Rebuild vs Replace (Fabtech Dirt Logics)
Discussion in '1st Gen Tundras (2000-2006)' started by Mctodd, Sep 8, 2018.
  1. Sep 8, 2018 at 9:20 AM
    Mctodd
    Mctodd [OP] New Member
    Todd
    Nor Cal
    2003 SR5 4wd TRD
    F. Fabtech Dirt Logic 2.5, Icon 1.5 Add a Leaf pack, BFG KO2s 285/75/17, 1.25 Spydertrax, SPC UCAs.
    I've got an older (all blue) pair of Dirt Logic 2.5 Coilovers that have been on the truck since i bought it about 5 years ago. The drivers side appears to be a little leaky and has started squeaking a bit down by the lower mount so they need to be rebuilt or replaced.
    From what I read they seem to be mid range + so the question to rebuild or replace?
    I don't have a ton of money to spend so i'm not looking for super high end stuff just good, durable, and reliable. Before reading up on the Dirt Logics I was thinking about going Bilstein 5100s all the way around, but after a little research I started thinking maybe it would be cheaper to just have them rebuilt. It seems like it would save me $ and I'd still end up with a pretty solid product?
    Any advice or insights out there for me?
    The truck is my daily driver so its mostly on the road, I commute on the freeway, haul stuff around, tow a light trailer (I'm and Ag teacher) and then get out to camp and fish on the weekends and in the summer.
    831Tun likes this.
  2. Sep 8, 2018 at 9:24 AM
    831Tun
    831Tun crazy Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    TC LT w/ king 2.5 C/O and bypass, ADS bypass rear, Toytech shackles, TRD dual exhaust dumped, KM3 37s on Method standard +18. N_Fab front bumper, Westin rear w/ hitch relocate, RCI skids, Desert Eagle tranny skid, All Pro sliders, ARB dual compressor, 5.29 gears and ARB rear locker
    I don't know a lot about the Fab Tech shocks but I'm guessing that 5100s would be taking a step backward. Personally, I'd lean toward rebuilding, and delve into possible valving changes/upgrades.
    Mctodd [OP] likes this.
  3. Sep 8, 2018 at 9:28 AM
    OBXTundra
    OBXTundra Member
    2018 Nissan Armada, 4x4
    X2, I'd look into a rebuild first. My buddy had Dirt Logic coilovers on his Tacoma, they're older, but seemed really stout. Rode really well too.
    Mctodd [OP] and ColoradoTJ like this.
  4. Sep 8, 2018 at 4:25 PM
    Mctodd
    Todd
    Nor Cal
    2003 SR5 4wd TRD
    Thanks Guys, that helps reinforce what i was thinking. I wanted to put it out there to see if there was something big i was missing.
    831Tun likes this.
  5. Sep 8, 2018 at 6:08 PM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    You would be at a higher cost to go 5100, you would need new top mounts and coils to go with the 5100s. I would rebuild, but keep in mind your truck will be down for a few days.
  6. Sep 9, 2018 at 6:18 AM
    Professional Hand Model
    Hand Protectors
    Thats the only disadvantage with the rebuilding is the longer downtime. Plus side is the loads of money saved by not buying new shocks.
    McTodd, Curious on what the parts rebuild cost is on Dirt Logics?
  7. Sep 9, 2018 at 10:21 PM
    Mctodd
    Todd
    Nor Cal
    2003 SR5 4wd TRD
    @Professional Hand Model, I've seen some rebuild kits for $16-30 for the seals and o rings but then you need the gas/fluids and the of course time and tools...i found a local shop that does rebuilds for about $70 so i'm going to give them a call tomorrow.
