Recalibrate Speedo
Discussion in 'Wheels & Tires' started by DMBfan, Sep 6, 2018.
  1. Sep 6, 2018 at 8:23 PM
    DMBfan
    DMBfan [OP] 2015 Tundra SR5 CrewMax
    So I just pulled the trigger and went to my local motorsports shop and put a 6"BDS lift w/ 35" tires on my Tundra (looks sharp). I have read the speedometer should be re-calibrated since the tire size has changed. Does anyone know if this is true?
  2. Sep 6, 2018 at 8:23 PM
    Yes
    Sas likes this.
  3. Sep 6, 2018 at 8:24 PM
    Rica25
    Ricardo
    Tulare
    How do you recalibrate
  4. Sep 6, 2018 at 8:26 PM
    Hypertech speedo calibrator can do it
    Sefferston and Sas like this.
  5. Sep 7, 2018 at 5:44 AM
    Sas
    Sas Humor is everywhere
    OKC, OK
    '17 SR5 CM TSS 4WD MGM 5.7 FF
    Lost track after #1.
    Looks like a pretty easy plug and play install. Saves me $100 by just buying the thing and doing it myself.
  6. Sep 7, 2018 at 5:44 AM
    DMBfan
    Shouldn't the shop have done this?
  7. Sep 7, 2018 at 5:48 AM
    4Runner
    4Runner New Member
    Columbia, SC
    2017 Black Limited FFV
    Magnuson Supercharged, FOX 2.5 DSC front and rear, TRD Exhaust, TRD Rear Sway, and many more....build thread coming
    I guess if they carry the Hypertech they could have offered as an option. I’m just living with mine be off a few mph.
  8. Sep 7, 2018 at 6:09 AM
    Sas
    OKC, OK
    Mine will be about 6 mph faster when going 70 mph. That's a little too much for my liking.
  9. Sep 7, 2018 at 7:12 AM
    Rica25
    Ricardo
    Tulare
    Exactly the same here
  10. Sep 7, 2018 at 7:14 AM
    ChrisTRDPro
    ChrisTRDPro New Member
    MT
    2017 Tundra TRD Pro CM
    Not only is the speedo off, the odometer will be off too. It adds up fast how quickly that thing gets out of whack.
    Sas likes this.
  11. Sep 7, 2018 at 7:15 AM
    Rica25
    Ricardo
    Tulare
    How much does it run for the hypertech part?
  12. Sep 7, 2018 at 7:39 AM
    Sas
    OKC, OK
  13. Sep 7, 2018 at 7:45 AM
    Rica25
    Ricardo
    Tulare
    Besides calibrating does it do anything else
  14. Sep 17, 2018 at 5:17 PM
    mfire01
    mfire01 New Member
    2017 Blazing blue pearl TRD
    i just installed a hypertech 730119 on my 2017 tundra CM. I went from a 255/70/18 to a 305/55/20. I cannot get my speedo correct with the hypertech. I have contacted hypertech and they just keep telling me to play with it until its corrected. My speed is off 2 miles an hour faster than speedo is showing. I can get it to match my GPS speed but then my odometer is off my 3 to 4 tenths which adds up. does anyone have a suggestion?
  15. Sep 17, 2018 at 5:21 PM
    ChrisTRDPro
    MT
    The odometer is based off the speed. How do you know the odo is wrong? If you can get the speed correct, stick with that.
  16. Sep 17, 2018 at 5:30 PM
    mfire01
    mfire01 New Member
    i can set the speed using my garmin GPS. I can get on the interstate and stop at the mile marker. I reset my trip on and reset the GPS at the next mile marker the gps is right but my truck is at 7 to 8 tenths of a mile. but the speed is dead on. thats why i'm confused. I can take my wifes camry and test it and it is dead on with the gps and miles.
  17. Sep 17, 2018 at 5:50 PM
    Sas
    OKC, OK
    Not all tires are sized exactly the same. You can either look up the exact tire size by the manufacturer and try using the equivalent of whatever size that is, or keep changing the height of the tire until you find one that works.
  18. Jul 23, 2020 at 6:39 AM
    2006Tundra
    2006Tundra Financially Irresponsible
    Lou
    Long Beach, CA
    2006 Toyota Tundra Double Cab SR5, 4.7L V8
    Has anyone had any luck calibrating their speedometer on a 2006 Tundra after re-gearing and bigger tires?
    Rica25 likes this.
  19. Oct 5, 2020 at 12:16 PM
    2006Tundra
    Lou
    Long Beach, CA
  20. Jun 29, 2024 at 3:51 PM
    Yodadog
    Yodadog New Member
    Rick
    24 tundra sr5 crewmax 4x4
    running boards - mud flaps - tires - bumper step - dash mat - Early Oil Change!
    Hey guys I have a two way scan tool. Is it possible to calibrate spedo/ odo with this tool?
  21. Jun 29, 2024 at 4:16 PM
    coTony
    Tony
    Montrose, CO
    Not to my knowledge
