Recalibrate safety sense for new front bumper end caps?
Discussion in '2.5 Gen Tundras (2014-2021)' started by usfdrohead, Nov 28, 2017.
  1. Nov 28, 2017 at 6:33 PM
    usfdrohead
    usfdrohead [OP] New Member
    Hey guys,
    I am extremely close to getting my chrome front bumper end caps on my 2018 replaced with paint matched ones. However, I am concerned because I believe the whole grill needs to come off. To take the grill off, I will need to unplug the sonar from the grill (toyota logo). If I do this I was told I have to take the truck back to the dealership to have safety sense recalibrated .
    Is this true? Asking because if so that may be a deal breaker for me.
  2. Nov 28, 2017 at 6:53 PM
    The front sensors in the caps are parking sensors. You don’t need to remove the grill for the front caps.
  3. Nov 28, 2017 at 7:01 PM
    TXMiamiFan
    Jose
    2016 White Crew Max TRD
    I have min early turned off as I don’t use em and beep for no reason. So I didn’t recalibrate.
  4. Nov 28, 2017 at 7:14 PM
    usfdrohead
    Right, I understand that those censors in the bumpers are for parking. However, when I was reading instal instructions of the end caps from sparks, they said you need to remove the entire grill.
  5. Nov 28, 2017 at 7:26 PM
    Never heard of that.
  6. Nov 28, 2017 at 7:45 PM
    usfdrohead
    Yea. I’m not sure , but this is exactly what sparks told me:
    “To do the swap, you need to remove your grille and the panels under your headlights. Once those are removed, you can get to the bolts that hold on the entire front bumper and swap out the end caps and then reinstall.”
  7. Nov 28, 2017 at 8:47 PM
    the_midwesterner
    the_midwesterner New Member
    Luis
    None, yet....
    If you send me a message tomorrow I'll look it up while at work.
    I don't think recalibration will be necessary so long as the position of the sensor stays relatively the same and you don't disconnect the battery. I'll double check though and let you know.
  8. Nov 29, 2017 at 3:45 AM
    71_340
    71_340 The German
    Hans
    FLW, MO
    I had the grille off on my 2018 because I installed color coded surrounds and hood bulge. The adaptive cruise is working fine. no sensor alignment was needed, just don't bang stuff around.
    Also, no need to unplug the wiring harness right at the sensor. There is an access cover on the driver side right next to the hood latch, just flip it up, remove it and you can unplug the harness for the cruise sensor right there. I didn't realize that until after I had the grille removed. Makes things much easier.
