Reborn Tundra owner
Discussion in 'New Member Introductions' started by Gecko, May 27, 2023.
  1. May 27, 2023 at 1:45 PM
    Gecko
    Gecko [OP] New Member
    Richard
    Hi gang,
    My first Tundra was a 2009 I had it about a week before a record snow fall in Eastern Washington. It was one of the few vehicles traveling on the road instead of getting dug out of a ditch. 130,000 miles later, I traded it for a Tacoma.
    After rolling with a Tacoma for 3 years, I traded back to a Tundra. My only problem is: This new 2023 Tundra Limited is BUTT UGLY. I can't get used to the brushed aluminum looking "Fu Manchu".
    Oh well, Here I am. I will need some solid advice on new front grill parts to dress this thing up a bit. I will also need advice on wheels and tires. I don't know how to buy wheels; I don't know what the second number on 20x10 means. I need advice on the largest wheels and tires combo for no-lift and for 3" lift.
    Actually, I need advice on whether a 3" lift is good or bad for this 2023 Tundra.
    Thank you for all the help you can give
  2. May 27, 2023 at 2:03 PM
    When you see a 20x10 or 18x9, that is the diameter and width of the wheel....ie 18 inch diameter with a 9 inch width.
    GODZILLA likes this.
  3. May 27, 2023 at 4:26 PM
    Gecko
    Richard
    Thank you!
    Continuing my quest to spiff up that 2023 Tundra.
  4. May 28, 2023 at 2:53 PM
    Rgross2112
    Rush
    2020 Silver TRD Limited
    Get your wallet ready, this group has a tendency to pressure increased spending. Welcome from Pennsylvania
    Gecko[OP] likes this.
  5. May 28, 2023 at 3:06 PM
    Welcome to the forum!
    As for whether a lift is good or not, that's a personal choice. Just know that lifting it and putting on bigger tires is going to hammer your fuel economy. It does on any vehicle. The change to aerodynamics has a big impact and adding weight doesn't help either.
    Personally, if you don't need a lift to fit bigger tires for added ground clearance, I would leave it stock sized. If you want a nicer ride you can downsize from a 20" wheel to an 18" on the same diameter tire. The added sidewall makes it more cushy.
    Also, :worthless:
    Gecko[QUOTED][OP] and Rgross2112 like this.
  6. May 28, 2023 at 7:18 PM
    Gecko
    Richard
    "Get your wallet ready, this group has a tendency to pressure increased spending. Welcome from Pennsylvania"
    Rgross, thanks for the warning. My budget just got tight because of this new Tundra, so artificial discipline applied.
    "Personally, if you don't need a lift to fit bigger tires for added ground clearance, I would leave it stock sized. If you want a nicer ride you can downsize from a 20" wheel to an 18" on the same diameter tire. The added sidewall makes it more cushy."
    Godzilla, good tip. I might take that advice just to keep from getting into too much expense. I got street tires on now, and my property can get a really muddy 100 yd drive way with heavy rain. With that in mind, I do want more aggressive tread. Maybe just some nice GY Wranglers.
  7. May 28, 2023 at 8:21 PM
    Welcome from NY.
  8. May 28, 2023 at 11:11 PM
    EddieBolt
    EddieBolt New Member
    David
    2020 CM SR5 4x4
    This is true! Also get ready to do a lot of researching here. Lots of great info!
    Gecko[OP] and Rgross2112[QUOTED] like this.
  9. May 29, 2023 at 4:44 AM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
  10. May 30, 2023 at 4:38 PM
    Charvonia Design
    Charvonia Design Enthusiast-Owned Small Business Vendor
    Keith
    Huntersville, NC
    2024 Tacoma TRD OffRoad Bronze Oxide
    Welcome back! You’ll find plenty of ways to make your Tundra look better to you by hanging around her.
  11. Jun 1, 2023 at 5:12 AM
    nordicfreak
    nordicfreak New Member
    2015 Navy Blue Tundra SR5 Double Cab
    Topper Decked Drawer System Katzkin Leather
    When you get around to it all, show us some before and after photos!
  12. Jun 3, 2023 at 7:34 PM
    Gecko
    Richard
    I remember when I was 20 year old, snot nosed idiot with a brand new J10 Jeep p/u. I learned a lot in Alabama. How the mud becomes part of your truck, and trying to wash it off is like trying to remove paint. I learned how to get myself out of a creek by running the starter on 1st gear and low range 4x4. Once the tail pipe cleared the water it fired right up. My first white tail buck. TG&Y stores. How to sharpen knives. My first Colt sporter AR. They called 'em Mattel toys back then.
    Lots of cool Alabama memories.
  13. Jun 5, 2023 at 4:58 AM
    RitcheyRch
    RitcheyRch New Member
    Richard
    Santa Clarita, CA
    TRD Lowered and Supercharged
    Welcome from So Cal
