Rear Window Switch Relocation
Discussion in '2.5 Gen Tundras (2014-2021)' started by eric.t.lindgren, Nov 6, 2019.
  1. Nov 8, 2019 at 12:03 PM
    careyrob
    careyrob In the field
    Carey
    Massachusetts
    2008 Crewmax TRD 4x4 Silver
    LRO 3/1 leveling lift 35x12.50's on 20x9's Hellwig rear sway bar B&M 70264 SuperCooler Transmission Cooler Firestone airbags Daystar cradles Air Lift WirelessONE Compressor System
    When I roll down the windows at higher speeds I get a really pronounced buffeting noise from the wind, but if I roll down the rear window just a few inches the buffeting stops and having the windows down is much quieter.
    BravoDeltaRomeo and panicman like this.
  2. Nov 8, 2019 at 4:52 PM
    BackHandHighballer
    BackHandHighballer New Member
    2017 White Tundra Crewmax 1794
    Lol bro that's just 1 window down. Highway speeds create a literal.vortex with the aerodynamics and you need an adjacent window open all the time. Try it out
    Drivers, passenger back
  3. Nov 8, 2019 at 5:15 PM
    Stocky Balboa
    Stocky Balboa New Member
    OC , CA
    2018 Limited TRD 4x4 CM - Cement
    Minor stuff- Tint, rear sway bar , pedal commander, TRD drop in filter DD Exhaust, Bilstein 6112/5160, stealth 32” lightbar, Cali Raised Offroad fog light replacements.
    Yesssss! Thought I was the only one! Haha
  4. Nov 8, 2019 at 5:23 PM
    Stocky Balboa
    OC , CA
    my 4runners rear window switch location is much better. Seems like they could have put it in that rectangle spot behind the console shifter.
    BackHandHighballer likes this.
  5. Nov 8, 2019 at 6:16 PM
    biebs96
    PA
    In my 2nd gen I extended all the wires in a diy harness I made and put the switch in the center console like @careyrob did.
    And the day this post was started I was thinking to myself... I wonder if I can put this in the door armrest.
    If the switch wasn’t so deep it would fit perfectly in the center console under the lid. When arm is placed on center armrest, fingers would be dangling above it.
  6. Nov 20, 2019 at 4:31 PM
    shootis
    shootis New Member
    James
  7. Nov 20, 2019 at 5:17 PM
    71_340
    71_340 The German
    Hans
    FLW, MO
    Because you usually leave the mirrors alone once they are adjusted and Toyota saves a few dollars.
    1lowlife and biebs96 like this.
  8. Nov 20, 2019 at 6:01 PM
    bmcdds
    bmcdds New Member
    CA
    2019 Barcelona Platinum
    Not true if there are more than one driver of different heights/mirror position preferences (hence two settings for seat positions, so Toyota is prepared for two drivers of different sizes). Plus, the reason why I want them lit is because I tuck the mirrors in to park in my garage. So I'm using that every time I pull in and back out of the garage, and fumbling for it in the dark is a pain.
    biebs96 likes this.
  9. Nov 20, 2019 at 6:59 PM
    71_340
    71_340 The German
    Hans
    FLW, MO
    Point was that it saves Toyota money.
    BravoDeltaRomeo likes this.
  10. Nov 20, 2019 at 9:57 PM
    bmcdds
    bmcdds New Member
    CA
    Sounds like you’re backtracking a bit. ;) You made two points, hence the “and”. To your second point, why are switches like the rear window (a luxury) lit, but one that is involved with safety (mirror adjustment) not? Doesn’t really matter why. Posters are simply stating that we don’t like it.
  11. Nov 21, 2019 at 3:20 AM
    Stumpjumper
    Stumpjumper Not a new member
    Fate, Tx
    2017 Tundra TSS 4x4
    Heck the Prius even has a backlit switch. Noticed when I drove neighbor's
    bmcdds likes this.
  12. Nov 21, 2019 at 9:24 AM
    Levinger79
    Levinger79 New Member
    Knoxville TN
    2016 White Tundra Platinum
    I saw a thread awhile back where the guy moved his rear window switch under the climate control and radio, to the glass breaking mics location, and then had a lightbar switch where the back window switch originally was. Looked clean.
  13. Nov 21, 2019 at 10:32 AM
    careyrob
    Carey
    Massachusetts
  14. Nov 21, 2019 at 11:09 AM
    Levinger79
    Knoxville TN
    Negative.... It was a 3rd gen
  15. Nov 21, 2019 at 12:41 PM
    Challenger1
    Challenger1 Gramping
    Andy
    Southern California /Tustin
  16. Nov 21, 2019 at 12:55 PM
    bmann7
    bmann7 Silver Sky Platinum Pro
    WA
    2019 SSM Tundra Crewmax Platinum
    See signature line
  17. Nov 21, 2019 at 7:48 PM
    careyrob
    Carey
    Massachusetts
    Oh. Okay. Link?
  18. Nov 21, 2019 at 7:57 PM
    Levinger79
    Knoxville TN
    Looked for a bit, couldn't find it. But was definitely a 3rd gen that moved his rear window switch to the center portion in the slot for the glass breaking mic. And had a lightbar switch in the stock rear window slot.
