Joe
    Scranton,PA
    2024 Supersonic Red Platinum
    Anyone have any first hand experience with this? They're saying certain nuts can come loose on the rear axle assembly and bad things happen.
    I'm going in this Friday. Hopefully a quickie.
  14. Jun 27, 2022 at 5:25 AM
    There is already a few other threads posted about it.
  15. Jun 27, 2022 at 5:25 AM
    22PlatWCP
    22PlatWCP New Member
    Mississippi
    2022 WCP Platinum 4x4
  16. Jun 27, 2022 at 6:54 AM
    Keepontrying
    Keepontrying New Member
    da Burgh
    2022 TRD OR, CM 6.5 ft. bed, Blueprint (aka Black, Blue or Purple)
    Got my alert yesterday... calling today.
  17. Jun 27, 2022 at 7:37 AM
    sablue
    sablue New Member
    jay
    2022 tundra plat
    So according to the recall its' certain models...Anyone with a platinum model get the notice ? Mines was built on Mar 2022
  18. Jun 27, 2022 at 7:38 AM
    eddiefromcali
    eddiefromcali New Member
    Eddie
    2022 Tundra Platinum
    100% Stock
    Platinum here and got the recall notice
  19. Jun 27, 2022 at 7:42 AM
    #49
    sablue
    sablue New Member
    jay
    2022 tundra plat
    Stupid Toyota app. Only notice I got so far was the back up camera. Looks like a call to the dealership.
  20. Jun 27, 2022 at 12:53 PM
    #50
    JPD
    JPD New Member
    2022 Black Tundra 1794 TRD OR
    I called to make my appointment today and they said it’s a lengthy appointment and will take at least 4 hours, seems to go against everything everyone is saying on here.
    Will be interested to see what they say when I drop off instead of the person who is just booking the appointments.
  21. Jun 27, 2022 at 1:12 PM
    #51
    Enduvall
    Enduvall New Member
    2022 Tundra Platinum Supersonic Red
    Platinum as well here. Just got mine back from the dealer. They checked and said all of mine were fine except one! Oh well good until the next recall, I guess. Had a taco before and it had several recalls over the years.
  22. Jun 27, 2022 at 10:20 PM
    #52
    bigjuice
    WA State
    2024 Terra TRD Pro
    Did they by any chance happen to say what “fine” meant?
    What I am getting at is if “fine” meant they were all at 70 per the recall suggested fix (except one) or were all at 44 per original spec and the exception was one that was backing out/loose?
    Tightened mine before heading out on a trip but have an appointment with the dealership next Tuesday.
    Also…does anyone know how to reset the app so it will stop screaming
    - 1 recall/safety notification
    - 1 maintenance notice (first oil change)
    Is that something that automatically updates once the dealer puts your vin in the system that these items were taken care of?
  23. Jun 28, 2022 at 11:00 AM
    #53
    Enduvall
    Enduvall New Member
    Sorry, they said they were all at 70 except one that only needed a little tightening. I twisted my knee and can't drive so my wife took it to the dealer. Those were the only details they gave her. The paperwork they sent home doesn't have any useful info.
    I called customer service and asked how to get the recall notice to clear on the app. They said give it a week and it should drop off. I highly doubt that will happen, just a wait and see thing for now. Seems like it would get cleared by VIN at the dealer after service but I guess that isn't the case.
    bigjuice[QUOTED] likes this.
  24. Jun 28, 2022 at 11:04 AM
    #54
    Razorback Guy
    Razorback Guy New Member
    2022 SR5 DC 4x4
    My recall noticed is gone from the app. Took a few days.
  25. Jun 28, 2022 at 7:27 PM
    #55
    GQ104
    GQ104 New Member
    Took mine in today, left it at the dealership and went to work, since work is across the street :) . took about 4 hours tho, but they were busy with other cars, guy said this is the first recall they are doing of this type but easy fix, if any fix.
  26. Jun 28, 2022 at 10:06 PM
    #56
    bigjuice
    WA State
    2024 Terra TRD Pro
    Ok…Thanks man.
  27. Jun 28, 2022 at 11:56 PM
    #57
    Dark
    Dark New Member
    @sablue I have a Platinum, March 25th build. I have the recall.
  28. Jun 29, 2022 at 7:24 AM
    #58
    Cav764
    Cav764 New Member
    I'd generally concur that once you get the car on a lift this should be a very quick job. I would personally check them myself you have the ability to, and then still bring it into a dealer to have it done on record.
  29. Jun 29, 2022 at 5:27 PM
    #59
    IslandStyle
    IslandStyle New Member
    Oregon
    2022 SR5 DC: Blueprint, TRD Premium Off Road AND 2004 SR5 DC: Charcoal
    I just noticed the recall on the app today. I'm not sure of my build but I picked it up mid May and it has 2800 miles on it. The first appointment available at the stealership is next Wednesday. I'm planning on driving 800 miles or so round trip to go visit family over the holiday weekend before that appointment. Do you all think these are plans I should change (drive a different vehicle)? Checking the nuts myself is not in my wheelhouse (no place to do it).
  30. Jun 29, 2022 at 5:57 PM
    #60
    brucega7x
    Honestly I personally wouldn't be concerned in the slightest. Even if they are under torqued, I highly doubt they'll come loose for probably thousands of miles.
    Unless you have like 10-15K+ I wouldn't even worry about it.
    IslandStyle[QUOTED] likes this.
